early dodge truck seat replacement #1717010
12/28/14 05:15 PM
12/28/14 05:15 PM
Shelby, Ohio
2
2abodymcodes Offline OP
Shelby, Ohio
the stock seat in my 42 dodge truck is very uncomfortable. sits up too high and too bouncy. what late model seat will fit in the cab. was looking at Chrysler town & country minivan 3rd rear seats. any suggestions?
Re: early dodge truck seat replacement [Re: 2abodymcodes] #1717011
12/28/14 11:49 PM
12/28/14 11:49 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Bucket seats almost always fit. I believe Dakota seats will fit as well.
Watch out for seats with thick back cushions and a leaned back backrest. They will put you real close the the steering wheel. Usually, low back seats where the seat back fits under the rear window ledge give you as much steering wheel clearance as possible, which is usually the biggest issue with modern seats. Gene
Re: early dodge truck seat replacement [Re: poorboy] #1717012
12/29/14 12:33 AM
12/29/14 12:33 AM
Lithonia, Ga
3
36PLYM Offline
36PLYM  Offline
Lithonia, Ga
Used Dakota or Durango seats in the 36 Coupe. Fit very well and power!
36 Plymouth Coupe
318 w/360 heads
518 trans
8 3/4 rear
Ga. Tech BCE'78
Re: early dodge truck seat replacement [Re: 36PLYM] #1717013
12/29/14 03:27 AM
12/29/14 03:27 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
that 3rd seat works well---also those low back dodge van seats work well----like previous says the high back buckets seat backs are thick and put you on the steering wheel.....
Re: early dodge truck seat replacement [Re: 2abodymcodes] #1717014
12/29/14 03:27 AM
12/29/14 03:27 AM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
The seat in my 37 is the 3rd seat from a 69 B body wagon, it's the perfect size IMO
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: early dodge truck seat replacement [Re: AZ_A12_BEE] #1717015
12/29/14 03:29 AM
12/29/14 03:29 AM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
I made it folding too
Re: early dodge truck seat replacement [Re: AZ_A12_BEE] #1717016
12/29/14 01:07 PM
12/29/14 01:07 PM
Crofton, Ky.
rattler Offline
rattler  Offline
Crofton, Ky.
I used power buckets from a jeep cherokee in my 57. They solved the placement issue and are a low back. Junkyard cheap too.
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: early dodge truck seat replacement [Re: rattler] #1717017
12/29/14 03:40 PM
12/29/14 03:40 PM
Shelby, Ohio
2
Shelby, Ohio
I like the b body 3rd seat idea but that is impossible to find around here. our local pick and pull has about 30 chrysler mini vans. i'll grab a back seat and try it.
Re: early dodge truck seat replacement [Re: 2abodymcodes] #1717018
12/29/14 04:43 PM
12/29/14 04:43 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Put a want ad here on Moparts
Re: early dodge truck seat replacement [Re: AZ_A12_BEE] #1717019
12/29/14 07:24 PM
12/29/14 07:24 PM
moparx Offline
moparx  Offline
if ya can't find one you like locally, and wouldn't mind traveling to mile 78 on I-80 , i'll give ya one from my bus i ain't using.
Re: early dodge truck seat replacement [Re: 2abodymcodes] #1717020
12/29/14 08:17 PM
12/29/14 08:17 PM
moparx Offline
moparx  Offline
here is a 3rd row seat that came from my junked 95 caravan in my cousin's model A. we had to pie cut the front to fit, but that was an easy deal. it retains the folding back, and we used the mechanism that folds the whole seat forward on the passenger side bucket to access the under seat storage area. it is assisted with the worn out hood struts from my wife's 93 chrysler concorde. they wouldn't hold the hood up, but work great on the seat mechanism !
