Page 1 of 5 1 2 3 4 5
Diesel Dart Cummins #1716533
12/27/14 09:37 PM
12/27/14 09:37 PM
Eastern Pa
DieselDart73 Offline OP
Eastern Pa
Here's my project for all of you that wanted to see it done. 1973 Dart Swinger 5.9 Cummins 47RH 8 3/4 2.73
Re: Diesel Dart Cummins [Re: DieselDart73] #1716534
12/27/14 09:39 PM
12/27/14 09:39 PM
Eastern Pa
Eastern Pa
Another pic
Re: Diesel Dart Cummins [Re: DieselDart73] #1716535
12/27/14 09:40 PM
12/27/14 09:40 PM
Eastern Pa
Eastern Pa
Ride height
Re: Diesel Dart Cummins [Re: DieselDart73] #1716536
12/27/14 09:41 PM
12/27/14 09:41 PM
Eastern Pa
Eastern Pa
Engine bay
Re: Diesel Dart Cummins [Re: DieselDart73] #1716537
12/27/14 10:44 PM
12/27/14 10:44 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
Cool build!! More details please!
Re: Diesel Dart Cummins [Re: NV69B7RR] #1716538
12/27/14 10:56 PM
12/27/14 10:56 PM
Eastern Pa
Eastern Pa
Thanks for the support. It'll have a 12mm p-pump 66mm Borg Warner turbo 5x18 injectors and nitrous. The motor is out of a RV it's a 94. The trans is out of a 2wd 2500. It's 4 link from jegs out back. With a 8 3/4 and 2.73 gears full tubs s&w cage. It's been long in the making picked up the car with slant 6 in it for 900bucks. The car will be ready for the race season to race my girl and her 34 chevy cummins Ratrod.
Re: Diesel Dart Cummins [Re: DieselDart73] #1716539
12/27/14 11:17 PM
12/27/14 11:17 PM
Eastern Pa
Eastern Pa
4 link
Re: Diesel Dart Cummins [Re: DieselDart73] #1716540
12/28/14 02:32 AM
12/28/14 02:32 AM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
awesome!!! 900+ft lbs of torque and a 8 3/4. I have found your weak spot.. your welcome.
I like your style
Re: Diesel Dart Cummins [Re: chrisf] #1716541
12/28/14 02:57 PM
12/28/14 02:57 PM
Eastern Pa
Eastern Pa
I want to keep the build as mopar/dodge as possible. I had a dana70 out of a 3500 but too big and spools are not available other then one I found. The 8 3/4 was super cheap compared to dana60 and with the spool big axles shortened length of shafts the axle should handle plenty for now....thanks for looking out for me and the build.
Re: Diesel Dart Cummins [Re: DieselDart73] #1716542
12/29/14 07:22 AM
12/29/14 07:22 AM
Eastern Pa
Eastern Pa
Another view
Re: Diesel Dart Cummins [Re: DieselDart73] #1716543
12/30/14 08:37 PM
12/30/14 08:37 PM
Eastern Pa
Eastern Pa
Cage going in
Re: Diesel Dart Cummins [Re: DieselDart73] #1716544
12/30/14 08:39 PM
12/30/14 08:39 PM
Eastern Pa
Eastern Pa
Frame connecting front to rear tying cage together
Re: Diesel Dart Cummins [Re: DieselDart73] #1716545
12/31/14 08:59 AM
12/31/14 08:59 AM
Eastern Pa
Eastern Pa
More of cage
Re: Diesel Dart Cummins [Re: DieselDart73] #1716546
12/31/14 09:00 AM
12/31/14 09:00 AM
Eastern Pa
Eastern Pa
Cage
Re: Diesel Dart Cummins [Re: DieselDart73] #1716547
12/31/14 04:09 PM
12/31/14 04:09 PM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
That's a cool project!
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Diesel Dart Cummins [Re: OhioMopar] #1716548
12/31/14 06:52 PM
12/31/14 06:52 PM
Eastern Pa
Eastern Pa
Thanks a lot. We'll have it out your way at one of the tracks. Norwalk national trail Thompson or la rue. See it in person.
Re: Diesel Dart Cummins [Re: DieselDart73] #1716549
12/31/14 07:08 PM
12/31/14 07:08 PM
CJD AUTOMOTIVE Offline
That 47 will never live. You can build it with the 48 5 -gear planetary's, but the weak link will always be the overdrive clutch/spring. You can update to a 48 overdrive, but by then, you could just use a 48...and the 48 won't live either with that torque. You've got options, but none are cheap.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
www.CJDAUTOMOTIVE.com
904-400-1802
"I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
Re: Diesel Dart Cummins [Re: CJD AUTOMOTIVE] #1716550
12/31/14 08:08 PM
12/31/14 08:08 PM
Eastern Pa
Eastern Pa
I don't think I'll ever need the overdrive the gearing and tire size will keep me out of it... But any pointers or tricks to making it live longer will be appreciated. Can I keep the 47 out of OD with a manual Valve body? Thanks
Re: Diesel Dart Cummins [Re: DieselDart73] #1716551
12/31/14 08:53 PM
12/31/14 08:53 PM
Unfortunately no. The OD units clutch is used in direct and OD. You'll still pull through the clutch with OD off.
If OD is not needed, you can just build a 727, or dare say I, a Turbo 400. The adapter on the back of the engine is available in Chevy, Ford, and Mopar. I'd say a Powerglide is out because your going to need 3 gears in the quarter with the rpm band of the engine. If your going to have one built, pick something that has gear ratios available for it. You can tailor the gear split to keep the diesel in it's narrow power band. Probably be best to check in with the Cummins truck drag race guys. They will be a lot more helpful on recommending a transmission and know what will live. I only know what won't!!
BTW, I think your going to want a lot more rear gear.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: Diesel Dart Cummins [Re: CJD AUTOMOTIVE] #1716552
12/31/14 10:05 PM
12/31/14 10:05 PM
Eastern Pa
Eastern Pa
Thanks for the info. We already have my girls truck with a powerglide adapted cummins. Fully built 2.70 gears 33x18.50s runs [Email]10.87@123mph[/Email] footbrake picks frontend off ground.
Re: Diesel Dart Cummins [Re: DieselDart73] #1716553
12/31/14 10:16 PM
12/31/14 10:16 PM
Eastern Pa
Eastern Pa
And the other truck the guy who built this one runs a 727 in it goes 11.2s all day and hasn't broke anything other then universal and pinion on the 9in. This is the first dodge trans I'm doing. I love my Mopars we have a lot in my family. Seven to be exact. I've always done the ford trans in my tow rigs most Suncoast part and precision.
Re: Diesel Dart Cummins [Re: DieselDart73] #1716554
01/01/15 03:10 AM
01/01/15 03:10 AM
Eastern Pa
Eastern Pa
Ok back to the cage. It's done now and front bars up front
Re: Diesel Dart Cummins [Re: DieselDart73] #1716555
01/01/15 11:29 PM
01/01/15 11:29 PM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
If it is at LaRue or National Trail I would make the tri to check it out for sure!
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Diesel Dart Cummins [Re: OhioMopar] #1716556
01/02/15 03:46 PM
01/02/15 03:46 PM
Eastern Pa
Eastern Pa
It'll be at laRue look up nadm for the dates. I'll have many passes on the car by the time we make it there.
Re: Diesel Dart Cummins [Re: DieselDart73] #1716557
01/03/15 02:16 AM
01/03/15 02:16 AM
Eastern Pa
Eastern Pa
Here's the narrowed up rear
Re: Diesel Dart Cummins [Re: DieselDart73] #1716558
01/03/15 02:23 AM
01/03/15 02:23 AM
Boise, Idaho, U.S.A.
tims69belvedere Offline
Those rh's can live. Decent clutch packs and bands. Some had an aluminum front planet. You will need a steel front planet. I would rollerize the gear train. Billet input and intermediate shafts with the second gear updates. A light car Like that shouldn't be too hard on it. Wouldn't hurt to do a direct drum. We do these all the time. Can't hardly keep them in the shelves. One customer keeps us busy with his. 1600 hp on fuel only in a regular cab 4wd. It's a race truck but the convertor has become the weak point. Sweet build though!
Re: Diesel Dart Cummins [Re: tims69belvedere] #1716559
01/03/15 02:32 AM
01/03/15 02:32 AM
Oh and can't forget the valve body mods to have 1st and 2nd gear lockup!
Re: Diesel Dart Cummins [Re: DieselDart73] #1716560
01/03/15 05:08 PM
01/03/15 05:08 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
Cool project! I think you're gonna need some fatter torsion bars....lol.
Re: Diesel Dart Cummins [Re: JDMopar] #1716561
01/03/15 05:27 PM
01/03/15 05:27 PM
Eastern Pa
Eastern Pa
Believe it or not those are the slant6 torsion bars. Lol being that the engine is moved back as far as it is it's really stiff up front. It's really amazing. Well test it and see where to go from there.
Re: Diesel Dart Cummins [Re: DieselDart73] #1716562
01/03/15 05:44 PM
01/03/15 05:44 PM
JDMopar Offline
JDMopar  Offline
You can buy bigger bars if needed. I would gusset the torsion bar frame stubs that are left, if you aren't going to tie the torsion bar cross member back together. With the motor scooted back, you may not have room to tie it back together. As long as the remaining sections of the torsion bar x member won't twist, they will be fine. It'd be hell to come down from a hard wheels up launch....and the drivers side torsion bar jab you in the back of your left leg!
Re: Diesel Dart Cummins [Re: JDMopar] #1716563
01/03/15 06:04 PM
01/03/15 06:04 PM
Eastern Pa
Eastern Pa
How's this look?
Re: Diesel Dart Cummins [Re: DieselDart73] #1716564
01/03/15 06:12 PM
01/03/15 06:12 PM
JDMopar Offline
JDMopar  Offline
Awesome! Is that a motor mount/ plate towards the mid to rear of the engine?
Re: Diesel Dart Cummins [Re: JDMopar] #1716565
01/03/15 06:42 PM
01/03/15 06:42 PM
Eastern Pa
Eastern Pa
Yes it's coming along
Re: Diesel Dart Cummins [Re: DieselDart73] #1716566
01/05/15 04:04 PM
01/05/15 04:04 PM
Eastern Pa
Eastern Pa
Here's the strengthened 8 3/4 and narrowed
Re: Diesel Dart Cummins [Re: DieselDart73] #1716567
01/05/15 04:05 PM
01/05/15 04:05 PM
Eastern Pa
Eastern Pa
Another view 8 3/4 narrowed
Re: Diesel Dart Cummins [Re: DieselDart73] #1716568
01/05/15 05:23 PM
01/05/15 05:23 PM
Eastern Pa
Eastern Pa
With 4 link attached
Re: Diesel Dart Cummins [Re: DieselDart73] #1716569
01/06/15 12:51 AM
01/06/15 12:51 AM
Eastern Pa
Eastern Pa
Rear end mock up and coilovers back half
Re: Diesel Dart Cummins [Re: DieselDart73] #1716570
01/06/15 10:57 AM
01/06/15 10:57 AM
TN
JS29R0B Offline
JS29R0B  Offline
TN
Looking good!
Re: Diesel Dart Cummins [Re: DieselDart73] #1716571
01/20/15 01:16 PM
01/20/15 01:16 PM
Eastern Pa
Eastern Pa
Engine bay prepped for paint
Re: Diesel Dart Cummins [Re: DieselDart73] #1716572
01/20/15 01:17 PM
01/20/15 01:17 PM
Eastern Pa
Eastern Pa
Painted up
Re: Diesel Dart Cummins [Re: DieselDart73] #1716573
01/21/15 10:51 AM
01/21/15 10:51 AM
TN
JS29R0B Offline
JS29R0B  Offline
TN
Cool...Do you come to the diesel drags in Bowling Green KY?
Re: Diesel Dart Cummins [Re: JS29R0B] #1716574
01/21/15 12:15 PM
01/21/15 12:15 PM
Eastern Pa
Eastern Pa
Yes we will be there love that track!
Re: Diesel Dart Cummins [Re: DieselDart73] #1716575
01/21/15 12:18 PM
01/21/15 12:18 PM
Eastern Pa
Eastern Pa
That pic was taken 2 years ago haven't seen that car since that race tho. There's a video on YouTube of our truck and it racing. Pretty cool
Re: Diesel Dart Cummins [Re: DieselDart73] #1716576
01/21/15 04:10 PM
01/21/15 04:10 PM
TN
JS29R0B Offline
JS29R0B  Offline
TN
I think I spoke with your wife asking what rear was in the truck.
It is a ford 9 inch.
Re: Diesel Dart Cummins [Re: JS29R0B] #1716577
01/21/15 04:17 PM
01/21/15 04:17 PM
TN
JS29R0B Offline
JS29R0B  Offline
TN
Not to hijack your post but you might have seen my truck there before.
I didn't own it when it was there but I do now
Re: Diesel Dart Cummins [Re: JS29R0B] #1716578
01/25/15 01:06 PM
01/25/15 01:06 PM
Eastern Pa
Eastern Pa
Oh yea I remember seeing that truck rolling around.
Re: Diesel Dart Cummins [Re: JS29R0B] #1716579
01/25/15 01:08 PM
01/25/15 01:08 PM
Eastern Pa
Eastern Pa
The wheels came yesterday from Weld!
Re: Diesel Dart Cummins [Re: DieselDart73] #1716580
01/25/15 01:09 PM
01/25/15 01:09 PM
Eastern Pa
Eastern Pa
15x14
Re: Diesel Dart Cummins [Re: DieselDart73] #1716581
01/25/15 01:11 PM
01/25/15 01:11 PM
Eastern Pa
Eastern Pa
The rear axle in place now just waiting for rear brake kit and axles to come
Re: Diesel Dart Cummins [Re: DieselDart73] #1716582
01/27/15 06:32 PM
01/27/15 06:32 PM
Eastern Pa
Eastern Pa
The engine is getting back together first coat of paint.
Re: Diesel Dart Cummins [Re: DieselDart73] #1716583
01/27/15 10:29 PM
01/27/15 10:29 PM
Eastern Pa
Eastern Pa
Looking better
Re: Diesel Dart Cummins [Re: DieselDart73] #1716584
01/31/15 01:10 AM
01/31/15 01:10 AM
Eastern Pa
Eastern Pa
Fuel cell and battery mounted up
Re: Diesel Dart Cummins [Re: DieselDart73] #1716585
01/31/15 01:11 AM
01/31/15 01:11 AM
Eastern Pa
Eastern Pa
Getting ready to mount up slicks
Re: Diesel Dart Cummins [Re: DieselDart73] #1716586
01/31/15 01:12 AM
01/31/15 01:12 AM
Eastern Pa
Eastern Pa
Fuel pump came too
Re: Diesel Dart Cummins [Re: DieselDart73] #1716587
02/02/15 11:06 AM
02/02/15 11:06 AM
TN
JS29R0B Offline
JS29R0B  Offline
TN
Re: Diesel Dart Cummins [Re: DieselDart73] #1716588
02/05/15 11:19 PM
02/05/15 11:19 PM
Eastern Pa
Eastern Pa
Axles came today
Re: Diesel Dart Cummins [Re: DieselDart73] #1716589
02/12/15 12:35 AM
02/12/15 12:35 AM
Eastern Pa
Eastern Pa
Rear and disc brakes installed
Re: Diesel Dart Cummins [Re: DieselDart73] #1716590
02/12/15 12:36 AM
02/12/15 12:36 AM
Eastern Pa
Eastern Pa
Putting engine and trans back in to do firewall tunnel and floor
Re: Diesel Dart Cummins [Re: DieselDart73] #1716591
02/14/15 11:47 AM
02/14/15 11:47 AM
Millersville, PA
HemiChallenger Offline
Millersville, PA
I like the concept here... Where are you in Pa?
Re: Diesel Dart Cummins [Re: HemiChallenger] #1716592
02/16/15 06:53 PM
02/16/15 06:53 PM
Eastern Pa
Eastern Pa
I'm in kutztown. It's being built up in mt Pocono. Thanks for the support.
Re: Diesel Dart Cummins [Re: DieselDart73] #1716593
02/26/15 01:02 AM
02/26/15 01:02 AM
Eastern Pa
Eastern Pa
Ok I ditched the wilwood brake kit and went with doctor diff 11.75 disc kit fit great thanks again.
Re: Diesel Dart Cummins [Re: DieselDart73] #1716594
02/26/15 01:06 AM
02/26/15 01:06 AM
Eastern Pa
Eastern Pa
Slicks fit perfect
Re: Diesel Dart Cummins [Re: DieselDart73] #1716595
02/26/15 01:10 AM
02/26/15 01:10 AM
Eastern Pa
Eastern Pa
Goodyears
Re: Diesel Dart Cummins [Re: DieselDart73] #1716596
02/26/15 01:11 AM
02/26/15 01:11 AM
Eastern Pa
Eastern Pa
More pics
Re: Diesel Dart Cummins [Re: DieselDart73] #1716597
02/26/15 01:12 AM
02/26/15 01:12 AM
Eastern Pa
Eastern Pa
Thru the trunk
Re: Diesel Dart Cummins [Re: DieselDart73] #1716598
02/26/15 02:27 PM
02/26/15 02:27 PM
Eastern Pa
Eastern Pa
Rear disc setup
Re: Diesel Dart Cummins [Re: DieselDart73] #1716599
02/26/15 03:35 PM
02/26/15 03:35 PM
TN
JS29R0B Offline
JS29R0B  Offline
TN
Looking Great!
Re: Diesel Dart Cummins [Re: DieselDart73] #1716600
02/26/15 04:41 PM
02/26/15 04:41 PM
Eastern Pa
Eastern Pa
Front discs on drum spindle
Re: Diesel Dart Cummins [Re: DieselDart73] #1716601
03/02/15 01:24 PM
03/02/15 01:24 PM
Eastern Pa
Eastern Pa
Doing exhaust short and sweet
Re: Diesel Dart Cummins [Re: DieselDart73] #1716602
03/02/15 01:25 PM
03/02/15 01:25 PM
Eastern Pa
Eastern Pa
In place fits great
Re: Diesel Dart Cummins [Re: DieselDart73] #1716603
03/02/15 01:27 PM
03/02/15 01:27 PM
Eastern Pa
Eastern Pa
Fender view
Re: Diesel Dart Cummins [Re: DieselDart73] #1716604
03/02/15 01:29 PM
03/02/15 01:29 PM
Eastern Pa
Eastern Pa
Down the side
Re: Diesel Dart Cummins [Re: DieselDart73] #1716605
03/10/15 05:42 PM
03/10/15 05:42 PM
Eastern Pa
Eastern Pa
The engine with pump and turbo on. Removable wiper cowl for access to motor
Re: Diesel Dart Cummins [Re: DieselDart73] #1716606
03/10/15 05:44 PM
03/10/15 05:44 PM
Eastern Pa
Eastern Pa
Firewall and trans tunnel coming along
Re: Diesel Dart Cummins [Re: DieselDart73] #1716607
03/12/15 12:14 PM
03/12/15 12:14 PM
Eastern Pa
Eastern Pa
Floor finished
Re: Diesel Dart Cummins [Re: DieselDart73] #1716608
03/15/15 03:12 PM
03/15/15 03:12 PM
Eastern Pa
Eastern Pa
Finished tubs
Re: Diesel Dart Cummins [Re: DieselDart73] #1716609
03/15/15 03:17 PM
03/15/15 03:17 PM
Eastern Pa
Eastern Pa
Tubs
Re: Diesel Dart Cummins [Re: DieselDart73] #1716610
03/15/15 03:18 PM
03/15/15 03:18 PM
Eastern Pa
Eastern Pa
Inside view
Re: Diesel Dart Cummins [Re: DieselDart73] #1716611
03/16/15 10:27 AM
03/16/15 10:27 AM
TN
JS29R0B Offline
JS29R0B  Offline
TN
Nice! You work fast
Re: Diesel Dart Cummins [Re: JS29R0B] #1716612
03/16/15 02:17 PM
03/16/15 02:17 PM
Eastern Pa
Eastern Pa
It'll be pouring smoke and melting tires in no time! April hopefully
Re: Diesel Dart Cummins [Re: JS29R0B] #1716613
03/18/15 09:16 PM
03/18/15 09:16 PM
Eastern Pa
Eastern Pa
Rear firewall finished up
Re: Diesel Dart Cummins [Re: DieselDart73] #1716614
03/21/15 05:59 PM
03/21/15 05:59 PM
Eastern Pa
Eastern Pa
Painted up
Re: Diesel Dart Cummins [Re: DieselDart73] #1716615
03/21/15 06:07 PM
03/21/15 06:07 PM
Eastern Pa
Eastern Pa
Front
Re: Diesel Dart Cummins [Re: DieselDart73] #1716616
03/28/15 07:31 PM
03/28/15 07:31 PM
Eastern Pa
Eastern Pa
Trunk
Re: Diesel Dart Cummins [Re: DieselDart73] #1716617
03/28/15 07:33 PM
03/28/15 07:33 PM
Eastern Pa
Eastern Pa
Dash cluster
Re: Diesel Dart Cummins [Re: DieselDart73] #1716618
03/28/15 07:34 PM
03/28/15 07:34 PM
Eastern Pa
Eastern Pa
Rear setup
Re: Diesel Dart Cummins [Re: DieselDart73] #1716619
03/28/15 11:48 PM
03/28/15 11:48 PM
Eastern Pa
Eastern Pa
Some of the body work passenger side and new ride height
Re: Diesel Dart Cummins [Re: DieselDart73] #1716620
03/28/15 11:50 PM
03/28/15 11:50 PM
Eastern Pa
Eastern Pa
Driver side body work shaved marker lights for custom led
Re: Diesel Dart Cummins [Re: DieselDart73] #1804810
04/16/15 10:15 AM
04/16/15 10:15 AM
TN
JS29R0B Offline
JS29R0B  Offline
TN
Any updates?
Re: Diesel Dart Cummins [Re: JS29R0B] #1884438
08/03/15 04:54 PM
08/03/15 04:54 PM
Eastern Pa
Eastern Pa
Yea the car made its first burnout on 8/1 in crossville Tennessee
Re: Diesel Dart Cummins [Re: DieselDart73] #1884442
08/03/15 04:56 PM
08/03/15 04:56 PM
Eastern Pa
Eastern Pa
Second try
Re: Diesel Dart Cummins [Re: DieselDart73] #1885647
08/05/15 03:21 PM
08/05/15 03:21 PM
TN
JS29R0B Offline
JS29R0B  Offline
TN
Awesome......
Re: Diesel Dart Cummins [Re: JS29R0B] #1885660
08/05/15 03:36 PM
08/05/15 03:36 PM
Eastern Pa
Eastern Pa
Yea didn't get any good passes the brakes were terrible. Guess you can't use a drum brake master cylinder for disc brakes lol. Got new master cylinder going to test next weekend and hope for nitrous passes too
Re: Diesel Dart Cummins [Re: DieselDart73] #1886150
08/06/15 09:53 AM
08/06/15 09:53 AM
TN
JS29R0B Offline
JS29R0B  Offline
TN
Cool I would like to see a vid of a clean pass. I hope you will have it at Bowling Green next year.
Re: Diesel Dart Cummins [Re: DieselDart73] #1897417
08/23/15 12:10 AM
08/23/15 12:10 AM
tulsa ok
U
upnover Offline
upnover  Offline
U
tulsa ok
thats one evil looking car, love it.
Re: Diesel Dart Cummins [Re: upnover] #3080695
09/25/22 11:42 PM
09/25/22 11:42 PM
Eastern Pa
Eastern Pa
Ok so I’ve been off for a long time but the car finally came back home.
Re: Diesel Dart Cummins [Re: DieselDart73] #3080698
09/25/22 11:44 PM
09/25/22 11:44 PM
Eastern Pa
Eastern Pa
Four days later.
Re: Diesel Dart Cummins [Re: DieselDart73] #3080699
09/25/22 11:45 PM
09/25/22 11:45 PM
Eastern Pa
Eastern Pa
Some more pics
Re: Diesel Dart Cummins [Re: DieselDart73] #3080700
09/25/22 11:50 PM
09/25/22 11:50 PM
Eastern Pa
Eastern Pa
More.
Re: Diesel Dart Cummins [Re: DieselDart73] #3080701
09/25/22 11:51 PM
09/25/22 11:51 PM
Eastern Pa
Eastern Pa
Dyno
