Hedman 75340 in a '65 Belvedere? #171599
12/20/08 03:36 PM
12/20/08 03:36 PM
Hertford, England
Dartbloke Offline OP
Hertford, England
I have the chance of a cheap set of Hedman 75340 headers, they are listed for '66 -'70 B bodies. Would they fit a '65 Belvedere? If not why not, all looks pretty much the same as the later cars to me? Wouldn't mind working them a little if I had too...
Re: Hedman 75340 in a '65 Belvedere? [Re: Dartbloke] #171600
12/20/08 03:51 PM
12/20/08 03:51 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
Re: Hedman 75340 in a '65 Belvedere? [Re: smokinwoody] #171601
12/20/08 09:00 PM
12/20/08 09:00 PM
Hertford, England
Hertford, England
I'm not convinced...
Re: Hedman 75340 in a '65 Belvedere? [Re: Dartbloke] #171602
12/20/08 09:07 PM
12/20/08 09:07 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
They might not fit because i think in 66 they moved the engine back 3 inches from wear it was in 65. but if they are cheep enough to you you could always try them anyway. When i had my 65 Plymouth with a 440 i ran some cheep 99 doller 1-3/4 headmans that fit great. but i can not remember the part number off the top of my head.Mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: Hedman 75340 in a '65 Belvedere? [Re: mopar65] #171603
12/21/08 08:49 AM
12/21/08 08:49 AM
metro detroit
turner Offline
turner  Offline
metro detroit
I bought a set of Hedman Elite headers for my 65' Satellite and was fairly happy with the fit, I just ran outside and checked the part # on them and the number said 73038, I would be interested in getting rid of these if your interested, pm me here on Moparts.
Re: Hedman 75340 in a '65 Belvedere? [Re: Dartbloke] #171604
12/21/08 09:57 AM
12/21/08 09:57 AM
i didn't see any 65's listed.
Re: Hedman 75340 in a '65 Belvedere? #171605
12/21/08 11:47 AM
12/21/08 11:47 AM
Hertford, England
Hertford, England
Ah, I didn't realise the motor was further forward on the '65's. This one might have been moved back, it has the running gear out of a later car, maybe the K frame has been changed to a later one? Is there an easy way to check if the motor is in the stock location or not?
Re: Hedman 75340 in a '65 Belvedere? [Re: Dartbloke] #171606
12/21/08 12:52 PM
12/21/08 12:52 PM
The Sunny Shuswap
dodgefarmer Offline
dodgefarmer  Offline
The Sunny Shuswap
The 64/65 K positions the engine about 1 3/4" further ahead than the later 67/70 K. So if a later K is being used the engine will be real tight to the firewall. In my case with trying to run kickdown linkage and a heater, the heater core spiggots interfered with the linkage. Also if the later K is used then the transmission crossmember will have to be modified.
HTH
Randy
Re: Hedman 75340 in a '65 Belvedere? [Re: dodgefarmer] #171607
12/21/08 02:01 PM
12/21/08 02:01 PM
Hertford, England
Hertford, England
Thanks, I'll take a closer look, trans crossmember is not stock, someone fabricated it from scratch....
