SBM Air Gap mods? #1723637
01/07/15 12:49 AM
01/07/15 12:49 AM
Between a rock & a hard place
cudadoug Offline OP
cudadoug  Offline OP
Any of you "porter" guys have proven Air Gap mods??
If it's worth the $$, I'd gladly send you mine to do your thing to it.
PM or email me if you'd prefer. Thanks!
Re: SBM Air Gap mods? [Re: cudadoug] #1723638
01/07/15 01:00 AM
01/07/15 01:00 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Not a air gap but a performer i put on my van that has like 150hp. Yours might not be this bad
Re: SBM Air Gap mods? [Re: cudadoug] #1723639
01/07/15 01:19 AM
01/07/15 01:19 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I have seen some pretty nice gains on a BBM RPM with porting but haven't had a chance to test the small block version back to back
It looks like it could definitely use the same treatment though.
Keith
Re: SBM Air Gap mods? [Re: Dunnuck Racing] #1723640
01/07/15 08:49 AM
01/07/15 08:49 AM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
I did one....Ports and cut the divider down....removed the logo, removed all the extra bosses on it...etc
Re: SBM Air Gap mods? [Re: Dragula] #1723641
01/07/15 02:18 PM
01/07/15 02:18 PM
cudadoug Offline OP
cudadoug  Offline OP
Any flow bench numbers before/after to evaluate any gains??
Re: SBM Air Gap mods? [Re: cudadoug] #1723642
01/07/15 04:33 PM
01/07/15 04:33 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I built a 402 SB with eddy heads, TTIs, 230@.050 hydraulic roller, and we ran a 650 double pumper, it was choking bad as the RPM climbed, started pulling vaccume and not pulling as hard as I thought it should. We had no room for a spacer and no bigger carb in the budget so I chucked a carbide in the router and milled out 3/4 inch of the divider from front to back and it would pull another 500 RPM. When we built it I did just a little radiusing in the plenum and some gasket matching... basic stuff. After eventually switching to a 750 it became a real animal pulling another 500 RPM more and now the hood and doors barely open and close (68 cuda).
Re: SBM Air Gap mods? [Re: cudadoug] #1723643
01/07/15 10:55 PM
01/07/15 10:55 PM
No, but the entire fuel mixture cleaned right up. I was using a carb and it really liked the 1" open spacer and the cut down divider. Obviously port matching helped too, but it had a snappier rev to it, and it really liked it.
I did it in stages. I tried a 1/2" divided spacer first, then cut the divider down a bunch and used a 1" open spacer....I think it liked the added plenum the most. Then I switched to efi...
Re: SBM Air Gap mods? [Re: Dragula] #1723644
01/07/15 11:20 PM
01/07/15 11:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I was just reading today in one of the Mopar mags
that they are building a 416 with that intake and
it showed a few pics and its mods.. not sure about
flow numbers..this was part 2 of the artical....
sorry I dont recall which mag... but its on sale now
Re: SBM Air Gap mods? [Re: MR_P_BODY] #1723645
01/08/15 12:54 AM
01/08/15 12:54 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Mopar Muscle
Tony
70 AARCuda Vitamin C
Re: SBM Air Gap mods? [Re: 70AARcuda] #1723646
01/08/15 02:55 PM
01/08/15 02:55 PM
cudadoug Offline OP
cudadoug  Offline OP
Thanks all! I'll hunt down the MM mag.
The gasket match is a no brainer as the intake is a little conservative compared to my gaskets, and I ASSUMED the added plenum would be a plus. I just thought I'd survey the brain trust and see what is out there and if someone already had "porting" program established, I'd contribute to their revenue.
Re: SBM Air Gap mods? [Re: cudadoug] #1723647
01/08/15 05:08 PM
01/08/15 05:08 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
I'd port match, smooth radius the entry at carb and run it.
Re: SBM Air Gap mods? [Re: cudadoug] #1723648
01/08/15 10:30 PM
01/08/15 10:30 PM
MD
1965fish Offline
1965fish  Offline
MD
Sorry to hijack the thread but what kind of valve covers are these?
1965 Plymouth Barracuda Formula S
1965 Plymouth Valiant 200 Convertible
1965 Plymouth Valiant 200 Station wagon 408 6.52 @ 104
2001 Dodge Dakota 394 6.63 @ 103 1/8 mile 10.64 @ 123 1/4 mile
1965 Plymouth Valiant Signet 2DR HT
Re: SBM Air Gap mods? [Re: RobX4406] #1723649
01/08/15 10:47 PM
01/08/15 10:47 PM
cudadoug Offline OP
cudadoug  Offline OP
That's the plan now. I'll also cut down and narrow the divider as that seems to be SOP on these intakes I've learned.
Re: SBM Air Gap mods? [Re: cudadoug] #1723650
01/08/15 11:03 PM
01/08/15 11:03 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I know it's a different intake but I did a fair amount of flowbench and porting on an ld340 intake and divider work paid little dividends Intake flange and radius attention was where the payoff was. The runners needed work but with the design of these intakes that was impossible. If you want to flow over 270-275 cam step up to a different manifold
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
