Re: Optima Red Top battery box and battery cable sizing
[Re: AlexP]
#1721888
01/05/15 03:11 AM
01/05/15 03:11 AM
Posts: 793 Utah
topbrent
Utah
Calculate your total maximum potential amperage load first. This will tell you what size cable you need. ECU, injectors, fans, pumps, stereo, headlights, horn, tailights, domelight, A/C, signals, markers, brake lights, 12v acc, oxygen sensors, ect. Make sure you pay attention to the ground capabilities also. You need low resistance on that side of the circuit as well. Depending on your grounding scheme preference, nearly 45-50 ft of 1/0 cable is probably what is spec' for your application (charge+ground). (I would keep it simple and use a modern lightweight battery up front. )
[Re: AlexP]
#1721889
01/05/15 03:30 AM
01/05/15 03:30 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I assume this is in the RR.. if you have a rear fire wall behind the seat(alum or steel) you dont need a box for the battery... if not.. then yes you need a enclosed box
[Re: MR_P_BODY]
#1721890
01/05/15 11:48 AM
01/05/15 11:48 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Ballistic Fabrication makes sweet battery holdowns that fit in a regular marine box.
Mopar to the bone!!!
[Re: AlexP]
#1721891
01/05/15 12:25 PM
01/05/15 12:25 PM
Posts: 7,506 Az
Crizila
Az
About the best bang for the $ is the kit from Summit #SUM-G1231-K. Comes with 20 ft of 1 gage.
Fastest 300
[Re: Crizila]
#1721892
01/05/15 12:52 PM
01/05/15 12:52 PM
Posts: 22,696 Bitopia
jcc
Bitopia
It is odd that chart jumps from 4 gauge to 1/0. And DC travels in the core of the wire unlike AC that favors the surface.
[Re: jcc]
#1721893
01/05/15 12:56 PM
01/05/15 12:56 PM
MR_P_BODY
I didnt know that DC likes the core.. thought they all used the outer area
[Re: MR_P_BODY]
#1721894
01/05/15 01:21 PM
01/05/15 01:21 PM
Posts: 10,645 Houston, Tx
AlexP
Houston, Tx
It is for my RR.
I don't have a wall behind the seat, but I'd really like the box to prevent the battery from being hit by anything in the trunk. I'm going to skip the NHRA requirement and leave the trunk switch out.
I'm honestly not sold on the Red Top. I researched last night, and I'm convinced to buy a premium parts house AGM battery over the Red Top.
[Re: AlexP]
#1721895
01/05/15 01:25 PM
01/05/15 01:25 PM
72Swinger
Nebraska
Dollar for dollar you can't beat a CAT battery group 31. 880cca.
[Re: AlexP]
#1721896
01/05/15 01:34 PM
01/05/15 01:34 PM
MR_P_BODY
It is for my RR. I don't have a wall behind the seat, but I'd really like the box to prevent the battery from being hit by anything in the trunk. I'm going to skip the NHRA requirement and leave the trunk switch out. I'm honestly not sold on the Red Top. I researched last night, and I'm convinced to buy a premium parts house AGM battery over the Red Top.
I've been running Die Hard(I believe it is) in my race car and in my Rampage.. the one in the race car has been in there for YEARS.. never even had a charger on it... we did some testing on the Optima batteries at Chrysler(the battery lab did) to see if we would go with them in production... they werent that great and didnt go with them... also being that I run a alt on all my junk I use the standard auto battery and not the marine ones.. they have a different way of being used(without a alt)
[Re: MR_P_BODY]
#1721897
01/05/15 01:55 PM
01/05/15 01:55 PM
Posts: 20,192 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Give these a look. Been using them for many years in Matts and my cars and really like them. http://www.diehard.com/products/automotive
[Re: pittsburghracer]
#1721898
01/05/15 02:10 PM
01/05/15 02:10 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Not that there aren't good & poor batteries, but I know that when I was younger, I spent about a year working in a battery factory. We had a few different specs of batteries (based on lead core surface area) that we built in a number of different color cases. Then, you guessed it, we slapped on stickers from just about every battery brand available! I slapped on stickers from Napa, to DieHard, to every Auto Parts store brand you can think of. All the same batteries. Other than the newer Gel-type batteries, my experience working for GBC (General Battery Corp.) tells me that the reason they all look the same, is because they are.
[Re: StealthWedge67]
#1721899
01/05/15 02:48 PM
01/05/15 02:48 PM
Posts: 7,506 Az
Crizila
Az
A word of caution on older batteries. They may pass a load test, and still not be up to cranking the engine over and firing the ignition at the same time. The last few times I have been out to the track, the car started fine cold off the trailer. No problem driving to the tech lane and teching in. Warm the motor up, drive to staging and shut down and wait for the call. Go to start up, good crank - no fire. As I would release the ignition switch to the run position ( drop out the starter ) the motor would try to fire. Cold motor & starter, no problem. Heat soak a bit in staging and the current draw went up enough to keep the ignition from firing the plugs. Starter draw was in specs. Voltage drop tests were all under .1 volts. Battery TESTED good. Installed new battery. Problem went away.
Fastest 300
[Re: Crizila]
#1721900
01/05/15 03:12 PM
01/05/15 03:12 PM
AlexP
Houston, Tx
I like sealed batteries, so the AGM is the best of both worlds in terms of performance and safety. I need to move the battery to the trunk to support the accessories in the rear. Two fuel pumps and an eventual amplifier. Also, I need the battery out of the engine bay to allow for me to mount a centrifugal supercharger on the drivers side of the hemi. A good trade off...
[Re: Crizila]
#1721905
01/05/15 09:33 PM
01/05/15 09:33 PM
Posts: 29 Washington State
lorenr
Washington State
What about battery weight? When I started this post I thought that someone would comment on battery weight. I'm under the impression that the reason many use the "red top" is because they are more durable, weigh less and are smaller. Does someone make a better AGM battery? I need something that will fire a high compression road race car and is lighter than a lead acid battery. I kind of thought that might be an AGM battery. Lithium ion batteries are the ticket but are just much money. Loren
