Engine/tranny/k-member install cradle #1713874
12/22/14 01:05 AM
12/22/14 01:05 AM
Mesa, Arizona
dart4forte Offline OP
Mesa, Arizona
Looking for a cradle to mount k- member with engine and trans. Needs to roll. Any vendors that sell something like that?
Re: Engine/tranny/k-member install cradle [Re: dart4forte] #1713875
12/22/14 12:46 PM
12/22/14 12:46 PM
Mesa, Arizona
Mesa, Arizona
Re: Engine/tranny/k-member install cradle [Re: dart4forte] #1713876
12/22/14 12:57 PM
12/22/14 12:57 PM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
I made one easily and cheaply with two furniture dollies and scrap 2x4's. It worked well for my limited use. I'm sure that there are venders that sell them. It probably just depends on much use it's going to have over it's lifetime.
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: Engine/tranny/k-member install cradle [Re: FJR doc] #1713877
12/22/14 01:02 PM
12/22/14 01:02 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
The couple I've seen I don't know where they came from or if they're homemade. Neither was worth a crap as it was designed to hold the K and the subsequent engine and trans but was built that it was in the way to do an engine install from the bottom.
It would have been fine as a run stand or something but wasn't quite what I was looking for at the time.
You're better off to just build your own to do what you need.
...FAFO...
Re: Engine/tranny/k-member install cradle [Re: FJR doc] #1713878
12/22/14 01:36 PM
12/22/14 01:36 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
That works.
I use a single large furniture dolly. Under $20 at Harbor Freight.
I screwed a 2x6 across each short end to raise it up a bit and rest the K on one end and the trans pan on the other. I also use the dolly for storage of just the engine/trans.
Re: Engine/tranny/k-member install cradle [Re: dart4forte] #1713879
12/22/14 04:09 PM
12/22/14 04:09 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
You don’t weld, correct?
Re: Engine/tranny/k-member install cradle [Re: 64Post] #1713880
12/22/14 05:48 PM
12/22/14 05:48 PM
Mesa, Arizona
Mesa, Arizona
Not if I have to. I saw the one on Graveyard cars which looked like what I had in mind
Re: Engine/tranny/k-member install cradle [Re: dart4forte] #1713881
12/22/14 07:02 PM
12/22/14 07:02 PM
AndyF Offline
AndyF  Offline
US Car Tool sells them
Re: Engine/tranny/k-member install cradle [Re: dart4forte] #1713882
12/22/14 07:06 PM
12/22/14 07:06 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
If you decide you want to do some welding… This has worked for me for 15+ years.
Re: Engine/tranny/k-member install cradle [Re: 64Post] #1713883
12/22/14 07:17 PM
12/22/14 07:17 PM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
Weld up your own if you can!!!!
Admiration For Multiple Carburetor Vehicles...
Re: Engine/tranny/k-member install cradle [Re: Stewpar] #1713884
12/22/14 07:38 PM
12/22/14 07:38 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
I used a large and small HF moving dolly.
You could also tie them together with a couple of 2x's
Weld one up if you have the ability.
Re: Engine/tranny/k-member install cradle [Re: RobX4406] #1713885
12/22/14 09:30 PM
12/22/14 09:30 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Homemade copy of the U.S. tool one, about $60 worth of steel.
Careful, your character's showing!
Re: Engine/tranny/k-member install cradle [Re: mopar346] #1713886
12/24/14 06:08 PM
12/24/14 06:08 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
This is the one that I have. It's from Dutch Brothers / Crazy Eight Lifts. I got 5+ years ago at "Spring Fling" in Van Nuys, CA. Haven't seen them there in many years and don't know if they are still around.
It also included a set of casters which bolted to the front bumper bracket area and allowed the car to be lifted / tipped using a cherry picker. This allowed the engine/tranny and front suspension to be installed from underneath.
It's a sweet unit.
Re: Engine/tranny/k-member install cradle [Re: dart4forte] #1713887
12/24/14 06:48 PM
12/24/14 06:48 PM
Annapolis, MD, USA
V
Vert Offline
Vert  Offline
V
Annapolis, MD, USA
I like this one
Re: Engine/tranny/k-member install cradle [Re: Vert] #1713888
12/24/14 06:49 PM
12/24/14 06:49 PM
Annapolis, MD, USA
V
Vert Offline
Vert  Offline
V
Annapolis, MD, USA
