Re: 1974 Dodge 727 out of a 318 4x4, can I swap tailshafts?
[Re: Stoga]
#1720826
01/03/15 06:51 PM
01/03/15 06:51 PM
Posts: 25,894 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Be careful when swapping tailshafts, the spline angle for the front planetary changed in '76. As long as the tailshaft is '75 or earlier it'll correctly fit your '74 planetary.
[Re: John_Kunkel]
#1720829
01/04/15 02:12 PM
01/04/15 02:12 PM
Posts: 12,174 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
As John said, the only thing to watch for with the swap is the splines where the shaft meets the planetary. Both styles will go together, but the problem is that the degree of pitch is different.
The '75 and earlier has 45* splines, while the '76 and up has 37.5* splines. The later shaft is marked with a groove to aid ID.
Master, again and still
[Re: Stoga]
#1720834
01/05/15 07:54 PM
01/05/15 07:54 PM
Posts: 760 Canada
CTD5.9
Canada
Small block 727s are harder to come by
What promised land are you living in? I have resorted to buying full cars to get BB 727's
[Re: CTD5.9]
#1720835
01/05/15 09:08 PM
01/05/15 09:08 PM
John_Kunkel
Rio Linda, CA
Considering that BB 727's stopped in '78 and SB 727's were built up to '00 I'd say there are a lot more SB's around. Of course, this is regional.
[Re: CTD5.9]
#1720837
01/06/15 09:38 PM
01/06/15 09:38 PM
Posts: 10 WV
Stoga
WV
West Virginia, most anything decent gets derbyed. To be honest, certain Torqueflites are harder to find these days then they once were. I plan to hang onto it, then when the opportunity comes, put it to use in some fashion.
