Grounding for battery in the trunck?
#1722011
01/05/15 12:38 PM
01/05/15 12:38 PM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I have had great success running a rear battery and using the cage for a ground for the most part. I ground the heads AND block to the frame, use two 3/8 bolts welded to the frame, one for the electronics and one for the starter circuit. My question is, for my street dart there is no cage, and I am moving the battery to the back. I am looking for a good way to ground the battery and thought that the same system would work, provided the ground connections are big enough (bolt welded all around the head?)to not create resistance at those points. I would drill a hole in the floor at the subframe area and weld it to the sub. The car has frame connectors. Input?
Re: Grounding for battery in the trunck?
[Re: gregsdart]
#1722012
01/05/15 12:45 PM
01/05/15 12:45 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Since electricity travels on the exterior of the wire (and the cage tubing) the cage isnt the best... so they say.. I have never had any issue doing the same thing on the cage as you.. and thats the way I set up my Rampage.. I will tell you how the EFI likes that ground system.. but I have no doubt its fine
[Re: gregsdart]
#1722019
01/05/15 02:29 PM
01/05/15 02:29 PM
Posts: 7,506 Az
Crizila
Az
Directly to the frame is ALWAYS your best bet - for grounding everything. Least # of attaching points for the starter / alternator. Next best is something that is welded to the frame. Worst is something that is bolted to the frame. Doing voltage drop tests are always in order when doing / checking grounds.
Fastest 300
[Re: Crizila]
#1722022
01/05/15 03:18 PM
01/05/15 03:18 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Not close to correct...........in fact that is the WORST way to wire a ground system. Just because people do it all the time and it is passable, does not make it right. Work with a lot of EFI cars as I do and you will quickly find the flaws in this type system. Your frame or sheetmetal is a TERRIBLE conductor.
What I do on all the EFI and actually everything I wire now, is a "floating" ground system. I attach a copper bus bar on rubber isolators under the dash. I run the cable from battery to bus bar and run all high draw grounds to this bar, such as ignition, pumps, fans, etc. I also tie both heads together and run a ground wire to bus bar as well. The ONLY thing I ground to the actual chassis or sheetmetal is the lights
Monte
[Re: Monte_Smith]
#1722023
01/05/15 04:06 PM
01/05/15 04:06 PM
dartman366
Mt. Vernon, Ohio
Monte
this is they way I did it back in the day and it still functions correctly, I had run the main ground from the battery to the frame then ran a 08 ground wire to the buss and ran all my grounds to that,,engine,electronics etc.
[Re: Monte_Smith]
#1722024
01/05/15 07:16 PM
01/05/15 07:16 PM
Posts: 7,506 Az
Crizila
Az
Monte
but the individual circuit voltage loss between the 2 systems is negligible, and just not practical in most instance's. Use the frame or 1000 feet of wire? I could see it for some "highly sensitive" circuits, but to run a fan, water pump, or a fuel pump, etc., not needed.
Fastest 300
[Re: Monte_Smith]
#1722025
01/05/15 07:21 PM
01/05/15 07:21 PM
Quicktree
Monte
exactly, thats the way I do them also
[Re: Crizila]
#1722026
01/05/15 07:22 PM
01/05/15 07:22 PM
Quicktree
Monte
not really but you can do it that way if you like.
[Re: Monte_Smith]
#1722027
01/05/15 08:37 PM
01/05/15 08:37 PM
Posts: 9,847 MI, usa
dvw
MI, usa
Monte
Lets look at a new Charger or Challenger. Battery in the trunk, tons of components that are Can Bus based. Cars are even sent to the lab to check for radio and magnetic interference. Guess where the ground connects? Frame rail next to the battery. What do you think? Doug
[Re: dvw]
#1722030
01/05/15 10:50 PM
01/05/15 10:50 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
Monte
Frame has high copper content.
If you like drag racing, support your local track.
