read "breakin secrets" at
www.mototuneusa.com make a mark on the dampener 2&1/4" (35.5 deg) CW from the TDC slit & have the guy manning the dist to set it to that when it fires for the cam breakin (can capped). any leaks/issues dont think about it just shut it off/fix it/refire back to 2500 RPM & continue on with the 25 min breakin procedure. You want a zinc additive for the cam. gm eos or something similar. In preperation set the dampener to 15 BTDC then move dist so the magnet is dead even with the tooth (#1 compression/#1 plug wire). Thermostat OUT. shop fan in front of rad. fill bowl with a syringe & several pumps to prime the eng & confirm the AP is working. You want it to fire right away & immed bring the RPM's up. you in the dr seat to watch the gauges/shout orders
, one helper to man the dist/timing light, another one top & underneath to check for leaks. You have ONE chance to get the cam and ring breakin correct & after all that time/money you want to get it right. As said I woulda went with Moly & they both want a different bore finish but you'll be fine. EDIT I missed that you have a roller cam so I am assuming no zinc needed.
