Page 3 of 4 1 2 3 4
Re: Finally my 544 stroker 6 pak, can't wait ..... *DELETED* [Re: meepmeep70] #1717392
01/02/15 12:54 PM
01/02/15 12:54 PM
weymouth,mass.
meepmeep70 Offline OP
weymouth,mass.
Post deleted by meepmeep70
Re: Finally my 544 stroker 6 pak, can't wait ..... [Re: sixpackgut] #1717393
01/02/15 02:44 PM
01/02/15 02:44 PM
Jamie McGrath Offline
I remember reading sometime back about someone doing a 500cfm center carb conversion on there 6BBL. I think it was a Ford 2BBL carb from a circle track engine using Chrysler 2300 shaft and linkage. The airhorn/choke tower was milled down and so was the carbs base where the air cleaner sits so the 6bbl base could be used.
I've been looking for it for sometime and I can't find it I guess my search kungfu is weak..
I did it
Yours looks like all 3 carbs are done, the write up I read was just the center carb (500) with the vac outboards, I cant remember if they used the Ed intake or Weiand's IR tunnel ram...
There is a cool youtube vid, they seem too have the carbs dialed pretty smooth, posted by 4406Chally.
www.youtube.com/watch?v=zJW5bwmuSmo
Re: Finally my 544 stroker 6 pak, can't wait ..... [Re: Jamie McGrath] #1717394
01/02/15 03:02 PM
01/02/15 03:02 PM
Stow ,Ohio
demon440 Offline
demon440  Offline
Stow ,Ohio
Is that a stock block?
If so how and why so many cubes?
I thought the largest a stock block
would go was 526c.i.d. ?
Re: Finally my 544 stroker 6 pak, can't wait ..... [Re: demon440] #1717395
01/02/15 05:35 PM
01/02/15 05:35 PM
Las Vegas NV
moparmanjames Offline
Las Vegas NV
You can go 540 with some extra grinding
Re: Finally my 544 stroker 6 pak, can't wait ..... [Re: Jamie McGrath] #1717396
01/02/15 09:06 PM
01/02/15 09:06 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
I did it
PPM builds the engines for the old Paul Rossi super stock six pack challenger. That is their own intake after spending 10,000 dollars on intakes made by hogans and others that wouldnt get down the track. The 4412 ( i think) holley 500 has a boss in the same spot where the vaccum port needs to be for the outboards. Yes, my set up ended up being 3 mechanical carbs.
Re: Finally my 544 stroker 6 pak, can't wait ..... [Re: moparmanjames] #1717397
01/02/15 11:40 PM
01/02/15 11:40 PM
NC
440Jim Offline
440Jim  Offline
NC
I have seen several people with 540 CID (4.5" Stroke) in an RB block.
Re: Finally my 544 stroker 6 pak, can't wait ..... [Re: Mr.Yuck] #1717398
01/02/15 11:47 PM
01/02/15 11:47 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I wouldn't be surprised if you don't see a number close to 600 when you're all done.
So after the dyno session are you saying the tuner left about 40hp on the table ?
Re: Finally my 544 stroker 6 pak, can't wait ..... [Re: Jamie McGrath] #1717399
01/03/15 08:45 AM
01/03/15 08:45 AM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
I did it
i run a 500cfm center carb also. works real well and definitely adds a little kick in the pants.
I see you are, just when I thought I was going nuts... I can't find the article too save my life, it was a pretty in-depth write up. How much more punch does it have with the larger center carb?
its quite noticeable, even more so when your just driving around off the center 2 barrel. never done a back to back at the track, probably should try it sometime.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: Finally my 544 stroker 6 pak, can't wait ..... [Re: meepmeep70] #1717400
01/03/15 12:37 PM
01/03/15 12:37 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
http://youtu.be/Vd1OA2l4bk8
another dyno look
I'm NOT an expert, but the carbs seem to need some adjustment. they hesitate and spit before revving. Also he only took the motor to 6k. As I mentioned that thing should be making power well above 6k. Does he have an A/F meter on it? Did he monkey w/ the jetting/springs/squirters?
Re: Finally my 544 stroker 6 pak, can't wait ..... [Re: JohnRR] #1717401
01/03/15 12:40 PM
01/03/15 12:40 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
he sent me his dyno sheet, and after looking and listening to the video it seems the engine hasn't been tuned for best numbers. It makes peak H at like 5400rpm. It falls off well after that. I would think there would be more in it.
Re: Finally my 544 stroker 6 pak, can't wait ..... [Re: Mr.Yuck] #1717402
01/03/15 01:59 PM
01/03/15 01:59 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I agree that the Dyno session was a little scarey with the motor jumping around like that at low RPM, the outboards were opening way to slow ... I hope the head gaskets survived that shock ... and there may be a LITTLE more in it but you are not realizing 3 things, it's a 4.5" stroke, the heads are too small for the cubes, and it's a HYDRAULIC roller cam, it's not going to be happy revving to the moon.
When I originally talked to Darren about those heads he was putting them on his 440, that grew to a 493 when he pulled the trigger to buy them and they would have been fine on that, now add another 50 cubes, things change ...
We had the Engine masters engine on the dyno and found another 30HP, but half of it came from changing the malfunctioning carb.
Re: Finally my 544 stroker 6 pak, can't wait ..... [Re: Mr.Yuck] #1717403
01/03/15 06:03 PM
01/03/15 06:03 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
True John, it does need some tuning for sure.
Re: Finally my 544 stroker 6 pak, can't wait ..... [Re: JohnRR] #1717404
01/03/15 08:31 PM
01/03/15 08:31 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I don't know if I would blame it on the tuner, but that last vid didn't sound real good. The buck of the engine seemed like a backfire into the intake. Even under power it didn't sound like it was running smoothly. Sounded like it was still having some mini backfires trying to occur in the intake.
I wouldn't be doing any high fives from that Dyno run. Id be saying, what the Hay.
If its running as bad as it sounds to me, there could be 40 HP left on the table. Its not running right IMO
Re: Finally my 544 stroker 6 pak, can't wait ..... [Re: meepmeep70] #1717405
01/03/15 08:50 PM
01/03/15 08:50 PM
another dyno look
I would have probally pulled the throttle back to abort that pull with all the banging, kicking and misfiring it was doing Have those issues been resolved yet? If not they really need to be Before the crank falls out onto the ground in the car Detonation kills stock 440 block main webbing If you make anymore dyno pulls and IF that FAST AFR system is hooked up and working make sure to ask the dyno operator to push the record feature before starting the next pull Those readings can be a really big help in getting a handle on what is going on
Re: Finally my 544 stroker 6 pak, can't wait ..... [Re: Cab_Burge] #1717406
01/03/15 10:52 PM
01/03/15 10:52 PM
I'm just thinking out loud here, asking the sixpack intake too feed 440ci has worked well in the past, but does it have enough air flow too feed 540 cubes? seems too me the runners would be pretty small. I know there was complaint years ago about core shift with the molds.
Question 2, the slight stumble before the outboards pop open could this be reversion in the intake? The engine wants too pull but its sucking threw a straw as the rev's build the outboards kick in and the air velocity looses momentum before it picks back up again? So with that thought it seems too want air would a larger center carb get it over the hump before the outboards kicked in or would this just move the stumble higher up in the rpm range?
#3 The jetting seems pretty close too the bone at 540ci, I would think it would like some more meat too eat on.
Re: Finally my 544 stroker 6 pak, can't wait ..... [Re: Jamie McGrath] #1717407
01/04/15 03:16 AM
01/04/15 03:16 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I didn't mean to take this thread in the direction it has gone, there may be a few more ponies in it but the real test is once it's in the car and running.
I haven't seen the dyno sheets but I assume the AFR was close to being correct or it wouldn't have come off the dyno.
Re: Finally my 544 stroker 6 pak, can't wait ..... [Re: JohnRR] #1717408
01/04/15 01:23 PM
01/04/15 01:23 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Its easy to grind a softball size amount of aluminum out of a sixpack intake on just a gasket match. They are awful
Re: Finally my 544 stroker 6 pak, can't wait ..... [Re: Cab_Burge] #1717409
01/04/15 04:22 PM
01/04/15 04:22 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
another dyno look
Sorry to rain on your parade meep, but man...WHAT dyno operator keeps the hammer down after that first "hiccup"????????? I'd sure want to find the problem/fix it BEFORE I'd whack the throttle in the car.
x2 on the use and reading an AFR meter.
Wow...
Re: Finally my 544 stroker 6 pak, can't wait ..... [Re: sixpackgut] #1717410
01/04/15 04:45 PM
01/04/15 04:45 PM
Connecticut
5126brl No more Offline
Connecticut
Doing mine right now, looks like runners #7 and #1 need a lot of work. cleaned up roof radius and sides wall where there was a big overhang from casting bottom and tops meet.
Any thoughts on what works best?
Re: Finally my 544 stroker 6 pak, can't wait ..... [Re: 5126brl No more] #1717411
01/04/15 11:35 PM
01/04/15 11:35 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
now I know why my buddy asked me "are you going to work the intake before you put it on?" are they really that bad? How much more can you pick up? Mine is right out of the box.
Page 3 of 4 1 2 3 4
