Re: ProCharger F3?
[Re: BulletBob]
#1718904
01/01/15 12:59 PM
01/01/15 12:59 PM
Posts: 1,238 North Cackilacky
sdaurity
North Cackilacky
First thing you would need to know is what size F3 units they are. Making 60lbs I assume it would be a 139 or a newer 136. Are they geardrive or belt?
One day I will have something cool here.
Re: ProCharger F3?
[Re: BulletBob]
#1718905
01/01/15 01:15 PM
01/01/15 01:15 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I passed on a F1 a few years ago.. was very cheap and I would have had to build the mounting plate.. I'm sorry I did.. but I didnt have the money
Re: ProCharger F3?
[Re: MR_P_BODY]
#1718906
01/01/15 01:24 PM
01/01/15 01:24 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
If you only want to run bottom 9's you sure won't have to spin it hard but will need a stout engine. 30lbs of boost on my f2 gets me bottom 7's @3300lbs.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: ProCharger F3?
[Re: bigtimeauto]
#1718909
01/01/15 02:40 PM
01/01/15 02:40 PM
Posts: 4,070 Mo.
racerx
Mo.
Bottom 7's that's what i'm talking bout.
Re: ProCharger F3?
[Re: 80arrow]
#1718914
01/03/15 05:32 AM
01/03/15 05:32 AM
Quicktree
whats the total cost of an F2 setup for a small block?
A lot
send me a pm since no one else knows that thing still running?
Re: ProCharger F3?
[Re: Quicktree]
#1718915
01/03/15 06:19 AM
01/03/15 06:19 AM
Posts: 733 jacksonville,FLORIDA
slammedR/T
I like the way you thinking
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
Re: ProCharger F3?
[Re: slammedR/T]
#1718916
01/03/15 03:23 PM
01/03/15 03:23 PM
Posts: 778 Sherwood park, Alberta.
go green
Steve Morris has a SBC kit for $6000 you might get him to modify it but that will cost $$&$ also . Charge tube and v-bands can start at $500 and go to $2000 depending on how many clamps and if you have a inter cooler ( air - water will set you back $2000 for the box , water tank ,pump and hose ) If you go with a carburetor is a minimum of $1300 for car and hat for a good one is way over $2000 working . If you want to go EFI look at around $3500- $10,000 . Your are looking at a minimum of $9000 and for the good stuff, around $17,000 to $20,000 . For a carb fuel delivery you will need some sort of data logging system so add a extra $1000 -$2000+ for that . Along with a good converter $1200-$2800 You have to make sure your transmition is good so throw away your 727 and put a t-400 or glide in $$$$ . Rear end and drive shaft $$$ . And so on . There are some thrifty MF's out there that will barnyard their builds and say it will cost 1/2 but they are easy to spot a mile away . If you want to put on a power adder just to cruise around a act cool then so be it ,there are plenty of shops that will sell shiney parts .
Re: ProCharger F3?
[Re: go green]
#1718917
01/03/15 08:00 PM
01/03/15 08:00 PM
Quicktree
