360 ENGINE NEW BUILD WILL NOT START #1717278
12/29/14 12:11 PM
12/29/14 12:11 PM
SO ILL
K
KISSFANN1 Offline OP
K
SO ILL
Let me start by stating that I知 a good mechanic, but this is my first V-8 engine build.
Following the instructions from my Chilton痴 manual, I have rebuilt a 360 engine in my 78 Power Wagon.
It will not start. It spits, sputters, and backfires.
I知 99% sure I assemble the timing chain to the cam and crank with the #1 piston @ TDC.
The coil and ignition resistor checks out as OK.
I stuffed some tissue in the #1 spark plug hole. Once it popped out, the distributor rotor is pointing to the #1 spark plug wire on the cap.
I知 picking up today a compression gauge to check each cylinder.
What am I missing?
I would appreciate any suggestions that will help me through this struggle.
Thanks,
SLD
Re: 360 ENGINE NEW BUILD WILL NOT START [Re: KISSFANN1] #1717279
12/29/14 12:16 PM
12/29/14 12:16 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
If the distrib is 180 degrees out of time, it could be as it has stumped many, simply loosen/remove hold down clamp, lift distrib and turn rotor 1/2 turn then drop it back in and try it.
Re: 360 ENGINE NEW BUILD WILL NOT START [Re: buildanother] #1717280
12/29/14 12:32 PM
12/29/14 12:32 PM
SO ILL
K
K
SO ILL
I did try that.
It did not help.
Thanks,
SLD
Re: 360 ENGINE NEW BUILD WILL NOT START [Re: KISSFANN1] #1717281
12/29/14 01:34 PM
12/29/14 01:34 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
What am I missing?
Thanks,
SLD
On the no. 1 cylinder, did you pull the valve cover to make sure both valves for that cylinder were fully closed?
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: 360 ENGINE NEW BUILD WILL NOT START [Re: DusterDave] #1717282
12/29/14 01:43 PM
12/29/14 01:43 PM
SO ILL
K
K
SO ILL
Yes I did.
The timing allignment has been based off that finding.
After reading other forums, I cannot remember where I alligned the dots on the gears. Cam could have been at 6 or 12 o'clock.
I will have to remove cover and verify.
Some others refer that the distributor shaft could be alligned with the #6 cylinder.
Re: 360 ENGINE NEW BUILD WILL NOT START [Re: KISSFANN1] #1717283
12/29/14 02:53 PM
12/29/14 02:53 PM
It's beer:30 somewhere
adventurer Offline
adventurer  Offline
With the cam at 6 o'clock and crank at 12 it is at #6 TDC not 1 #1 that has confused many an engine builder. 1-8-4-3-6-5-7-2 clock wise rotation
77 Dodge Adventurer SE 440 2wd SWB
78 Dodge Adventurer SE 440 2wd Utiline
90 Dodge D150 SWB 2wd 318fi 4speed
60 Desoto Adventurer 2dr
67 Dodge Dart Gt Conv. 273 4bbl
04 PT Cruiser GT Turbo
14 Ram R/T
"Life's to short to drink cheap beer."
Re: 360 ENGINE NEW BUILD WILL NOT START [Re: adventurer] #1717284
12/29/14 02:59 PM
12/29/14 02:59 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Sounds timing related. Did you confirm tdcin relation to the balancer at all? If the rotor isn't 180 out, then maybe your timing is off by a bunch due to a slipped balancer?
**Photobucket sucks**
Re: 360 ENGINE NEW BUILD WILL NOT START [Re: 70Cuda383] #1717285
12/29/14 06:15 PM
12/29/14 06:15 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
The firing order for Mopar Big Blocks and Small Blocks (Chevys, too) is the same, BUT the rotation of the distributor is different between the two. Did you wire it like a Big Block???????????
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: 360 ENGINE NEW BUILD WILL NOT START [Re: adventurer] #1717286
12/29/14 07:43 PM
12/29/14 07:43 PM
adventurer Offline
adventurer  Offline
One other thought that I have seen happen from time to time on people building engines. Soaking and pumping up the lifters to where they will hold the valves open. I have seen this many times on brand x stuff but not so much Mopar. The lifters need to have oil on them but not be pumped up solid. When you tighten down the rockers if the lifters are pumped up it will hold the valves open. A compression test will show this. Hope that helps
14 Ram R/T
Re: 360 ENGINE NEW BUILD WILL NOT START [Re: 70Cuda383] #1717287
12/29/14 08:30 PM
12/29/14 08:30 PM
West Palm Beach, Florida
Copper Dart Offline
Copper Dart  Offline
I like this answer.
Or maybe...
Possibly early/late timing cover/balancer?
Just to say I pitched in.
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: 360 ENGINE NEW BUILD WILL NOT START [Re: Polarapete] #1717288
12/30/14 01:33 AM
12/30/14 01:33 AM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Thats what I was going to suggest
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: 360 ENGINE NEW BUILD WILL NOT START [Re: W.I.N. Racing] #1717289
12/30/14 11:10 AM
12/30/14 11:10 AM
SO ILL
K
K
SO ILL
Thanks you everyone for your responses.
This is all good quality input.
I will be able to try some of these suggestions tomorrow.
I will update everyone on my findings.
Thanks,
SLD
Re: 360 ENGINE NEW BUILD WILL NOT START [Re: KISSFANN1] #1717290
12/30/14 12:37 PM
12/30/14 12:37 PM
Lehigh Acres, Florida
rickstershemi Offline
If this is a new rebuild with fresh cam and lifters....I highly suggest you find someone with the knowledge to set it up correctly before you attempt to start it again so you don't end up wiping out a cam lobe....it should fire instantly and then run at 2k rpm for about 20 minutes
Rickster
Re: 360 ENGINE NEW BUILD WILL NOT START [Re: KISSFANN1] #1717291
12/30/14 06:30 PM
12/30/14 06:30 PM
Nevada
dezduster Offline
dezduster  Offline
Nevada
Ill go out on a limb and ask, what timing set did you use? The edelbrock timing chain if that's what you used is confusing. I had installed it incorrectly until I dialed the cam in and nothing came up correctly. Couple other people in our small town did the same thing but they just dot to dotted it. It would run but needed excessive spark lead made no power once it was broken in.
Next thought is no power at coil while cranking but when you let off crank cycle it hits and dies. I believe this is ignition switch problem but may also be wiring related.
Re: 360 ENGINE NEW BUILD WILL NOT START [Re: dezduster] #1717292
12/31/14 09:42 PM
12/31/14 09:42 PM
SO ILL
K
K
SO ILL
Let me start by saying, thanks to everyone's help.
I decided to get back into the gear set to verify the dot lineup.
Guess what, I did not have the rotation set correctly.
There were so many marks on the crank gear, I used the wrong one.
I set everything to the way it was supposed to be.
Cranked it and had plenty of backfire.
Rotated the distributor 180 and it fired off immediately.
It sounded great!!!
Tomorrow it will button up the fluids and break in the cam.
I will keep you all updated on the build.
SLD
Re: 360 ENGINE NEW BUILD WILL NOT START [Re: KISSFANN1] #1717293
01/01/15 02:09 AM
01/01/15 02:09 AM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
It sounded great!!!
SLD
That's great that you corrected the issues, but, I'm concerned that all of the cranking has wiped off the break-in lube on your cam lobes. I'm assuming you have a flat tappet cam.
