Re: what brand upper control arm to buy
[Re: duckblind]
#1716047
12/26/14 11:43 PM
12/26/14 11:43 PM
moparpollack
Lil Herman
Lil Herman
85086
My guess is A the ball joints are stripped, B the car has aftermarket a arms' or C there are people selling new a arms complete with bushings and ball joints on eBay. Maybe we will get the answer soon.
[Re: duckblind]
#1716049
12/26/14 11:50 PM
12/26/14 11:50 PM
moparpollack
Lil Herman
Lil Herman
85086
From my experience if the ball joint will unscrew they are fine. The problem I have seen are radius rods that are bent and worn out pivots on the lower arm.
[Re: moparpollack]
#1716050
12/26/14 11:59 PM
12/26/14 11:59 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
I've never had an issue with rebuilding the original upper arms.. (As you said, unless the ball joint threads were chewed up I could see replacing them with another old set.) I rather rebuilt some old arms, versus the new oe style, would-have-to-come-from-china-I-guess ones.
[Re: duckblind]
#1716051
12/27/14 12:03 AM
12/27/14 12:03 AM
Challenger 1
Cincinnati, Ohio
I am about to rebuild the front suspension on my 68 charger and am trying to find upper control arms. I want to go with OEM stle. Any suggestions on what brand to buy and where? Thanks.
I know you said OEM style...But IMO you would be very happy with Firm Feel upper control arms because of the added positive caster that they provide. That's my recommendation. I will never put a OEM arm back on ever again after running FF arms.
[Re: OzHemi]
#1716052
12/27/14 12:05 AM
12/27/14 12:05 AM
moparpollack
Lil Herman
Lil Herman
85086
Lucky you, sometimes you get a problem child where the ball joint won't tighten up. You can spot weld them in but it will be the last time.
[Re: moparpollack]
#1716053
12/27/14 12:08 AM
12/27/14 12:08 AM
OzHemi
Garden Grove, CA
Never had a problem with one
Maybe it's the rust?
[Re: jbeintherockies]
#1716058
12/27/14 10:02 AM
12/27/14 10:02 AM
Posts: 4,744 Florida
BDW
Mancini sells these reproduction factory uppers with everything you need for $180: http://www.manciniracing.com/mbmupcoarmse.html
rock auto has them for $142: http://www.rockauto.com/catalog/moreinfo.php?pk=5490240&cc=1078826
If you do it yourself, you need to buy the tool to remove the upper ball joint and I think you need a tool to remove the upper control arm (UCA) bushings. Then you need new ball joints ($20x2) and new UCA bushings ($25x2 if offset bushings), new eccentric bolts, and I think that's it. If I'm missing something or have the moog offset bushings wrong, someone will hopefully correct me.
Me, I bought these jammy-jams: http://www.manciniracing.com/bebofuadupco.html They provide more adjustments than I will ever need.
Great info, this is why I bought aftermarket. Once you add up the cost of the parts & tools and labor (I don't have press), it's a wash.
