Taking on another project. Engine break-in stand #1716657
12/27/14 11:33 PM
12/27/14 11:33 PM
PA.
pittsburghracer Online work OP
"Little"John
pittsburghracer  Online Work OP
"Little"John
PA.
Been wanting an engine break-in stand for years so I started looking around. I found one on Amazon for less than 275 dollars but reading the feedback MOST of the guys reworked it. I found a set of plans on ebay for 8.50 and the plans are emailed to you for a fold up stand. The plans look GREAT and I should be attacking this project soon as Matt and I have 5 engines to build. We started removing inner springs on our cam break ins so this should help. I will let you know how it goes.
https://www.youtube.com/watch?v=wUtmE0MYhlQ&feature=youtu.be
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Taking on another project. Engine break-in stand [Re: pittsburghracer] #1716658
12/28/14 07:33 PM
12/28/14 07:33 PM
PA.
"Little"John
"Little"John
PA.
Well I ordered all the metal needed to build a fold-able, well built engine break-in stand from onlinemetals. They cut anything you order to size at no added cost. The metal needed and delivery came to almost 500 dollars but this thing should last several lifetimes. LOL. The one I looked at on Amazon was cheaply build and most of the guys beefed theirs up before using it. Can't wait to get started. Here is a link to the one i could have bought for 280 dollars
http://www.amazon.com/dp/B0007NXVB0/ref=...amp;dra_ohs=0-0
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Taking on another project. Engine break-in stand [Re: pittsburghracer] #1716659
12/28/14 07:49 PM
12/28/14 07:49 PM
Q
Quicktree Offline
Quicktree  Offline
Q
why do you need one
Re: Taking on another project. Engine break-in stand [Re: Quicktree] #1716660
12/28/14 07:56 PM
12/28/14 07:56 PM
PA.
"Little"John
"Little"John
PA.
Kinda just an itch I had but it will help with cam break-ins and spring changes. Lots of guys buying engines now like to hear them run and when selling them I would rather break the cams in. LOTS of guys have issues on initial fire-ups.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Taking on another project. Engine break-in stand [Re: pittsburghracer] #1716661
12/28/14 08:18 PM
12/28/14 08:18 PM
Q
Quicktree Offline
Quicktree  Offline
Q
i didn't know you sold motors
Re: Taking on another project. Engine break-in stand [Re: pittsburghracer] #1716662
12/28/14 08:24 PM
12/28/14 08:24 PM
Az
Crizila Offline
Crizila  Offline
Az
I would like to see some pics as you go along if you don't mind.
Fastest 300
Re: Taking on another project. Engine break-in stand [Re: pittsburghracer] #1716663
12/28/14 08:46 PM
12/28/14 08:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I made 8 of them at work... they were a break in cart
or a dyno cart... made out of 2" X 3" steel with adjustable
mounts... the front panel could be taken off if it was
going on the dyno... had casters on it.. the tank and
battery hung on the front lower cross bar... I wish
I would have kept a pic of them(but wasnt allowed to
being its a company job)
Re: Taking on another project. Engine break-in stand [Re: Quicktree] #1716664
12/28/14 09:59 PM
12/28/14 09:59 PM
PA.
"Little"John
"Little"John
PA.
Gotta make a buck went you get a chance when your on a fixed retirement.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Taking on another project. Engine break-in stand [Re: Crizila] #1716665
12/28/14 10:01 PM
12/28/14 10:01 PM
PA.
"Little"John
"Little"John
PA.
Will do. The plans look real nice and he also sent pictures of other guys builds.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Taking on another project. Engine break-in stand [Re: pittsburghracer] #1716666
12/28/14 10:07 PM
12/28/14 10:07 PM
GA
roadrunninMark Offline
GA
That plastic gas can right by the engine and battery would cause me some concern.
Re: Taking on another project. Engine break-in stand [Re: roadrunninMark] #1716667
12/28/14 10:24 PM
12/28/14 10:24 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I have seen some very well respected engine shops that have their plastic fuel cell in their dyno cell next to the engine
I mounted mine outside the cell with shut offs inside and out.
Better safe then sorry
Keith
Re: Taking on another project. Engine break-in stand [Re: Dunnuck Racing] #1716668
12/28/14 10:49 PM
12/28/14 10:49 PM
PA.
"Little"John
"Little"John
PA.
I have to come up with something for fuel storage. 2-4 gallon would be more than enough so I may practice my tig (lack of) skills. Lots of Holley blue pumps laying around so I have that covered. Also have an unused aluminum rad here so that will be put in service.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Taking on another project. Engine break-in stand [Re: pittsburghracer] #1716669
12/28/14 11:08 PM
12/28/14 11:08 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
Before you get too deep go the a vo-tech that teaches auto maint or a high school. When I taught we had several well built that went through numerous engine changes and rough handling and still worked like a charm. Had a radiator so you could get plenty of break-in time. Students needed that because I would break the engine and they have to fix it. The radiator was very small.
Re: Taking on another project. Engine break-in stand [Re: Dunnuck Racing] #1716670
12/28/14 11:13 PM
12/28/14 11:13 PM
Truckville, the capital of NY
85_Ram_4speed Offline
I built this one a couple years ago--after determining that most prebuilt ones were cheap and good ones were out of my price range and either way none had some features I wanted. I have about $400 into it. The 8" casters were expensive, I tried pneumatic 8" tires before, that was a no go. To much weight for them and by the time you got enough pressure in them, they were ready to pop off the rims--plus it rocked--a lot, when you revved the engine.
It is still a work in progress, I modify it as I go along. It is currently set up to run big and small block Mopars, and big and small Chebby's. Also have a bellhousing for a slant six too if it ever arises.
I have been using a Chrysler electronic ignition to fire all the engines run so far--I made an adapter to hook it to MSD distributors. I don't bother with the mechanical fan anymore, I also have a blue pump and regulator to run engines set up for electric pumps. Mechanical pump engines I run through that pump to verify all is operational. I run a volt gauge, oil gauge and temp gauge. My timing light has a tach function on it.
A 1.5-2 gallon fuel supply has been more than adequate for engine break in so far, I have just recently got a dedicated gas tank that I need to mount up somewhere. As far as where to mount the batter, wherever you can find room to do so. I still have to make a bracket/box, but want it not permanetly mounted to the stand.
The exhaust is a couple of 2.5" swapmeet "turbo" mufflers. I have about two feet of straight pipe after them. I use various adapters I made for manifolds that go to 2.5" or just use 2.5" collectors on headers, and I have two 4 foot sections of flex pipe to connect to the mufflers. I just set the mufflers on jack stands.
I also made it high enough to be A)comfortable to work on, and B) if you ever had to drop the pan, you could while it was still on the stand. I also made it so the bellhousing support unbolts and you lay it down and rebolt it on so it is flush on the frame and the radiator yoke also unbolts.
This is by far one of the best investments I have made and has saved my bacon twice before engines got put into cars. One leaked water from a side head freeze plug, the other had a oil leak that was hard to spot from a valve cover in the rear.
Outcast Dodge guy.
Re: Taking on another project. Engine break-in stand [Re: 85_Ram_4speed] #1716671
12/29/14 02:58 AM
12/29/14 02:58 AM
ky, usa
littlejohn44 Offline
ky, usa
sweet stand , i am think of building one as well , would seem to make adjusting and changing parts and seeing how they work so much easier in winter months. Do you have any more pics like of the back and of the front. looking for ideas.
Re: Taking on another project. Engine break-in stand [Re: littlejohn44] #1716672
12/29/14 09:35 AM
12/29/14 09:35 AM
I will post a couple more later for you.
Outcast Dodge guy.
Re: Taking on another project. Engine break-in stand [Re: littlejohn44] #1716673
12/29/14 09:55 AM
12/29/14 09:55 AM
PA.
"Little"John
"Little"John
PA.
Don't be afraid to buy these plans as they are laid out pretty nice. For $8.50 I think they are well worth it.
http://www.ebay.com/itm/331051831960
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Taking on another project. Engine break-in stand [Re: pittsburghracer] #1716674
12/29/14 03:20 PM
12/29/14 03:20 PM
Annapolis, MD, USA
V
Vert Online content
Vert  Online Content
V
Annapolis, MD, USA
That looks pretty good. I still want one of these. Starts as a run stand, but front section with controls, radiator, fuel comes off easily. Set up so it can be used for loaded k-frame under the car installs also.
http://www.speedhunters.com/2014/06/aaro...ches-of-awesome Speedhunters...
Re: Taking on another project. Engine break-in stand [Re: pittsburghracer] #1716675
12/29/14 04:22 PM
12/29/14 04:22 PM
Nebraska
451Cuda Offline
451Cuda  Offline
Nebraska
Just ordered a set, looks like a great design.
Re: Taking on another project. Engine break-in stand [Re: 451Cuda] #1716676
12/29/14 05:11 PM
12/29/14 05:11 PM
PA.
"Little"John
"Little"John
PA.
Well worth the price
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
