Hughes rockers / stock VC's,'72 440 #1719429
01/01/15 05:19 PM
01/01/15 05:19 PM
Neenah,Wi
rod440 Offline OP
rod440  Offline OP
Neenah,Wi
Has anyone used Hughes 1.5 roller rockers with stock valve covers? I need to know if the adjusters will clear the baffles.It's a '72 440,w/.515 lift.Thanks! Rod
Re: Hughes rockers / stock VC's,'72 440 [Re: rod440] #1719430
01/01/15 05:25 PM
01/01/15 05:25 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I had these 1.6 Hughes roller tip rockers under the Chrome Eddy valve covers that are just a tad taller then stock. Ron
Re: Hughes rockers / stock VC's,'72 440 [Re: 383man] #1719431
01/01/15 05:28 PM
01/01/15 05:28 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
These are the Eddy covers I used as I painted them orange. They fit with no problem under them. Ron
Re: Hughes rockers / stock VC's,'72 440 [Re: 383man] #1719432
01/01/15 05:37 PM
01/01/15 05:37 PM
Neenah,Wi
rod440 Offline OP
rod440  Offline OP
Neenah,Wi
Ron,do the Eddies have the sheet metal baffles under the oil filler hole?
Re: Hughes rockers / stock VC's,'72 440 [Re: rod440] #1719433
01/01/15 05:40 PM
01/01/15 05:40 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Yes they have a baffle under the oil cap or PCV grommet hole. Not a real big baffle but it covers the hole area and a bit more. I still have them out in my garage as I went to different covers so if you need I can take a pic of the underside of them and show you the baffle ? Ron
Re: Hughes rockers / stock VC's,'72 440 [Re: 383man] #1719434
01/01/15 05:59 PM
01/01/15 05:59 PM
Neenah,Wi
rod440 Offline OP
rod440  Offline OP
Neenah,Wi
Thanks for the offer Ron.On my engine the adjusters just touch the baffles without a gasket,clear with a gasket,but I haven't started the engine yet so the hyd. lifters haven't pumped up yet,so I'm not sure if they will clear.
Re: Hughes rockers / stock VC's,'72 440 [Re: rod440] #1719435
01/01/15 06:07 PM
01/01/15 06:07 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
You know not thinking as my heads are the basic Indy EZ heads and I did not ask what heads you are using ? It may also make a difference. What heads are you using ? Ron
Re: Hughes rockers / stock VC's,'72 440 [Re: 383man] #1719436
01/01/15 06:30 PM
01/01/15 06:30 PM
Neenah,Wi
rod440 Offline OP
rod440  Offline OP
Neenah,Wi
440 Source.Now that I think about it,I also had to shim under the rocker shafts to get the pushrod angle right so that would make it that much closer.I finished & installed the engine 5 years ago & never started it.But because of my combination of parts I think I'll just have to figure it out.
Re: Hughes rockers / stock VC's,'72 440 [Re: rod440] #1719437
01/01/15 06:43 PM
01/01/15 06:43 PM
I know racers that use two sets of gaskets, one glue to the head and the other glue to the rocker cover so they can remove the covers without ripping or tearing the gaskets up. They use chassis grease as a lube between the two mating surfaces I've double gaskets in the past to gain cleanrces also, another way to get additional clearances is to either dimple where they hit the baffles with hammmer or use a small hloe saw to cut a hole where they hit Lots of different ways to skin the kitty : whistling:
