Taurus electric fans #171941
12/20/08 08:31 PM
12/20/08 08:31 PM
Bristol, Va
fasteddie Offline OP
Bristol, Va
I saw a post a while back that some were using these fans.
Is there a certain year or type of Taurus to look for?
4 cyl, V6?
Do they bolt right up?
Any rigging or fabricating involved?
Will any other brands work?
Fasteddie
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
Re: Taurus electric fans [Re: fasteddie] #171942
12/20/08 09:01 PM
12/20/08 09:01 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
Look up 98 V6 Taurus on E bay. you will find a ton for sell. I bought one with a life time warranty for around 125 shipped. Another one that is a good one is a fan off a HHR Chevy. ether one you get you are going to have to fab some mounting brackets etc for. mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: Taurus electric fans [Re: mopar65] #171943
12/20/08 09:09 PM
12/20/08 09:09 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I don't know what the Taurus fan draws as far as amps, but I checked out a PT Cruiser fan and it draws almost 40 amps, needs a "driver" & a circuit breaker. I found a 16" fan that moves 2500CFM on eBay, draws 17 amps IIRC. Gotta buy the seller's electrical kit separately, but I'm in the whole deal about $75. The fan's also reversible if you need it to push instead of pull. Seller is Skip White (White Performance).
Re: Taurus electric fans [Re: topside] #171944
12/20/08 09:17 PM
12/20/08 09:17 PM
mopar65 Offline
mopar65  Offline
I have read that the Taurus fan pulls around 4500 cfm and is a 2 speed fan. I don't r member how many amps it pulls off the top of my head. but i am thinking around 40-50 amps. there is a member on the board here that can get you a hhr fan and plug in cheep.I am going for the Taurus fan because my car is going to be a street strip car and don't think 2500 will be enough for me.thanks Mopar65
Re: Taurus electric fans [Re: mopar65] #171945
12/20/08 09:23 PM
12/20/08 09:23 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
You can get the HHR fan from member/moderator Eric.
Re: Taurus electric fans [Re: dartman366] #171946
12/20/08 11:09 PM
12/20/08 11:09 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
Mid 90's Ford Taurus 3.8 V6 is the fan to get. High CFM, Oem durability, and cheap at junkyards. I run mine on the high speed circiut wiht a SPAL PWM controller and a 40 amp fuse.
Re: Taurus electric fans [Re: Azzkikrcuda] #171947
12/20/08 11:16 PM
12/20/08 11:16 PM
mopar65 Offline
mopar65  Offline
Azzkikrcuda did you put any kind of foam to the edge of the fan so it would seal to the rad core or did you just bolt the fan to the rad as is? thanks Mopar65
Re: Taurus electric fans [Re: fasteddie] #171948
12/20/08 11:22 PM
12/20/08 11:22 PM
usa
hot67cuda Offline
hot67cuda  Offline
usa
They are the bestgreat amount of air,but u will need a good alt.and some minor fab skills i have mine in front of my rad.
Re: Taurus electric fans [Re: hot67cuda] #171949
12/21/08 01:10 AM
12/21/08 01:10 AM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
I run a mid-90's V6 Taurus one as well...flows big air and pulls lots of amps on startup. You better have a good alt...
Also, I run a maxi-fuse on it with a big relay and a temp control relay.
Re: Taurus electric fans [Re: Quicksilver440] #171950
12/22/08 04:29 PM
12/22/08 04:29 PM
Tampa, FL
tpabayflyer Offline
tpabayflyer  Offline
Tampa, FL
Yeah.. I got one from the junky and it works great. I tested in my battery to make sure it worked and it put out more thrust than a Piper Cub propeller ..... Unfortunately it was just a tad bit too deep to fit on my Cordoba so I ordered up an HHR fan. It arrived last week broke in about 5 pieces and it is getting pretty frustrating trying to get GMpartsdirect to replace it.... TBF
71 Challenger 528 Hemi project
09 Gr Cherokee 5.7 hemi in da house!!
Re: Taurus electric fans [Re: tpabayflyer] #171951
12/22/08 11:52 PM
12/22/08 11:52 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
TBF, I recieved my HHR in less then a week and in perfect condition. Yours took almost A month and its broken into five pieces. That sucks!, I hope you get that issue resolved with GMpartsdirect. mike
Post deleted by Defbob [Re: Sport440] #171952
12/23/08 10:03 AM
12/23/08 10:03 AM
Re: Taurus electric fans #171953
12/23/08 11:46 AM
12/23/08 11:46 AM
Odessa, Fl
blowndart Offline
blowndart  Offline
Odessa, Fl
What are the dimensions of the HHR fan? Any one have a pic?
Re: Taurus electric fans [Re: blowndart] #171954
12/23/08 12:44 PM
12/23/08 12:44 PM
Odessa, Tx.
cudarex Offline
cudarex  Offline
Odessa, Tx.
Fits a 22" rad. perfect.
This pic. curtousy of Goodys
Re: Taurus electric fans [Re: cudarex] #171955
12/23/08 10:09 PM
12/23/08 10:09 PM
Maine
itali83 Offline
itali83  Offline
Maine
How many CFM's and amps does the HHR fan pull? How much do they cost? Thanks!
'68 Roadrunner Built 440/727 4:10 filled 8 3/4 in the process of a ground up restification
Post deleted by Defbob [Re: itali83] #171956
12/23/08 11:19 PM
12/23/08 11:19 PM
Re: Taurus electric fans #171957
12/23/08 11:43 PM
12/23/08 11:43 PM
Newfoundland
codfish Offline
codfish  Offline
Newfoundland
Don't know the exact CFM but they move a ton of air.....I believe someone checked and said 18 amps at start-up....about $80 shipped with a factory connector.
Eric do you have a part number? You still selling them?
I have a 16" Zirgo that I want to replace.
thanks and merry christmas
codfish
EDIT
Does that thickness of 3.875", include the shroud? And is the shroud included?
thx
Re: Taurus electric fans [Re: codfish] #171958
12/24/08 12:24 AM
12/24/08 12:24 AM
Renton Washington
Triple Threat Offline
Renton Washington
I have the HHR Fan on my radiator as well.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Taurus electric fans [Re: Triple Threat] #171959
12/24/08 08:41 PM
12/24/08 08:41 PM
Newfoundland
codfish Offline
codfish  Offline
Newfoundland
codfish
Re: Taurus electric fans [Re: codfish] #171960
12/24/08 08:57 PM
12/24/08 08:57 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
codfish
Yes that 3.875 dimension includes the shroud, and yes it comes all in one molded piece .
GM
part# 15817306 Fan
part# 12101917 Connector spord.
mike
