any chrysler mechanics?? please help #171529
12/20/08 03:05 PM
12/20/08 03:05 PM
crlush Offline OP
crlush  Offline OP
I have a 2005 town and country and the battery died so I hooked the charger up and when i turned the charger on the radiator fan turned on with engine cold, so I looked for relay in fusebox but there isnt one so I unpluged the fuse to turn it off and charge battery. was looking for the fan thermo switch(or what ever you call it)hidden on the motor or radiator but cant find it anywhere. If someone knows specificly where it is or if it is something else causing the problem I would be greatly appreciative, sorry this isnt an old mopar question but didnt know where else to go. thanks
Re: any chrysler mechanics?? please help [Re: crlush] #171530
12/20/08 03:49 PM
12/20/08 03:49 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Can't answer why your fan turned on but you should never charge a battery with the cables hooked up.
Re: any chrysler mechanics?? please help [Re: crlush] #171531
12/20/08 04:02 PM
12/20/08 04:02 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm not sure on that year but it could be the after
run fan timer is bad(when you shut the car off the fan
continues to run for X amount of minutes then shuts
off)
Re: any chrysler mechanics?? please help [Re: bboogieart] #171532
12/20/08 04:39 PM
12/20/08 04:39 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Where did you hear that? I think somone misled you. I've been in this businees for 50 years and never had any problems charging a battery with the cables still hooked up.
Re: any chrysler mechanics?? please help [Re: crlush] #171533
12/20/08 06:11 PM
12/20/08 06:11 PM
md,usa
tigger Offline
tigger  Offline
md,usa
the fan relay is mounted on top of the steel bumper behind the front facia. remove the upper radiator support and look down. Looks almost like a lego block.
Re: any chrysler mechanics?? please help [Re: tigger] #171534
12/20/08 07:36 PM
12/20/08 07:36 PM
crlush Offline OP
crlush  Offline OP
thanks tigger i knew it was hidden in there somewhere.
Re: any chrysler mechanics?? please help [Re: tigger] #171535
12/20/08 07:40 PM
12/20/08 07:40 PM
N.J. north west
1972challenger Offline
N.J. north west
I think it's on the drivers side of the radiator. It is usually black with blue sticker and has a 3 or 4 wire connector on it.
Re: any chrysler mechanics?? please help [Re: tigger] #171536
12/20/08 08:40 PM
12/20/08 08:40 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
That should be correct for that year as I just remove the facia to get at it. The relay is controlled by the PCM which just uses the coolant temp sensor readings to turn the fan on. Ron
Re: any chrysler mechanics?? please help [Re: crlush] #171537
12/20/08 09:41 PM
12/20/08 09:41 PM
crlush Offline OP
crlush  Offline OP
thanks all!!!
Re: any chrysler mechanics?? please help [Re: crlush] #171538
12/20/08 10:02 PM
12/20/08 10:02 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
When you do replace the relay it is very important to secure it tight to the mounting area. Heat is displace from the relay to the frame to keep it cool.
