Re: Best clutch drum for 727
[Re: 67HEMI]
#172246
12/21/08 01:40 PM
12/21/08 01:40 PM
Posts: 5,991 Anoka County, MN
Leigh
Anoka County, MN
I would use this drum Don't forget to check the champher clearance on the rear to front clutch drum, when using this. I usually just buy a new rear retainer, it's easier and cheaper than driving someplace and digging through a bunch of junk to hopefully find the correct type. If you have a friend with a lathe, of course, it's no big deal.
[Re: 70blackfish]
#172248
12/21/08 07:29 PM
12/21/08 07:29 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Get a billet steel drum. The alum one require much more maintenence and fluid changes.
Call John at CRT. That's where I got mine. Great customer service.
[Re: 70blackfish]
#172249
12/21/08 07:34 PM
12/21/08 07:34 PM
Posts: 902 Mopar Lane,Mississippi
67HEMI
I was just thinking that the steel sleeved aluminum is 2 lbs lighter and still has steel for the band apply surface.Thanks for info, I got the CSR shield so while I had it out thought I would do it right.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction)
'69 Chrysler 300 Convertible 375 HP 440
'71 Plymouth Duster 360 W/EFI (Wife's Ride)
'12 Ram MegaCab Dually 6.7 Cummins
[Re: 540dust]
#172252
12/21/08 08:29 PM
12/21/08 08:29 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
me and quicktree had are hands all over the aluminum drum with steel sleeve and replacable bushing at the PRI show. very nice piece. alot lighter than the all steel drum too. the steel sleeve is replacable. that is the one i will buy when i can scratch up the change
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
