adjustable strut rods
#172150
12/21/08 02:50 AM
12/21/08 02:50 AM
Posts: 206 indy
eds dart
indy
Am getting around to installing some adjustable strut rods i fabbed up. I measured and cut carefully to get the same overall length or so i thought. with everything installed at ride height the lower control arm is obviously not perpendicular to the front frame rail. it should be right? have been searching the net to find some info on dimensions for the front end but no luck so far. anybody got some suggestions? car is a 68 Dart with a complete 74 valiant k and suspension/ disk brake setup. race only, when i built it ten years ago used complete poly bushing rebuild kit, had it aligned and have been racing since. had alignment checked 3 years ago, needed no adjustments. those poly bushing are unbeilevably stiff but look as good as the day i put them in. tubular uppers with rod ends are going in next. nothing is bent or broken car drove fine when i put it up for the winter, just doing some upgrades.
