12v key on and crank under dash on 70 b body? #1718344
12/31/14 03:30 AM
12/31/14 03:30 AM
sandwich IL
sublimehemi Offline OP
sandwich IL
Well I tested and tried the fuse box but no luck there. is a 12 volt key on while cranking wire under dash?.... need this for my efi....i know where I can get in engine compartment... but looking for something under dash any help would be appreciated.... ty moparts
70 charger ,all aluminum 528 hemi 727 cope rmvb,680hp 670 tq,full sequential holley hp efi,full hotchkis tvs,qa1 k and lowers,borgeson steering box cass viper 11.75 with cass s-trac dana 3.54
Re: 12v key on and crank under dash on 70 b body? [Re: sublimehemi] #1718345
12/31/14 03:44 AM
12/31/14 03:44 AM
You have the "ST" terminal on the ign sw that goes out to the yellow wire on the "ST" terminal on the starter relay to energize the starter and you have the "ign2" "crank" terminal on the ign sw which goes out to the downstream end of the ballast resistor (which bypasses the ballast) for full 12V to the coil while cranking. This is the brown wire circuit. www.mymopar.com will have the colors for a '70 B body
