Overcharging issue? -UPDATE #1717027
12/28/14 06:38 PM
12/28/14 06:38 PM
The Historic Hudson Valley
MONC Offline OP
MONC  Offline OP
Took the Charger out for a short drive ( bout 10 miles round trip ) and noticed on the way home the ammeter was jumping a little ( positive). Didn't think too much of it as I hadn't driven the car for a while and figured the battery needed charging.
Took the car out for a longer drive ( about 30 miles mostly highway) and on the way up the ammeter read +20 the whole way up.
On the way back it was still around +20 then about 15 or 20 miles in started to go higher about +40 (almost pegged).
The car ran fine but concerned about overcharging.
Today I started the car and after warm up and the car idling the ammeter read just slightly positive ( normal ).
I checked the voltage at the battery before starting it was about 12.75V . While idling the battery voltage was 17.50 - 17.62 volts ( seems high to me ) .
I checked the voltage at the regulator at idle and it was 6.8-7.5 volts.
I checked the alternator at idle and it was about 7.8- 8.2 volts
I checked the ground to the voltage regulator ( using the bracket holding the regulator as one side and an open hole in the radiator support on the other side with the ohmmeter ) and got a good connection.
The car runs with a Petronix electronic ignition system, does this effect the type of voltage regulator I need for an otherwise stock 69 set up?
I've seen solid state replacement voltage regulators for sale, but not sure what's in the stock 69 regulator.
Thoughts?
Overcharging or not?
TIA
Re: Overcharging issue? [Re: MONC] #1717028
12/28/14 06:50 PM
12/28/14 06:50 PM
DO NOT run it anymore (not even 10 seconds) till you swap the reg. I'm assuming you have an OE type electromechanical type reg? Your parts house has a Wells VR 706 (iirc) electronic replacemnt reg (does not look identical to OE) and mrrandyj at aol dot com has an electronic version with an black cover that does look identical to the OE electromechanical ones for $29 to your door. Reportedly you can swap your current cover to an electronic parts house replacement reg but I ain't sure which one that is.
Re: Overcharging issue? [Re: RapidRobert] #1717029
12/28/14 06:54 PM
12/28/14 06:54 PM
MONC Offline OP
MONC  Offline OP
Thanks for the reply Robert.
This is the VR I saw on Ebay Motors - is this the type I should get :
http://www.ebay.com/itm/Dodge-Charger-Ch...0ce&vxp=mtr
Re: Overcharging issue? [Re: MONC] #1717030
12/28/14 07:04 PM
12/28/14 07:04 PM
Yes! dirt cheap/no tax/free shipping/USA made/good seller/expedited shipping. that's as good as it gets
Re: Overcharging issue? [Re: MONC] #1717031
12/28/14 07:22 PM
12/28/14 07:22 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Once your sure you have your charging straight I have a Reproduction cover with Red writing I would sell if you need.
Ron
Re: Overcharging issue? [Re: RapidRobert] #1717032
12/28/14 07:22 PM
12/28/14 07:22 PM
MONC Offline OP
MONC  Offline OP
Ok thanks .
So are those readings not right?
Was thinking that VR and battery should be about same , but is Ammeter reading the voltage being created at the battery or from voltage regulator or where?
Re: Overcharging issue? [Re: MONC] #1717033
12/28/14 07:51 PM
12/28/14 07:51 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Without further testing, I wouldn't assume the problem is the regulator. A high current draw or direct short somewhere in the system will cause a perfectly good alternator and regulator to charge at the max rate.
Re: Overcharging issue? [Re: John_Kunkel] #1717034
12/28/14 08:07 PM
12/28/14 08:07 PM
MONC Offline OP
MONC  Offline OP
What further testing do you suggest John?
Do those voltage readings at the VR and alternator at idle indicative of charging at the max rate?
Re: Overcharging issue? [Re: MONC] #1717035
12/28/14 09:06 PM
12/28/14 09:06 PM
no, you took those readings at idle & the alt does not put out enough at idle which is why you have those low voltage numbers (8 ish) at the reg/alt field. At a higher RPM it will full field & put out the crazy numbers (17+ charging voltage) you mentioned earlier
Re: Overcharging issue? [Re: MONC] #1717036
12/28/14 09:14 PM
12/28/14 09:14 PM
Nevada
dezduster Offline
dezduster  Offline
Nevada
Something funky going on.
Voltage at battery before start 12.7
Voltage at battery while idling 17.7
Voltage at alternator while idling 7.8-8.2
Voltage at voltage regulator idling 6.8-7.5
Seems bad ground when checking voltages at alternator and regulator?? Makes me think clean your grounds and any contact points between alt and vr. Also loosen and tighten alternator bracket and VR to fire wall to ensure a good ground. ohm the wires between alt and vr check resistance from alt to AMP guage to battery clean bulk head connector. MY THOUGHTS ARE voltage at alt and vr should be the same as or close to battery. If not why? faulty meter? Just sounds like ground problem to me.
Im off to fallon for tires for daughter cant stay and help more.
Re: Overcharging issue? [Re: dezduster] #1717037
12/29/14 11:29 AM
12/29/14 11:29 AM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
Don't be surprised if you have a bad connection at either the bulkhead connector or the connector on the steering column. Look at the heavy red wire at both connections. Look for discoloration of the plastic. Pull them apart if possible and check them. I had the same problem on my 71 Challenger and I changed everything out. Regulators, alternators, had it to two different shops, nothing. I was under the dash one day just looking around and saw a brown streak in the connection for the steering column to the main harness. I bypassed the connector and that took care of the overcharging problem. Remember, these connectors are 45 alomost 50 yrs. old.
Re: Overcharging issue? [Re: 70HemiGTX] #1717038
12/29/14 11:42 AM
12/29/14 11:42 AM
MONC Offline OP
MONC  Offline OP
I did look at the bulk head connections from the firewall side and the inside and I didn't notice any discoloration or corrosion. It's harder on the b-bodies to get up that far underneath the column so I couldn't get any farther than that.
The connection looked good at the ammeter itself, will doubled check the column harness connection - thanks for the reminder.
Re: Overcharging issue? [Re: MONC] #1717039
12/29/14 12:56 PM
12/29/14 12:56 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
Double check your readings.
It is impossible to have 17.5 at the battery with 7.8-8.2 at the alternator.
Re: Overcharging issue? [Re: TJP] #1717040
12/29/14 01:59 PM
12/29/14 01:59 PM
Those are blue wire ign1 field terminal readings as opposed to a alt batt stud reading and they are low cuz they were taken at idle (alt ain't puttin out) whereas at a higher RPM the field terminal (blue wire circuit) voltage readings would be in the 17+ range (as would the entire electrical system) from the alt putting out what it is capable of & the bad (full fielded) reg telling/allowing it to put out all it can.
Re: Overcharging issue? [Re: RapidRobert] #1717041
12/29/14 06:56 PM
12/29/14 06:56 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
Ok he didn't specify that, but if so,
1. he is losing 1V between the alt and reg.
2.The ign side of the reg should be close to battery V or 17V,
You say the readings are low because the alt is at idle and not putting out yet his battery V is 17+ ????
Re: Overcharging issue? [Re: TJP] #1717042
12/29/14 07:03 PM
12/29/14 07:03 PM
Oh OK I see what you are sayin cuz he does state that his batt voltage is 17+ at (normal/slow?) idle
Re: Overcharging issue? [Re: TJP] #1717043
12/29/14 07:19 PM
12/29/14 07:19 PM
MONC Offline OP
MONC  Offline OP
I'm going to try and recheck my readings tomorrow as well as check the connections again from the bulkhead connector to the ammeter itself.
Re: Overcharging issue? [Re: MONC] #1717044
12/29/14 07:35 PM
12/29/14 07:35 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
I've found that those stock early voltage regulators don't seem to handle the cold all too well. Anyone else experience that? Not sure if that's a good explanation.
Re: Overcharging issue? [Re: dart4forte] #1717045
12/29/14 08:17 PM
12/29/14 08:17 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Never had a weather related problem with my points type regulators that I recall. But the farthest north I ever was running this system during the winter was Memphis in 90-91. Yeah, it snowed there.
Don't be the exception.
Re: Overcharging issue? [Re: MONC] #1717046
12/29/14 08:51 PM
12/29/14 08:51 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
