Removing pin on bronze dist. gear #172186
12/21/08 12:33 PM
12/21/08 12:33 PM
Santa Rosa,CA USA
67dodgeracer Offline OP
Santa Rosa,CA USA
Is there an easy way to drive out the pin that holds the bronze gear to the intermediate shaft?
Re: Removing pin on bronze dist. gear [Re: 67dodgeracer] #172187
12/21/08 12:46 PM
12/21/08 12:46 PM
yes, it's pretty simple if you use a press. if your trying to drive it out by hand you might be there awhile.
Re: Removing pin on bronze dist. gear #172188
12/22/08 01:44 AM
12/22/08 01:44 AM
Santa Rosa,CA USA
Santa Rosa,CA USA
I thought it would be simple,but my machinist couldn't press it out.Just wondered if it's common for them to be difficult.
Re: Removing pin on bronze dist. gear [Re: 67dodgeracer] #172189
12/22/08 02:08 AM
12/22/08 02:08 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i not long ago replaced my gear for a new one. that pin was not going to move without assistance. we were showing 15 tonnes on the press guage & it was not budging. ended up drilling a small pilot hole & then enlarged it to almost the small end of the pin size. back on the press & it came off at 1.5 tonnes. this might be your best option too as you don't want to damage the shaft if you mishandle it too much.
Re: Removing pin on bronze dist. gear [Re: 67dodgeracer] #172190
12/22/08 02:47 AM
12/22/08 02:47 AM
I've driven them out with a punch and hammer
Re: Removing pin on bronze dist. gear [Re: Cab_Burge] #172191
12/22/08 03:34 AM
12/22/08 03:34 AM
San Diego
formula S Offline
formula S  Offline
San Diego
Re: Removing pin on bronze dist. gear [Re: Cab_Burge] #172192
12/22/08 07:51 AM
12/22/08 07:51 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
I've had one that came apart easy and another one that wouldn't budge
Re: Removing pin on bronze dist. gear [Re: 67dodgeracer] #172193
12/22/08 10:43 AM
12/22/08 10:43 AM
KY
juicedcuda Offline
juicedcuda  Offline
KY
what brand gear are you guys using?
1970 Plymouth 'Cuda 1970 Plum Crazy "Gold Duster" 1973 Gold Duster
Re: Removing pin on bronze dist. gear [Re: juicedcuda] #172194
12/22/08 11:04 AM
12/22/08 11:04 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
If it's stubbern,then grind one end of the pin almst flush with the gear,center punch it.drill in about 1/8" then drive or press it out with the appropiate size drift pin.
Re: Removing pin on bronze dist. gear [Re: B G Racing] #172195
12/22/08 11:31 AM
12/22/08 11:31 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Would heating it work? Matt
Re: Removing pin on bronze dist. gear [Re: MattW] #172196
12/22/08 11:40 AM
12/22/08 11:40 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
I've never heated any.Usually if you can keep the drift pin from jumping around and not mushrooming the pin it with come out.Thats why we grind and drill giving an even and held in place area to start to press or hammer it out.
Re: Removing pin on bronze dist. gear [Re: B G Racing] #172197
12/22/08 10:11 PM
12/22/08 10:11 PM
Santa Rosa,CA USA
Santa Rosa,CA USA
Great tip BG.
