K&N substacks... #1718205
12/30/14 11:34 PM
12/30/14 11:34 PM
Melbourne.....Oz-land
Moparmal Offline OP
Moparmal  Offline OP
Anyone tried these?
results? What carbs and application eg fresh air or sealed scoop etc.....?
67 RO23 clone with 6.1 SRT Hemi and dual quads. Soon to have Drag Pak induction and Throttle body.
Re: K&N substacks... [Re: Moparmal] #1718206
12/30/14 11:39 PM
12/30/14 11:39 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I tried the version that fits over the standard Holley 4150 main body that still has a choke tower (NOT milled down).
Did it make a difference? You bet... caused a bog right off the line that went away as soon as I pulled it back off.
I didn't have the patience to go through a whole 'nother tuning routine simply because the stub-stack changed something so significantly.
Re: K&N substacks... [Re: BradH] #1718207
12/30/14 11:44 PM
12/30/14 11:44 PM
Moparmal Offline OP
Moparmal  Offline OP
If it did that to a Holley....I hate to think how an AFB would behave!
Re: K&N substacks... [Re: Moparmal] #1718208
12/30/14 11:49 PM
12/30/14 11:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I run a stack thats mounted to the bottom of my scoop
pan...thats on a 1050 dom.. its been on there a long
time.. it smooths out the air due to the radius...
if you looked at the air filter on race car thread you
can see what that radius does
Re: K&N substacks... [Re: MR_P_BODY] #1718209
12/31/14 12:03 AM
12/31/14 12:03 AM
Locomotion Offline
Locomotion  Offline
It increases airflow so it leans out your carb set up. If it bogs and/or runs slower, you were close to optimum or a little on the lean side. If the car picks up, you were on the rich side without it. If I remember correctly, at least a couple of jet sizes richer helped me when I installed one on my bracket car. One size bigger squirters may also be helpful.
Re: K&N substacks... [Re: Locomotion] #1718210
12/31/14 12:15 AM
12/31/14 12:15 AM
Rescue CA.
joes68340s Offline
joes68340s  Offline
Rescue CA.
I have had one sitting in my garage for years and never tried it. I thought they were placebos and never gave it a chance.
Re: K&N substacks... [Re: Moparmal] #1718211
12/31/14 12:22 AM
12/31/14 12:22 AM
AndyF Offline
AndyF  Offline
I did some dyno testing with a stubstack on an AFB carb years ago. The stubstack messed up the carb metering so bad we couldn't figure out how to fix it. Ended up just throwing the stubstack away.
Re: K&N substacks... [Re: AndyF] #1718212
12/31/14 03:05 AM
12/31/14 03:05 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Bought one used on here years ago and it to screwed up the signal and it lost power............
Re: K&N substacks... [Re: Thumperdart] #1718213
12/31/14 03:35 AM
12/31/14 03:35 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Not to wander off too far but what's the consensus with removing the choke plate? Will the small holes in the choke tower where the choke shaft went through cause turbulence?
Re: K&N substacks... [Re: Moparmal] #1718214
12/31/14 04:25 AM
12/31/14 04:25 AM
Moparmal Offline OP
Moparmal  Offline OP
Thanks for the input.
Its interesting that these dont seem to work...but the factory used air bells on the race Hemi motors....
Re: K&N substacks... [Re: Moparmal] #1718215
12/31/14 01:29 PM
12/31/14 01:29 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
The bell`s have a generous taper to em the stub stack has an abrupt 1" wall to go over before it enters the carb.
Re: K&N substacks... [Re: Thumperdart] #1718216
01/01/15 07:34 AM
01/01/15 07:34 AM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
I've been very happy with mine. Use it on 4150 and 4160 Holleys. Improved the performance wherever I have used them, but then again, I've been likely running rich before installation, so the additional smoothed out airflow seems a benefit, at least to an unmodified, intact choke carb.
Re: K&N substacks... [Re: D_C] #1718217
01/01/15 12:35 PM
01/01/15 12:35 PM
Earth
Rob C Offline
Rob C  Offline
Earth
It seems to be a bit and miss with these things.
Re: K&N substacks... [Re: Moparmal] #1718218
01/01/15 12:57 PM
01/01/15 12:57 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I have one that I use to hold the Moroso air pan on the carb.I dont remember if it helped or not,it's been on over 20 years.
Nautilus Racing-
Re: K&N substacks... [Re: Chris2581] #1718219
01/01/15 01:32 PM
01/01/15 01:32 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
The style that works on a milled choke horn 750 4150 Holley has been good for a .03 gain on 2 cars. But a HP main body is better
"Just a Bracket car dressed up like a streetcar"
Re: K&N substacks... [Re: Just-a-dart] #1718220
01/01/15 01:41 PM
01/01/15 01:41 PM
MR_P_BODY Offline
MR_P_BODY  Offline
This is the style I use... its mounted to the bottom
of my scoop and sits on the carb so the scoop is sealed...
I know they work for what they are suppose
to do(smooth out the air) because I had to use one
on all the carbs and filters that I flowed... with and
without you could see the difference.. its been on
the car since day one when I built it
Re: K&N substacks... [Re: Locomotion] #1718221
01/01/15 02:35 PM
01/01/15 02:35 PM
BradH Offline
BradH  Offline
No doubt my 850 would have appreciated my taking the time to re-tune it for the stubstack. However, at the time I was like "WTH?" when I did the A-B-A test vs. w/o it and decided it wasn't worth the trouble.
Re: K&N substacks... [Re: BradH] #1718222
01/01/15 06:44 PM
01/01/15 06:44 PM
AndyF Offline
AndyF  Offline
You might not have been able to find a quick fix. I had a chat with one of the dyno engineers at Edelbrock a few years ago about the stubstacks and he said that they can really distort the metering system. Evidently the signal across the air bleeds gets disturbed enough that the carb can't properly meter the fuel. I think a person would need to run one on a dyno with a smoke wand to see what is happening.
