1970 Challenger antenna location #1720202
01/02/15 01:24 PM
01/02/15 01:24 PM
Halifax, Nova Scotia
Larry Offline OP
Larry  Offline OP
I would like to know the exact location of the antenna hole in the passenger fender of a 1970 Challenger. There is some debate as to whether mine is in the correct spot or not, and I would really like to fix this issue before paint - smart eh??
Thanks as always
Re: 1970 Challenger antenna location [Re: Larry] #1720203
01/03/15 02:14 PM
01/03/15 02:14 PM
Larry Offline OP
Larry  Offline OP
Anybody out there have a measurement/location for me?
Re: 1970 Challenger antenna location [Re: Larry] #1720204
01/03/15 05:53 PM
01/03/15 05:53 PM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
To center of hole is 6-3/8" from hood edge of fender and 8-3/8" along top body line. I checked this on two other sets of fenders I have ( off cars) as well as on my car.
Re: 1970 Challenger antenna location [Re: 71vert340] #1720205
01/03/15 05:54 PM
01/03/15 05:54 PM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
Here's from the hood edge of the fender.
Re: 1970 Challenger antenna location [Re: 71vert340] #1720206
01/05/15 11:53 AM
01/05/15 11:53 AM
Larry Offline OP
Larry  Offline OP
That is exactly what I needed, the photos are perfect. I can't thank you enough for taking the time to do that.
Larry
Re: 1970 Challenger antenna location [Re: Larry] #1720207
01/06/15 10:22 PM
01/06/15 10:22 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Larry
Unless you are doing a factory concour level restoration, consider installing a power antenna. One of my favorite upgrades to our Challenger. Partly driven by the fact that at times I park the the car under my 4 post lift and tired of removing the antenna to do so.
Re: 1970 Challenger antenna location [Re: Sxrxrnr] #1720208
01/07/15 03:03 AM
01/07/15 03:03 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
you've got the measurements you need
just in case you need it, here's the factory hole opening sizes you need.
Re: 1970 Challenger antenna location [Re: mccannix] #1720209
01/07/15 03:11 AM
01/07/15 03:11 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Here..this one's easier to read, Barracuda and Challenger have same size opening
Re: 1970 Challenger antenna location [Re: Sxrxrnr] #1720210
01/07/15 03:40 AM
01/07/15 03:40 AM
California, USA
filmsurgeon Offline
filmsurgeon  Offline
California, USA
Unless you are doing a factory concours level restoration, consider installing a power antenna. One of my favorite upgrades to our Challenger. Partly driven by the fact that at times I park the the car under my 4 post lift and tired of removing the antenna to do so.
Just out of curiosity: What power antenna did you install? I've been seriously considering this for my Challenger. Thanks.
Re: 1970 Challenger antenna location [Re: filmsurgeon] #1720211
01/07/15 03:28 PM
01/07/15 03:28 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Obtained it from the Mopar Classic Auto Parts catalog. Had tried a couple other brands but unable to fit to the car.
Is a bit tricky when trying to use the stock antenna bezel as comes on Challenger. Was able to achieve success and stock appearance with the Classic supplied antenna.
Looks and fits well.
Any further interest I will try to recreate and post exactly what I had to do to get a successful installation.
Re: 1970 Challenger antenna location [Re: Sxrxrnr] #1720212
01/07/15 11:29 PM
01/07/15 11:29 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Photo of retracted antenna.
The white washer is a requirement as an insulator. Have yet to find something in chrome appearance that is not a conductor. Black plastic would be ok too. Just have not spent the time yet to find something suitable
Re: 1970 Challenger antenna location [Re: Sxrxrnr] #1720213
01/08/15 01:33 AM
01/08/15 01:33 AM
California, USA
filmsurgeon Offline
filmsurgeon  Offline
California, USA
Thanks Roger. Don't know "Mopar Classic Auto Parts". Do you mean Classic Industries? I am certainly interested in your "successful install" process. Thanks in advance for any future posts you can make with more detail.
Re: 1970 Challenger antenna location [Re: filmsurgeon] #1720214
01/08/15 08:49 AM
01/08/15 08:49 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Sorry,,,,Classic Industries it is. Will post installation notes later.
Re: 1970 Challenger antenna location [Re: mccannix] #1720215
01/09/15 12:12 PM
01/09/15 12:12 PM
Larry Offline OP
Larry  Offline OP
Thanks for the template mccannix. Much appreciated.
Re: 1970 Challenger antenna location [Re: Sxrxrnr] #1720216
01/09/15 05:44 PM
01/09/15 05:44 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Classic industries. Power antenna and required bezel(if you need one). Uncertain of difference between the 2 listed. Our Challenger, it appears as the way that ME1536 looks.
http://www.classicindustries.com/shop/mopar/parts/audio-security/antenna-parts/
