Re: 1970 RR Auto with a 4Spd pedal bracket ????
[Re: skicker]
#1714632
12/23/14 02:07 PM
12/23/14 02:07 PM
Posts: 2,150 Bristol, CT
RalphsRapidTrnst
Bristol, CT
They all have the firewall reinforcement plate behind the master cylinder. Auto and 4sp alike.
The bracket to the right of the master that supports the 4spd pedal is the question.
[Re: BMChrysler68]
#1714633
12/23/14 02:15 PM
12/23/14 02:15 PM
RalphsRapidTrnst
Bristol, CT
Original floor pedal and column pic1
Did someone's body do that to the steering wheel?
It had to of been damaged when the car spent time in Texas Acres. There is no frame damage that supports a crash that would cause the wheel to collapse like that.
[Re: RalphsRapidTrnst]
#1714634
12/23/14 02:37 PM
12/23/14 02:37 PM
Posts: 1,028 NB, Canada
moparfan53
NB, Canada
I attached the pic below just so everyone understands which piece you are asking about. Is there a fender tag to confirm codes?
[Re: moparfan53]
#1714635
12/23/14 02:46 PM
12/23/14 02:46 PM
Posts: 1,603 Central Ohio
BMChrysler68
Smarter than the average bear? I think not.
Central Ohio
Rust is a weird thing. The heavy gauge stuff looks ultra-crusty with deep pits and corrosion; but the sheetmetal looks to be in decent shape. It's almost like it chose to go after the meatier stuff first. Science.
1968 Plymouth Fury III 2dr FT, 383-4v, 4 speed
1972 AMC Ambassador SST wagon 360-4v, automatic
2014 Challenger R/T Classic 6-speed
#1714636
12/23/14 02:46 PM
12/23/14 02:46 PM
Posts: 8,677 Buford, GA
I_bleed_MOPAR
Buford, GA
I think that some got it regardless of transmission. I've converted several auto trans. cars to 4 spds. and only had to hang the clutch pedal and swap the brake pedal. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: I_bleed_MOPAR]
#1714637
12/23/14 02:49 PM
12/23/14 02:49 PM
BMChrysler68
Central Ohio
Maybe they realized later in production that they could accomplish the same thing with one part #. Or, because the manual trans was standard in the B-body, they had more of them laying around.
This is all assuming that the manual trans assembly is all one piece with two extra bolts in the firewall, of course. I'm not familiar with the B-body assemblies.
[Re: BMChrysler68]
#1714638
12/23/14 02:52 PM
12/23/14 02:52 PM
Posts: 5,138 East Aurora (Buffalo) NY
RoadRunner
I haven't seen them on auto cars for 68 and 69. I would think that the factory wouldn't use the part unless needed. If they could save a few cents by not having that bracket there, they would. Most likely a mistake. Its hard to tell, but is the a bracket welded to the top of the frame rail down under the master cylinder?
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: RoadRunner]
#1714640
12/23/14 03:15 PM
12/23/14 03:15 PM
RalphsRapidTrnst
Bristol, CT
Clean with no signs of ever having the z-bar pivot bracket installed. All of the original auto linkage is still there.
[Re: moparfan53]
#1714641
12/23/14 03:49 PM
12/23/14 03:49 PM
RalphsRapidTrnst
Bristol, CT
When I saw the bracket it excited me to think this was a manual trans RR. When I looked for more evidence and found none, because all of the auto peices are in place with no chance of this being a manual shift RR other than the bracket. I now questioned my beliefs regarding other B-Bodies that I have seen with the bracket.
[Re: okie]
#1714643
12/24/14 12:38 PM
12/24/14 12:38 PM
Posts: 4,285 Ohio
64dodge572
Ohio
I think it was just an assembly line goof up.
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
