Page 1 of 5 1 2 3 4 5
Diesel Dart Cummins #1716533
12/27/14 09:37 PM
12/27/14 09:37 PM
Eastern Pa
DieselDart73 Offline OP
Eastern Pa
Here's my project for all of you that wanted to see it done. 1973 Dart Swinger 5.9 Cummins 47RH 8 3/4 2.73
Re: Diesel Dart Cummins [Re: DieselDart73] #1716534
12/27/14 09:39 PM
12/27/14 09:39 PM
Eastern Pa
Eastern Pa
Another pic
Re: Diesel Dart Cummins [Re: DieselDart73] #1716535
12/27/14 09:40 PM
12/27/14 09:40 PM
Eastern Pa
Eastern Pa
Ride height
Re: Diesel Dart Cummins [Re: DieselDart73] #1716536
12/27/14 09:41 PM
12/27/14 09:41 PM
Eastern Pa
Eastern Pa
Engine bay
Re: Diesel Dart Cummins [Re: DieselDart73] #1716537
12/27/14 10:44 PM
12/27/14 10:44 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
Cool build!! More details please!
Re: Diesel Dart Cummins [Re: NV69B7RR] #1716538
12/27/14 10:56 PM
12/27/14 10:56 PM
Eastern Pa
Eastern Pa
Thanks for the support. It'll have a 12mm p-pump 66mm Borg Warner turbo 5x18 injectors and nitrous. The motor is out of a RV it's a 94. The trans is out of a 2wd 2500. It's 4 link from jegs out back. With a 8 3/4 and 2.73 gears full tubs s&w cage. It's been long in the making picked up the car with slant 6 in it for 900bucks. The car will be ready for the race season to race my girl and her 34 chevy cummins Ratrod.
Re: Diesel Dart Cummins [Re: DieselDart73] #1716539
12/27/14 11:17 PM
12/27/14 11:17 PM
Eastern Pa
Eastern Pa
4 link
Re: Diesel Dart Cummins [Re: DieselDart73] #1716540
12/28/14 02:32 AM
12/28/14 02:32 AM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
awesome!!! 900+ft lbs of torque and a 8 3/4. I have found your weak spot.. your welcome.
I like your style
Re: Diesel Dart Cummins [Re: chrisf] #1716541
12/28/14 02:57 PM
12/28/14 02:57 PM
Eastern Pa
Eastern Pa
I want to keep the build as mopar/dodge as possible. I had a dana70 out of a 3500 but too big and spools are not available other then one I found. The 8 3/4 was super cheap compared to dana60 and with the spool big axles shortened length of shafts the axle should handle plenty for now....thanks for looking out for me and the build.
Re: Diesel Dart Cummins [Re: DieselDart73] #1716542
12/29/14 07:22 AM
12/29/14 07:22 AM
Eastern Pa
Eastern Pa
Another view
Re: Diesel Dart Cummins [Re: DieselDart73] #1716543
12/30/14 08:37 PM
12/30/14 08:37 PM
Eastern Pa
Eastern Pa
Cage going in
Re: Diesel Dart Cummins [Re: DieselDart73] #1716544
12/30/14 08:39 PM
12/30/14 08:39 PM
Eastern Pa
Eastern Pa
Frame connecting front to rear tying cage together
Re: Diesel Dart Cummins [Re: DieselDart73] #1716545
12/31/14 08:59 AM
12/31/14 08:59 AM
Eastern Pa
Eastern Pa
More of cage
Re: Diesel Dart Cummins [Re: DieselDart73] #1716546
12/31/14 09:00 AM
12/31/14 09:00 AM
Eastern Pa
Eastern Pa
Cage
Re: Diesel Dart Cummins [Re: DieselDart73] #1716547
12/31/14 04:09 PM
12/31/14 04:09 PM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
That's a cool project!
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Diesel Dart Cummins [Re: OhioMopar] #1716548
12/31/14 06:52 PM
12/31/14 06:52 PM
Eastern Pa
Eastern Pa
Thanks a lot. We'll have it out your way at one of the tracks. Norwalk national trail Thompson or la rue. See it in person.
Re: Diesel Dart Cummins [Re: DieselDart73] #1716549
12/31/14 07:08 PM
12/31/14 07:08 PM
CJD AUTOMOTIVE Offline
That 47 will never live. You can build it with the 48 5 -gear planetary's, but the weak link will always be the overdrive clutch/spring. You can update to a 48 overdrive, but by then, you could just use a 48...and the 48 won't live either with that torque. You've got options, but none are cheap.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
www.CJDAUTOMOTIVE.com
904-400-1802
"I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
Re: Diesel Dart Cummins [Re: CJD AUTOMOTIVE] #1716550
12/31/14 08:08 PM
12/31/14 08:08 PM
Eastern Pa
Eastern Pa
I don't think I'll ever need the overdrive the gearing and tire size will keep me out of it... But any pointers or tricks to making it live longer will be appreciated. Can I keep the 47 out of OD with a manual Valve body? Thanks
Re: Diesel Dart Cummins [Re: DieselDart73] #1716551
12/31/14 08:53 PM
12/31/14 08:53 PM
Unfortunately no. The OD units clutch is used in direct and OD. You'll still pull through the clutch with OD off.
If OD is not needed, you can just build a 727, or dare say I, a Turbo 400. The adapter on the back of the engine is available in Chevy, Ford, and Mopar. I'd say a Powerglide is out because your going to need 3 gears in the quarter with the rpm band of the engine. If your going to have one built, pick something that has gear ratios available for it. You can tailor the gear split to keep the diesel in it's narrow power band. Probably be best to check in with the Cummins truck drag race guys. They will be a lot more helpful on recommending a transmission and know what will live. I only know what won't!!
BTW, I think your going to want a lot more rear gear.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: Diesel Dart Cummins [Re: CJD AUTOMOTIVE] #1716552
12/31/14 10:05 PM
12/31/14 10:05 PM
Eastern Pa
Eastern Pa
Thanks for the info. We already have my girls truck with a powerglide adapted cummins. Fully built 2.70 gears 33x18.50s runs [Email]10.87@123mph[/Email] footbrake picks frontend off ground.
