new rear leaf springs #1714070
12/22/14 04:07 PM
12/22/14 04:07 PM
California
mickm Offline OP
mickm  Offline OP
California
time for new springs. what are the main vendors that sell them?
Re: new rear leaf springs [Re: mickm] #1714071
12/22/14 05:36 PM
12/22/14 05:36 PM
springs n things. ESPO. JC whitney in Chicago. I would suggest 1" more arch than stock
Re: new rear leaf springs [Re: RapidRobert] #1714072
12/22/14 05:39 PM
12/22/14 05:39 PM
California
mickm Offline OP
mickm  Offline OP
California
i bought the stock hemi mopar (made in mexico) springs, and they have held up for a bout 5 years or so. not a good track record. was considering having them re-arced, but that doesn't seem like a good idea, as i assume it's the composition of the metal itself that has them sagging after such a short period of time. so re-arced, they'll just sag again.
i loved the stance the stock springs gave it, not sure i want 1" more than that. i'll talk to them as ESPO and see what they say.
Re: new rear leaf springs [Re: mickm] #1714073
12/22/14 06:51 PM
12/22/14 06:51 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Re: new rear leaf springs [Re: Sunroofcuda] #1714074
12/22/14 07:21 PM
12/22/14 07:21 PM
California
mickm Offline OP
mickm  Offline OP
California
wow, am i seeing this correctly?
ESPO is $250 for the pair of springs.
Eaton is $250 EACH???
Re: new rear leaf springs [Re: mickm] #1714075
12/22/14 08:49 PM
12/22/14 08:49 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
prolly.
Stanley is another good spring manufacturer, but unlike Eaton you can't buy direct.
Here's a listing from a Spring shop in Pennsylvania (who will ship if you can't find a local retailer).
http://www.stengelbros.net/Passenger-Car-Leaf-Springs_c_181.html
Reasons for wearing out are lots of cycles and overloading. Differences in leaf thickness (especially the first two), number of leaves, positions and end shape, are all factors. Bushings and interleaves can wear out too. If that's all thats worn, they are candidates for rebuilding.
Re: new rear leaf springs [Re: Mattax] #1714076
12/22/14 09:05 PM
12/22/14 09:05 PM
MO, USA
Tom Hand Offline
Tom Hand  Offline
MO, USA
Eaton is who I used and you get a good quality spring with great support.
Tom
Re: new rear leaf springs [Re: Tom Hand] #1714077
12/22/14 10:55 PM
12/22/14 10:55 PM
pawling n.y.
cudachas Offline
cudachas  Offline
pawling n.y.
I bought mine through PST and they told me they would be drop shipped from the manufacture which turned out to be Eaton. Been in the car 4 years and have not settled a bit. I'm happy. Yes they are expensive but I feel they were worth it.
Re: new rear leaf springs [Re: cudachas] #1714078
12/23/14 04:54 PM
12/23/14 04:54 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Try calling a HD truck parts supplier in your area & ask them of a good spring supplier. The truck & trailer parts suppliers deal with stuff like this all the time & many times a spring shop will deal with automotive as well as HD applications. The truck parts suppliers are generally more expert in all the parts components than automotive suppliers.
Re: new rear leaf springs [Re: Sunroofcuda] #1714079
12/23/14 06:07 PM
12/23/14 06:07 PM
California
mickm Offline OP
mickm  Offline OP
California
ok, so here's another angle. herb just had his springs re-arched. i was thinking of doing mine as well, but my thought is that the composition of the metal of these springs is inferior, and that is why they sagged in a relatively short period of time.
so if i have them re-arched, won't they just sag again in a number of years?
or maybe the matrix structure of the molecules has settled to what it is going to be, and they will keep the new re-arcing ok?
hmmm....
Re: new rear leaf springs [Re: Tom Hand] #1714080
12/23/14 06:45 PM
12/23/14 06:45 PM
california
sbcjd Offline
sbcjd  Offline
california
I have Eaton rear leaf springs on my Cuda since 1992. Very pleased with them!
Re: new rear leaf springs [Re: mickm] #1714081
12/23/14 07:33 PM
12/23/14 07:33 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
mickm, I've not ever seen re-arched springs hold the re-arch more then a few years, my shop used to be next to a spring shop. His advice was to replace the springs, or at least every other leaf in a pack or they would flatten out in a few years. I think it has something to do with the number of duty cycles the springs go through, because all forms of springs tend to weaken over time. Gene
Re: new rear leaf springs [Re: poorboy] #1714082
12/23/14 08:15 PM
12/23/14 08:15 PM
California
mickm Offline OP
mickm  Offline OP
California
gene, thanks, i was kind of thinking that is what it would be. i was assuming i'd get new ones, just have to decide if i want to go with the ESPO springs, or twice as much for eaton.
Re: new rear leaf springs [Re: mickm] #1714083
12/23/14 08:28 PM
12/23/14 08:28 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Before you pull the trigger,might want to see if the leaves are made of 'imported' steel...
Got 20+ years going on a set that was OEM to the car, re-worked(with an extra leaf added)by a shop here, locally...
They're doing fine...
Re: new rear leaf springs [Re: RSNOMO] #1714084
12/23/14 09:12 PM
12/23/14 09:12 PM
San Francisco Ca
SCATPK Offline
SCATPK  Offline
San Francisco Ca
Mick, remember i did rearch my factory springs this year, but i had them done once before over 20 years ago. As said i also had a couple of leafs added and with all of the action my car has seen i would 20+ years on my original rearch was money well spent. Did you talk to Mike about getting the number to the truck spring shop in the east bay and discuss with them? I would explain what your after and see what they say. As said the truck guys know all about what works and what does not. If you go new go with Eaton as you drive and haul people around with your car and not use it as a stage prop at the local car shows.
Re: new rear leaf springs [Re: SCATPK] #1714085
12/23/14 10:22 PM
12/23/14 10:22 PM
California
mickm Offline OP
mickm  Offline OP
California
herb, but yours are factory springs, mine are mopar springs made in mexico. people have said for a while these springs aren't the best. so we are talking two different qualities of metal here, i'm sure.
i did call them, but only got a woman on the phone who had no clue as to what i was talking about. i said i had a question about springs, guess i should call back and politely ask to speak with someone more knowledgeable.
i'm pretty sure i'm just going to bite the bullet and get the eaton springs. rearching is $225 or so, iirc, so it's double that to get the eaton springs and be done with it.
Re: new rear leaf springs [Re: mickm] #1714086
12/24/14 01:32 AM
12/24/14 01:32 AM
San Francisco Ca
SCATPK Offline
SCATPK  Offline
San Francisco Ca
Mick, sounds like you got the wrong person on the phone over there. But if you do go new sounds like the eatons are the way go. I would ask about the metal used in their springs and ask how long you should expect them to hold things up before sagging. Sucks that the springs you have had only been in use for 5 years or so. Let me know if you need a hand or want to use the rack at the warehouse.
Re: new rear leaf springs [Re: mickm] #1714087
12/24/14 01:36 AM
12/24/14 01:36 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
"or maybe the matrix structure of the molecules has settled..."
Whoa, whoa... We are MOPAR guys, not astronauts.
Re: new rear leaf springs [Re: Kern Dog] #1714088
12/24/14 02:03 AM
12/24/14 02:03 AM
Indiana
68_661charger Offline
Indiana
I used the Eaton +1 springs on my 68 Charger about 3 years ago and havn't noticed any sagging so I'd recommend them too. I don't know about the other brands.
Re: new rear leaf springs [Re: mickm] #1714089
12/24/14 02:56 AM
12/24/14 02:56 AM
NorCal
fatsat Offline
fatsat  Offline
NorCal
Anyone have experience with General Spring? I was checking out their prices awhile back...
http://www.generalspringkc.com/SearchRes...amp;f-1970=2889
