Re: tough one: overheating on the highway
[Re: smos001]
#1719507
01/03/15 11:41 AM
01/03/15 11:41 AM
Challenger 1
Cincinnati, Ohio
Might be leaning out as you press into the higher speeds. Does it miss at high cruise? faint lean miss? a lean miss also cause a slight hesitation as you press on the gas at a stop sign. You may have to rejet the carb a little.
Vacuum leak?
Do not discount the 2 guys who suggested this. I third this suggestion.
[Re: FASTBACK340]
#1719513
01/04/15 12:26 PM
01/04/15 12:26 PM
Posts: 1,381 Youngsville, NC
dem440c
Youngsville, NC
I sure hope we find out what the cause is as the remedies are all over the map….
holy moly you aren't kidding... you guys have a LOT of great ideas. A lot of them I have tried already and I've been taking notes on some things to try that I haven't done yet.
- full length headers, 2-1/2" duals through Flowmasters exiting in front of the axle. I'm pretty confident there is no exhaust restriction.
- gonna try the idea to remove the fan and see what happens. Only problem there is I have to drive 25 minutes to get to a highway, guess I'll bring tools and see what happens.
- I haven't mapped the timing yet to see exactly what the distributor is doing as the RPMs increase, I can do that. It runs perfect so I haven't been thinking in that direction but it wouldn't hurt to see what it is doing.
- pulling freeze plugs is gonna be a sucky job but I agree that the symptoms would line up with that cause so it should be explored. Man, that is gonna take me a whole freakin' weekend to pull all that apart and then get new plugs back in... sigh
- changing the ignition module is easy, I have a box full of them. I'll try that just because it is quick and easy.
- someone mentioned air baffles, I have all the ones in place that cover the gap between the core support and the radiator. What else should be there?
[Re: dem440c]
#1719514
01/04/15 12:44 PM
01/04/15 12:44 PM
Posts: 952 Queens, N. Y.
FASTBACK340
Queens, N. Y.
Might be easier to pull the water pump and use a bora-scope and peek in through the timing chain cover openings first. Freeze plugs are a chore on an educated guess.
`68 Barracuda 340-S
[Re: FASTBACK340]
#1719515
01/04/15 02:02 PM
01/04/15 02:02 PM
RapidRobert
![](/ubbthreads/images/graemlins/iagree.gif) that if you do not post the solution (when you find it) that there might be a cyberspace lynching ![](/ubbthreads/images/graemlins/tsk.gif) . Recently a member lost his life cuz he DELETED his thread ![](/ubbthreads/images/graemlins/wink.gif) . On the timing, in your driveway just run it up to the same RPM you are at on the highway when it is getting hot & see what you get with your dialback or make some marks. 0.0632683" around the circumference is 1 degree on the dampener or can use the tab as a ruler. 2&1/4 (2.246") is 35.5 deg which should get you close to what you have tho the can will kick it higher above that
[Re: dem440c]
#1719516
01/04/15 03:41 PM
01/04/15 03:41 PM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
I don't know what came stock on your car as I don't have any experience with these models. But if you're adventurous you could take a trip simply without the hood mounted and see if the issue remains.
[Re: RapidRobert]
#1719517
01/04/15 03:49 PM
01/04/15 03:49 PM
Posts: 727 Ottawa, ontario
dd340
Ottawa, ontario
that if you do not post the solution (when you find it) that there might be a cyberspace lynching . Recently a member lost his life cuz he DELETED his thread . On the timing, in your driveway just run it up to the same RPM you are at on the highway when it is getting hot & see what you get with your dialback or make some marks. 0.0632683" around the circumference is 1 degree on the dampener or can use the tab as a ruler. 2&1/4 (2.246") is 35.5 deg which should get you close to what you have tho the can will kick it higher above that
This made me think of something, can you duplicate the overheating in 1st or 2nd gear if you hold it at the same rpm as you run at highway speeds? If the engine doesn't heat up in the lower gears this would seem to eliminate the water pump and pulley possibilities. I would be interested to know the results of that.
[Re: Rhinodart]
#1719519
01/04/15 04:40 PM
01/04/15 04:40 PM
Posts: 3,053 Bowling Green, KY
cudaboy
Bowling Green, KY
I still have not read if you checked or replaced your cap...
Its in there. Changed twice.
Dennis
[Re: FASTBACK340]
#1719522
01/04/15 06:46 PM
01/04/15 06:46 PM
Posts: 4,924 new berlin wisconsin
Mr T2U
I am surprised no one mentioned weak fuel pump. if it cuts out at higher rpm's it can make it run lean. of course if it's lean at the top end it usually surges.
perception is 90% of reality
[Re: dem440c]
#1719524
01/04/15 08:16 PM
01/04/15 08:16 PM
Posts: 15,545 Omaha Ne
TJP
Omaha Ne
At this point I would 1. verify the timing 2. verify the pulley sizing 3. look at lean condition due to jetting or a vacuum leak. 4. pop a freeze plug
What intake / carb setup are you running ??
