Rolled indy 360-1 #1720584
01/03/15 02:08 AM
01/03/15 02:08 AM
PA
bwhackd34 Offline OP
PA
While Indy does not reference it I know some guys have done it....how much have you rolled your Indys....wondering if any one has gone .250"....looking for as much compression as I can get and am using a reverse dome piston....it's a 468 so the inches help but want to be above 13:1
Re: Rolled indy 360-1 [Re: bwhackd34] #1720585
01/03/15 04:14 AM
01/03/15 04:14 AM
SoCal
Brian Hafliger Offline
SoCal
I angle mill them 1/2 a degree then correct intake face...spot facing head bolt holes is simple...here's the thing...I don't use Indy's cnc program for the chamber or ex. port.
I hand port them only. So my chambers end up around 48cc.
Brian
Brian Hafliger
Re: Rolled indy 360-1 [Re: Brian Hafliger] #1720586
01/03/15 09:44 AM
01/03/15 09:44 AM
PA
PA
So that's about .060"
Re: Rolled indy 360-1 [Re: bwhackd34] #1720587
01/03/15 10:06 AM
01/03/15 10:06 AM
PA
PA
I had mine 245 cnc'd about 2 years ago... They are the new style castings with the INDY logo under the spark plugs recessed in not raised. Wishing I would not have had the exhaust ports done and hoping they don't turn into sprinklers. I asked if the leaks were still a problem and was told try were not.....I guess we will see...going to be doing some hand work on the intakes today...
Re: Rolled indy 360-1 [Re: bwhackd34] #1720588
01/03/15 12:16 PM
01/03/15 12:16 PM
Walhalla, SC
BlueDart Offline
BlueDart  Offline
Walhalla, SC
My 360-1's were angle milled .100" and if I remember they came in at 53 cc chambers getting ready to dissemble the engine after 12 years I'll check them again
Re: Rolled indy 360-1 [Re: BlueDart] #1720589
01/03/15 05:08 PM
01/03/15 05:08 PM
PA
PA
