Best clutch drum for 727 #172245
12/21/08 01:28 PM
12/21/08 01:28 PM
Mopar Lane,Mississippi
67HEMI Offline OP
67HEMI  Offline OP
I am going to replace the clutch drum in my 727. My car is primarily street driven,weighs 3850,runs low 10's,and has a trans-brake. Should I go with a billet steel,aluminum or a steel sleeved aluminum drum that Mancini sells? Thanks in advance! And no I am not going to switch to a Chevy transmission
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: Best clutch drum for 727 [Re: 67HEMI] #172246
12/21/08 01:40 PM
12/21/08 01:40 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
I would use this drum Don't forget to check the champher clearance on the rear to front clutch drum, when using this. I usually just buy a new rear retainer, it's easier and cheaper than driving someplace and digging through a bunch of junk to hopefully find the correct type. If you have a friend with a lathe, of course, it's no big deal.
Re: Best clutch drum for 727 [Re: 67HEMI] #172247
12/21/08 01:43 PM
12/21/08 01:43 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
Billet that A&A makes.
you can get it from CRT.
after reading another post on aluminum drums, there only for the die hard, they need to be machined after so many runs and put alot of small shavings through the trans.
Re: Best clutch drum for 727 [Re: 70blackfish] #172248
12/21/08 07:29 PM
12/21/08 07:29 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Get a billet steel drum. The alum one require much more maintenence and fluid changes.
Call John at CRT. That's where I got mine. Great customer service.
Re: Best clutch drum for 727 [Re: 70blackfish] #172249
12/21/08 07:34 PM
12/21/08 07:34 PM
67HEMI Offline OP
67HEMI  Offline OP
I was just thinking that the steel sleeved aluminum is 2 lbs lighter and still has steel for the band apply surface.Thanks for info, I got the CSR shield so while I had it out thought I would do it right.
Re: Best clutch drum for 727 [Re: WILD BILL] #172250
12/21/08 07:36 PM
12/21/08 07:36 PM
67HEMI Offline OP
67HEMI  Offline OP
Will do thanks!
Re: Best clutch drum for 727 [Re: 67HEMI] #172251
12/21/08 08:23 PM
12/21/08 08:23 PM
Kokomo, IN
540dust Offline
540dust  Offline
Kokomo, IN
Steel.
Re: Best clutch drum for 727 [Re: 540dust] #172252
12/21/08 08:29 PM
12/21/08 08:29 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
me and quicktree had are hands all over the aluminum drum with steel sleeve and replacable bushing at the PRI show. very nice piece. alot lighter than the all steel drum too. the steel sleeve is replacable. that is the one i will buy when i can scratch up the change
Re: Best clutch drum for 727 [Re: sixpackgut] #172253
12/22/08 02:00 AM
12/22/08 02:00 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i went with the TCS steel drum after reading about the failure rpm's of all the different drum combo's. the steel drum was still in 1 piece after it reached failure rpm, more that can be said about the aluminium & ali/steel sleeve versions. buy direct from TCS they're good people to deal with & they're cheaper than dealing with other middle men who want their share of the profit on top.
Re: Best clutch drum for 727 [Re: 67HEMI] #172254
12/22/08 11:13 AM
12/22/08 11:13 AM
NW Indiana USA
727specialist Offline
NW Indiana USA
The TCS drum is a real nice piece.
It is lighter than the steel drum, I think it is the best choice.
Re: Best clutch drum for 727 [Re: 727specialist] #172255
12/22/08 10:13 PM
12/22/08 10:13 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
....and the TCS drum has a servicable bushing in it. Saw one at MaTS. Nice piece!!
