timing problem in 96 5.2 #1717783
12/30/14 09:48 AM
12/30/14 09:48 AM
Tennessee usa
8
88 ragin ram Offline OP
Tennessee usa
I had a coolent leak in timing cover and when i went to fix it I found bad timing chain... so I replace the chain set and put it back together, it started up just fine like new ran for about 10 minutes and when i gave it a little gas it just puttered out and wont start back up. cranks fine just won't start. could one of the key ways have come out or????
Re: timing problem in 96 5.2 [Re: 88 ragin ram] #1717784
12/30/14 01:44 PM
12/30/14 01:44 PM
See if you have spark: hold the coil wire (dist end) 1/4" from ground while someone cranks it with the key. To ans your Q, you might pull the plugs & do a compression test in any hole real quick & see if you have a normal reading
Re: timing problem in 96 5.2 [Re: RapidRobert] #1717785
12/30/14 02:17 PM
12/30/14 02:17 PM
Tennessee usa
8
Tennessee usa
if I got spark whats next?, I just put a new coil on it a couple of weeks before the leak started, and it was working fine. I only replaced it because of not running strong, but that was the timing chain that was causing that ( which is in time ).
Re: timing problem in 96 5.2 [Re: 88 ragin ram] #1717786
12/30/14 03:26 PM
12/30/14 03:26 PM
Pacifica, CA
Devilbrad Offline
Devilbrad  Offline
Pacifica, CA
What timing set did you use? I had a Comp Cams set that had the cam mark two teeth off, same thing happened with my Magnum engine. Need to degree that cam in.
Re: timing problem in 96 5.2 [Re: Devilbrad] #1717787
12/30/14 03:40 PM
12/30/14 03:40 PM
Tennessee usa
8
Tennessee usa
stock timing set
