Re: how to make Challenger more road friendly
[Re: moparmikethree]
#1722810
01/06/15 01:36 AM
01/06/15 01:36 AM
Posts: 4,848 Memphis
HemiRick
Memphis
All over the place is not very specific description of the symptoms.....Is there play in the steering? Does it drive fine at low speeds? Was the guy who aligned it ever done an old Mopar before?
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
#1722817
01/06/15 04:53 AM
01/06/15 04:53 AM
Posts: 1,723 North Austin
KnuckleDuster
North Austin
Rear leaf springs have new bushings. Six plys right side five on left. I may need a new gear box, what all makes and models will work. I will get a brand new box
If you do get another box, be warned it might be as sloppy as what you already have. Don't know who sells a brand new box but I bought a remanned Cardon box and it sucked...BAD!
Upgraded to a Firm Feel Stage III and it totally changed the car. Love it!
Seemed a little pricey at first,but after wasting almost $200 on the reman I say it's the best money I've spent on the car.
#1722820
01/06/15 10:54 AM
01/06/15 10:54 AM
Posts: 5,444 Indiana
YO7_A66
Indiana
""I do not have sway bars,would they help?""
My first Challenger (74) did not have sway bars. It drove well at lower speeds but when I was highway cruising speeds and I hit a bump, it started wondering around. My current Challenger has the stock front sway bar and a 3/4" rear sway bar and it drives a lot better at highway speeds than my 74. It is very tight at highway speeds now. If you do not find anything wrong underneath the car, then you might want to look into at least a front sway bar (1-1/8" or so).
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: KnuckleDuster]
#1722823
01/06/15 11:23 AM
01/06/15 11:23 AM
Posts: 4,244 Canada
Kam*Kuda
Canada
I did the same. The firm feel made a huge difference. I used the Addco sway bars. That helps lots with body roll. the biggest difference was better tires Quote:
1970 Barracuda Convertible 1968 Satellite Street Strip car 1654.5 Mustang 1955 Land Rover
[Re: gdonovan]
#1722824
01/06/15 11:40 AM
01/06/15 11:40 AM
YO7_A66
Indiana
""It drove well at lower speeds but when I was highway cruising speeds and I hit a bump, it started wondering around.""
""I have driven the GTX with and without the swaybar (to aid in racing) and never noted a difference at highway speeds.""
Mine only wondered after hitting bumps at highway speeds. It just felt "squishy" without the sway bar(s). I guess it could have been low cost shocks too.
#1722826
01/06/15 01:09 PM
01/06/15 01:09 PM
Posts: 5,394 Pikes Peak Country
TC@HP2
Pikes Peak Country
Drives very good around town,when at high way speed you have to "saw" the steering wheel. I did the alignment at work. Been a mechanic for 33 years, at Dodge dealer for 28 years
If your sawing the wheel, it sounds like you have a worn out steering box, worn out box coupler, or some pretty wide bias ply tires. If everything else is new but the box and/or coupler, I'd suspect the box and the coupler are the culprits. I'd second the suggestion to get a rebuilt Firm Feel box and associated coupler rebuild kit. There also is the Borgeson box upgrade that could be utilized, but it will cost a bit more than the Firm Feel box.
I'd also update your alignment specs to be more aggressive if you are using radial tires. Radials will tolerate a wider range of specs than bias ply. Us the specs for a 2005 Mustang to get things a bit more modern. This also will enhance the feel with increased caster and some negative camber.
A front sway bar wouldn't be a bad addition, either.
