Page 3 of 4 1 2 3 4
Re: tough one: overheating on the highway [Re: flypaper] #1719505
01/03/15 04:34 AM
01/03/15 04:34 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Are you running the stock electronic ignition? If so you may want to try a new box. I had a high speed overheating problem this summer. Kept chasing after dead ends. Well a friend told me he had the same issues before and he ended up changing the box. Solved the problem. Turns out the box was leaning out at high RPM. I changed mine, problem solved. When those Mopar boxes are new things run great but they go away things can haywire.
Re: tough one: overheating on the highway [Re: flypaper] #1719506
01/03/15 11:27 AM
01/03/15 11:27 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
a few thoughts i have is
what kind of water pump did you use?
some hi volume pumps will push the water way too fast thru
the radiator,not giving the water enough time in it to be able to cool down.
DO NOT listen to this type of "advice".
It is wrong and illustrates a completely ignorance of thermodynamics.
Don't be the exception.
Re: tough one: overheating on the highway [Re: smos001] #1719507
01/03/15 11:41 AM
01/03/15 11:41 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Might be leaning out as you press into the higher speeds. Does it miss at high cruise? faint lean miss? a lean miss also cause a slight hesitation as you press on the gas at a stop sign.
You may have to rejet the carb a little.
Vacuum leak?
Do not discount the 2 guys who suggested this. I third this suggestion.
Re: tough one: overheating on the highway [Re: Challenger 1] #1719508
01/03/15 04:45 PM
01/03/15 04:45 PM
Niwot, CO Formerly denn...
dynorad Offline
dynorad  Offline
I second the idea of using a IR thermometer to help you troubleshoot. Harbor Freight has them for not much money.
Re: tough one: overheating on the highway [Re: dynorad] #1719509
01/03/15 09:38 PM
01/03/15 09:38 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
Underhood airpressure might cause air to have hard time entering the enginebay at speed through the radiator.
I know you mentioned air flaps are presents but maybe a front airdam has been left out perhaps?
Specially since the car is fairly high overal with a lot of groundclearance causing turbulence under it.
Re: tough one: overheating on the highway [Re: flypaper] #1719510
01/03/15 10:05 PM
01/03/15 10:05 PM
Delaware
GeorgeH Offline
GeorgeH  Offline
Delaware
Had a old dodge van I had a similar issue on. Turned out the heat riser spring was weak and not opening up fully.
Re: tough one: overheating on the highway [Re: GeorgeH] #1719511
01/04/15 02:14 AM
01/04/15 02:14 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Pretty sure he mentioned he has headers
Re: tough one: overheating on the highway [Re: WO23Coronet] #1719512
01/04/15 02:28 AM
01/04/15 02:28 AM
Queens, N. Y.
FASTBACK340 Offline
FASTBACK340  Offline
Queens, N. Y.
I sure hope we find out what the cause is as the remedies are all over the map….
`68 Barracuda 340-S
Re: tough one: overheating on the highway [Re: FASTBACK340] #1719513
01/04/15 12:26 PM
01/04/15 12:26 PM
Youngsville, NC
dem440c Offline OP
dem440c  Offline OP
Youngsville, NC
holy moly you aren't kidding... you guys have a LOT of great ideas. A lot of them I have tried already and I've been taking notes on some things to try that I haven't done yet.
- full length headers, 2-1/2" duals through Flowmasters exiting in front of the axle. I'm pretty confident there is no exhaust restriction.
- gonna try the idea to remove the fan and see what happens. Only problem there is I have to drive 25 minutes to get to a highway, guess I'll bring tools and see what happens.
- I haven't mapped the timing yet to see exactly what the distributor is doing as the RPMs increase, I can do that. It runs perfect so I haven't been thinking in that direction but it wouldn't hurt to see what it is doing.
- pulling freeze plugs is gonna be a sucky job but I agree that the symptoms would line up with that cause so it should be explored. Man, that is gonna take me a whole freakin' weekend to pull all that apart and then get new plugs back in... sigh
- changing the ignition module is easy, I have a box full of them. I'll try that just because it is quick and easy.
- someone mentioned air baffles, I have all the ones in place that cover the gap between the core support and the radiator. What else should be there?
Re: tough one: overheating on the highway [Re: dem440c] #1719514
01/04/15 12:44 PM
01/04/15 12:44 PM
Queens, N. Y.
FASTBACK340 Offline
FASTBACK340  Offline
Queens, N. Y.
Might be easier to pull the water pump and use a bora-scope and peek in through the timing chain cover openings first. Freeze plugs are a chore on an educated guess.
`68 Barracuda 340-S
Re: tough one: overheating on the highway [Re: FASTBACK340] #1719515
01/04/15 02:02 PM
01/04/15 02:02 PM
that if you do not post the solution (when you find it) that there might be a cyberspace lynching . Recently a member lost his life cuz he DELETED his thread . On the timing, in your driveway just run it up to the same RPM you are at on the highway when it is getting hot & see what you get with your dialback or make some marks. 0.0632683" around the circumference is 1 degree on the dampener or can use the tab as a ruler. 2&1/4 (2.246") is 35.5 deg which should get you close to what you have tho the can will kick it higher above that
Re: tough one: overheating on the highway [Re: dem440c] #1719516
01/04/15 03:41 PM
01/04/15 03:41 PM
The Netherlands
The Netherlands
I don't know what came stock on your car as I don't have any experience with these models.
But if you're adventurous you could take a trip simply without the hood mounted and see if the issue remains.
Re: tough one: overheating on the highway [Re: RapidRobert] #1719517
01/04/15 03:49 PM
01/04/15 03:49 PM
Ottawa, ontario
dd340 Offline
dd340  Offline
Ottawa, ontario
This made me think of something, can you duplicate the overheating in 1st or 2nd gear if you hold it at the same rpm as you run at highway speeds? If the engine doesn't heat up in the lower gears this would seem to eliminate the water pump and pulley possibilities. I would be interested to know the results of that.
Re: tough one: overheating on the highway [Re: dd340] #1719518
01/04/15 04:08 PM
01/04/15 04:08 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I still have not read if you checked or replaced your cap...
JB Rhinehart, Realist
A-Body's RULE!
Re: tough one: overheating on the highway [Re: Rhinodart] #1719519
01/04/15 04:40 PM
01/04/15 04:40 PM
Bowling Green, KY
cudaboy Offline
cudaboy  Offline
Bowling Green, KY
Its in there. Changed twice.
Dennis
Re: tough one: overheating on the highway [Re: Supercuda] #1719520
01/04/15 05:07 PM
01/04/15 05:07 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
However "way too fast" condition can promote cavitation and/or hidden hot spots,
But then I am one of the "unlearned brethren" that thinks a well performing cooling system at highway speeds has little use for a fan.
Re: tough one: overheating on the highway [Re: RapidRobert] #1719521
01/04/15 05:55 PM
01/04/15 05:55 PM
Queens, N. Y.
FASTBACK340 Offline
FASTBACK340  Offline
Queens, N. Y.
Especially when the suggestions for repair run the entire spectrum of anything/everything that could possibly affect the cooling system.
Let's have some fun….. Lottery anyone?
`68 Barracuda 340-S
Re: tough one: overheating on the highway [Re: FASTBACK340] #1719522
01/04/15 06:46 PM
01/04/15 06:46 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
I am surprised no one mentioned weak fuel pump.
if it cuts out at higher rpm's it can make it run lean.
of course if it's lean at the top end it usually surges.
perception is 90% of reality
Re: tough one: overheating on the highway [Re: cudaboy] #1719523
01/04/15 06:53 PM
01/04/15 06:53 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Dennis
OK, didn't want to wade through the whole post again.
A-Body's RULE!
Re: tough one: overheating on the highway [Re: dem440c] #1719524
01/04/15 08:16 PM
01/04/15 08:16 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
At this point I would
1. verify the timing
2. verify the pulley sizing
3. look at lean condition due to jetting or a vacuum leak.
4. pop a freeze plug
What intake / carb setup are you running ??
Page 3 of 4 1 2 3 4
