Re: Sub frame connectors
[Re: Dr Dave]
#1714700
12/23/14 06:13 PM
12/23/14 06:13 PM
Posts: 5,394 Pikes Peak Country
TC@HP2
Pikes Peak Country
Hotchkis, Competition Engineering, Mopar Performance, Moroso are all either basic bolt in kits or minimal welding required packages.
Since your car is assembled, it is probably best to install them while sitting on its tires to ensure panel gaps remain consistent and your doors are functional. Normally I'd suggest putting it on 6-8 stands to get everything level, square, and plumb, but with a completed car, you've got all that paint to consider.
[Re: Dr Dave]
#1714704
12/24/14 12:36 AM
12/24/14 12:36 AM
Posts: 841 Santa Fe Springs, CA
Dan@Hotchkis
Hi Dan, please give me the low down on your connectors. What level of chassis stiffness can I expect verses weld in and will they be visible looking at the car from the side, will I lose ground clearance ..... Thanks!
These tie the chassis together on a second plane and tie the rear subframe to the front subframe at the strongest points. They require minimal welding on the B/E cars. The lowest point of the connectors will be at the torque box, and they run about 1/4" from the floorpan. Here are the instructions for them which have a lot of good pictures that will answer a lot of your questions. http://www.hotchkis.net/_uploaded_files/4011S.pdf
[Re: roadrunninMark]
#1714712
12/25/14 04:58 AM
12/25/14 04:58 AM
Posts: 8,089 Sorrento, BC, Canada
4speeds4me
4Speed, those looks nice... don't know how well they will work though, need some experts to take a look at them. Might even be able to make them for less.
I think the seller is here on Moparts, but it's been a few years since I spent much time here...
2 Demons...no, not my kids!
[Re: Dr Dave]
#1714718
12/28/14 07:54 PM
12/28/14 07:54 PM
Posts: 240 Plano, Texas
68cuda440
Plano, Texas
Fastback, looks like yours are not welded to the floor correct? Are you able to park on a bias and still have your doors open easily?
Mine has subframe connectors (welded), torque boxes, 2x2 frame under the radiator, 1x2 frame across f&r of fuel tank for support. I have jacked up the car at the front corner and lifted 3 wheels off the ground... gaps on the doors and fenders did not move. The car is very rigid. Rust free Texas car if that makes any difference.
-Michael
Michael
1968 Barracuda Notchback Coupe
440 EFI 6-pack, T56 Magnum 6-spd
