75 Duster front disc conversion #1714428
12/22/14 11:56 PM
12/22/14 11:56 PM
Harrisburg Pa. 17112
moparmikethree Offline OP
I want to install disc brakes on the front of my 75 Duster. What all parts do I need and from what cars..Can you use disc from a Volare or an Aspen?
Re: 75 Duster front disc conversion [Re: moparmikethree] #1714429
12/23/14 12:04 AM
12/23/14 12:04 AM
the house on the left.
cogen80 Offline
cogen80  Offline
Re: 75 Duster front disc conversion [Re: cogen80] #1714430
12/23/14 12:21 AM
12/23/14 12:21 AM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
73-76 A Body cars with disc brakes.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: 75 Duster front disc conversion [Re: cogen80] #1714431
12/23/14 12:26 AM
12/23/14 12:26 AM
Thank you that's what I was looking for. Merry Christmas!
Re: 75 Duster front disc conversion [Re: moparmikethree] #1714432
12/23/14 12:26 AM
12/23/14 12:26 AM
Phoenix - surface of the sun
nomore65BelvJim Offline
Yes on the Aspen/Volare...F bodies.
Also spindles out from any M, J or late B (73 up). Get the distribution block/prop valve as well.
Will you be getting rid of the small bolt pattern 7-1/4 the car came with?
Re: 75 Duster front disc conversion [Re: nomore65BelvJim] #1714433
12/23/14 12:30 AM
12/23/14 12:30 AM
Yes got rid of the 7 1/4 and put in a 8 1/4 from a 73 Duster
Re: 75 Duster front disc conversion [Re: moparmikethree] #1714434
12/23/14 12:37 AM
12/23/14 12:37 AM
rebuilt calipers are cheap/troublefree. the 73-75 A calipers are 2.60 bore and the '76 A calipers are 2.75 & are identical & are the ones to ask for. The FMJ calipers are all 2.75" & I believe have different hose mounting points & not sure if that is a problem with an A body app or not. No opinion on the FMJ vs A disc spindle old controversy but for calipers ask for the 76 dart ones & you're good (more front bias, always a good thing)
Re: 75 Duster front disc conversion [Re: moparmikethree] #1714435
12/23/14 12:39 AM
12/23/14 12:39 AM
AndyF Offline
AndyF  Offline
The big bearing rotors will slide right on your existing drum knuckles but stock calipers won't bolt on. I used to sell a kit that would add Viper calipers to those late model A-body knuckles. Check with DoctorDiff to see what he has for you these days.
