I see it a lot but seems wrong #1715525
12/25/14 04:52 PM
12/25/14 04:52 PM
USA
Lawn Monkey Offline OP
USA
Those engine lifting plates that bolt to the intake manifold in place of the carb to lift the engine out, just seems weak but I have seen it a lot on 340 and 440's but never on a Hemi thou, strange. My engine pulls always get big bolts to the intake/head.
Re: I see it a lot but seems wrong [Re: Lawn Monkey] #1715526
12/25/14 05:27 PM
12/25/14 05:27 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
Re: I see it a lot but seems wrong [Re: 6bblgt] #1715527
12/25/14 05:35 PM
12/25/14 05:35 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
N-o
F-easible
W-ay...
That flange was designed to support a carb...
Not balance an elephant...
Re: I see it a lot but seems wrong [Re: RSNOMO] #1715528
12/25/14 05:42 PM
12/25/14 05:42 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
N-o
F-easible
W-ay...
I've used one in the past to pull a HEMI. but regardless of the engine, only a fool would pull a motor relying on just that plate, I always "safety chain/strap" an engine with a back up plan should the plate/hook/etc fail
Re: I see it a lot but seems wrong [Re: DAYCLONA] #1715529
12/25/14 06:24 PM
12/25/14 06:24 PM
Nashville, Tennessee
Tempest Offline
Tempest  Offline
I always use a chain to the heads.
Re: I see it a lot but seems wrong [Re: RSNOMO] #1715530
12/26/14 12:59 AM
12/26/14 12:59 AM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
N-o
F-easible
W-ay...
Proof load for a single grade 2 5/16"-18 bolt loaded in tension is 2900 pounds!
That little steel plate that is bolted to the intake is 1/4" plate? Easily handle that load, probably designed to handle a higher load than the hoist without visible deflection.
Brought to you by the magic of Mechanical Engineering.
-Michael
Michael 1968 Barracuda Notchback Coupe 440 EFI 6-pack, T56 Magnum 6-spd
Re: I see it a lot but seems wrong [Re: 68cuda440] #1715531
12/26/14 01:17 AM
12/26/14 01:17 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
N-o
F-easible
W-ay...
-Michael
Shear/load tension of the bolt means little if the manifolds threads are marginal, or insufficient thread length/engagement is an issue, esp with an aluminum intake!....always use a back up chain or strap that's attached to the lift/picker independent of the lifting hook or chain doing the work/load
Re: I see it a lot but seems wrong [Re: DAYCLONA] #1715532
12/26/14 02:23 AM
12/26/14 02:23 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I always use the plates now. I lost one engine that the chain actually broke and dropped it back in the engine bay. One exhaust stud went through an inner fender well and broke off, the other inner fender was damaged pretty severly.
JB Rhinehart, Realist
A-Body's RULE!
Re: I see it a lot but seems wrong [Re: DAYCLONA] #1715533
12/26/14 02:24 AM
12/26/14 02:24 AM
Alabama
BigMoneyLewis Offline
Alabama
Aluminum is a pretty soft metal . I would NEVER put that much weight on those aluminum threads .
Greg
gregward@mchsi.com phone 256-852-0955
Re: I see it a lot but seems wrong [Re: BigMoneyLewis] #1715534
12/26/14 02:32 AM
12/26/14 02:32 AM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
I bought a kd tool one and the upright flat bar that you hook you crane to broke at the welds. I did get another one but afraid to use it now.
Re: I see it a lot but seems wrong [Re: chrisf] #1715535
12/26/14 10:57 AM
12/26/14 10:57 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I made my own lifting plate when I was 18 years old and have used it for 30 years now on countless motors without a failure.
Used a cutting torch and AC "buzz box' stick welder long before I even knew what a mig welder was. I heated up that cold rolled and wrapped it around a 2" pipe and welded it into a ring, it has never even distorted.
I lifted gasoline truck engines numerous times which are much heavier that any big block motor. I trust it now.
No I would not trust some of those cheaper ones sold. I would re-weld it myself before using one.
I have seen some real unsafe rigging on here with with chains, so pick your poison.
Re: I see it a lot but seems wrong [Re: Challenger 1] #1715536
12/26/14 12:39 PM
12/26/14 12:39 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
I made my own as well since one was not available for the dual quad intake. With 8 bolts it was very secure and it even picked up my Hemi with 727 trans and also with the K-frame attached as it was going on the dolly prior to dropping the body over it. Worked great!
Re: I see it a lot but seems wrong [Re: 68jim] #1715537
12/26/14 01:04 PM
12/26/14 01:04 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I see a bigger potential problem with lifting a Hemi by the carb to intake bolts. The bolts that hold the intake to the heads are small diameter and have a low torque spec. I wouldn't want to risk pulling them out of the heads or worse, breaking away chunks of the heads which has been known to occur just from over torqueing them.
Re: I see it a lot but seems wrong [Re: ScottSmith_Harms] #1715538
12/26/14 03:35 PM
12/26/14 03:35 PM
California
mickm Offline
mickm  Offline
California
i never liked the idea, even though it is an easier way to lift the engine. i asked tim at FHO about it, he said "some shops use them, we don't"
Re: I see it a lot but seems wrong [Re: ScottSmith_Harms] #1715539
12/26/14 05:41 PM
12/26/14 05:41 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I agree with this. I wouldn't do it & never have not with the weight of a Hemi anyway & the smaller 1/4" dia intake bolts. Although, I do have a 4150 & 4500 dominator plates we have used all the time on my buddies engine when pulling them. I don't mind if the Brand X'ers fall on the floor....
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: I see it a lot but seems wrong [Re: Lawn Monkey] #1715540
12/26/14 09:45 PM
12/26/14 09:45 PM
Cincinnati, Ohio
Cincinnati, Ohio
In all the years I have never seen anyone post a picture of where the intake manifold either failed or cracked and the engine fell off. Have never seen it, has anyone had the intake manifold fail from a lifting plate?
I have never lifted a hemi with a plate, I always used a chain because none of my hemis had 4 barrel intake manifolds.
Re: I see it a lot but seems wrong [Re: Challenger 1] #1715541
12/26/14 10:18 PM
12/26/14 10:18 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
I have one that was made for my 440/3x2 Edelbrock and drilled a couple of extra holes to fit my 340/cast iron intake for AVS. I am a little cautious picking up a fully assembled 440-6 but I haven't had any problem. Used it about 10-12 times on two motor jobs for loading, unloading, painting and installing. The 340 seems effortless in comparison. It's difficult to find good balance points for hooking up a chain on a 426 Hemi. I would use a lifting plate if I had one instead of a plain link chain but my chain has some bent plates on the ends that work good for picking up a Hemi. I can say that a fully assemble Hemi bent my extra heavy duty home made engine stand back in the day. You definitely need the right tools for a safe job.
Re: I see it a lot but seems wrong [Re: RoadRunnerJD] #1715542
12/26/14 10:39 PM
12/26/14 10:39 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Uh-huh...
I did engine jobs everyday in the past...
This did the trick...
(Bolted to IRON cylinder heads...)
Re: I see it a lot but seems wrong [Re: RSNOMO] #1715543
12/26/14 10:56 PM
12/26/14 10:56 PM
Warrenton, VA
Warrenton, VA
That's just like mine. I think I got it from Summit Racing. Works fine on a Hemi.
Re: I see it a lot but seems wrong [Re: RSNOMO] #1715544
12/27/14 12:54 AM
12/27/14 12:54 AM
Cincinnati, Ohio
Cincinnati, Ohio
Uh-huh...
I made one just like that 30 years ago at the same time I built my engine lifter plate at my old job. My old boss was handy like that and that's who influenced me back in the day.
Then I loaned it to someone one day, and it never came back to me. I think I know who I loaned it too, but not sure and now the guy does not work for me any more. I rarely loan tools because of this BS.
But yes that is the best design lifting chain because the links can't slide through the lifting hook. And bolting it on with flat plates with the bolts tight in the heads is best. Tighten those bolts don't leave them loose.
