Re: Torsion Bar Removal [Re: johnscudashop] #1718099
01/02/15 06:05 PM
01/02/15 06:05 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
I been Making and selling these for years,with a 30 day replacement warranty. Knurled handle 1"X 1" solid steel striking surface .
I have one, it's slicker than snot.
Re: Torsion Bar Removal [Re: dart4forte] #1718100
01/02/15 08:42 PM
01/02/15 08:42 PM
BDW Offline
BDW  Offline
I've heard a gooseneck from a BMX bike works, should be easy to find and cheap.
Re: Torsion Bar Removal [Re: BDW] #1718101
01/02/15 09:53 PM
01/02/15 09:53 PM
NY NY
3
340duster340 Offline
NY NY
i have had good success with unbolting the LCA pin, strut rod and lower ball joint and whacking the LCA with a dead blow, or when i had a lift, the same + prying with a 2x4 pushing the LCA and t-bar rearward.
the tool that clamps to the t-bar is the quickest though,
Re: Torsion Bar Removal [Re: Big Bad Bee] #1718102
01/02/15 11:02 PM
01/02/15 11:02 PM
Toronto, Ontario, Canada
plazomat Offline
plazomat  Offline
If the bars are junk....I cut it in two just before the LCA. Then air hammer from the back side of bar pushing it out the front side. I hammered on it for hours til Igave up on saving the bar and went this way.
It was out in 5 mins with clean up....
Re: Torsion Bar Removal [Re: Big Bad Bee] #1718103
01/03/15 12:58 PM
01/03/15 12:58 PM
Central Oregon
Rodney Offline
Rodney  Offline
Central Oregon
this is the tool I made out of some metal I had laying around. it works great and really takes a beating.
Re: Torsion Bar Removal [Re: DaveRS23] #1718104
01/03/15 01:35 PM
01/03/15 01:35 PM
BDW Offline
BDW  Offline
I've always just used a couple of 1" rope clamps. Doesn't hurt the bars and gives a good surface for the hammer.
Tried looking for this, didn't see much, and what I did, couldn't see where you'd have some surface area to hit it?
Got a link?
Here's a pic of a bike gooseneck that might work.
http://farm7.static.flickr.com/6194/6103662644_8b02a71d81_m.jpg
Re: Torsion Bar Removal [Re: BDW] #1718105
01/03/15 06:19 PM
01/03/15 06:19 PM
NJ, USA
bill440rt Offline
bill440rt  Offline
NJ, USA
I made this out of some junk laying around in the garage.
Worked like a charm.
Re: Torsion Bar Removal [Re: bill440rt] #1718106
01/03/15 06:26 PM
01/03/15 06:26 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Simple and effective. Nice
Re: Torsion Bar Removal [Re: RobX4406] #1718107
01/03/15 06:56 PM
01/03/15 06:56 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
And I'm lucky enough to have the real thing which I never use anymore.
Re: Torsion Bar Removal [Re: BDW] #1718108
01/03/15 09:40 PM
01/03/15 09:40 PM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
http://static.grainger.com/rp/s/is/image/Grainger/4DV33_AS01?$zmmain$
$10 or so from Grainger. There is not a lot of hammering area, but they have always worked for me. Heck, I beat on the nuts as much as the clamps base. Doesn't seem to hurt them none. The pair I have are probably 40 years old and have pulled a good dozen sets of bars.
As mentioned above, I loosen the lower control arm nut and pry the the lower control arm back and whack the clamps.
Although it is probably not necessary, I clamp 2 clamps back to back against each other for more clamping force. One would likely be enough for most bars.
Master, again and still
