Drawing for Hemi & B/RB oil pan rail?
#1714558
12/23/14 04:50 AM
12/23/14 04:50 AM
Posts: 6,148 Melbourne , Australia
LA360
Has anyone got a drawing for the oil pan bolt pattern on a Big Block Chrysler. I would check my Mopar engines book, but it's in storage
Thanks in advance!
Alan Jones
Re: Drawing for Hemi & B/RB oil pan rail?
[Re: go green]
#1714561
12/23/14 10:12 PM
12/23/14 10:12 PM
LA360
I have been sent one by a friend in Sweden (Thanks Tom!)but the file was corrupt. I will try again and if it works out, I will check out that it fits, and I will then send out something to you Go Green. PM me your email address.
Alan Jones
[Re: RT540]
#1714564
12/24/14 10:27 AM
12/24/14 10:27 AM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
The two bolt holes in front and the two at the back didnīt line up when I made an paper copy and tested on my Megablock, so check those out.
Probably make sense. Not dimensioned as they are not drilled and tapped in this process step. Just guessing.
Nice info though, thanks.
[Re: RT540]
#1714565
12/24/14 02:20 PM
12/24/14 02:20 PM
Posts: 16,928 NC
440Jim
NC
here is the drawing that I sent to Alan. I also sent an DWG and DXF also.
I got the PDF drawing from a Moparts member, donīt know where it comes from. The two bolt holes in front and the two at the back didnīt line up when I made an paper copy and tested on my Megablock, so check those out.
I did some quick measurements on a 1977 block and they were within about 0.015" of that drawing. I didn't make an oil pan, but a jig that mounted to the various holes and it fit well between any pair of holes. For example:
Drawing Mine 4.200 4.187 between the holes (large spacing)4-3/16 2.700 2.687 between the holes (small spacing)2-11/16 2.740 2.756 between the holes (ends) ~2-3/4 = 2.750 0.580 0.580 side offset rear holes ~37/64 = 0.578"
I didn't use the front holes, but I just went in the garage and made a quick side offset measurement and 0.460 looks like it matches that drawing (1.140-0.680=0.460). When adding up the spaces, the drawings 4.20 and 2.70 fit better then the fractions I used.
