Re: Gen 3 Hemi map sensor with MSD hemi 6
[Re: biff426]
#1713592
12/22/14 01:04 PM
12/22/14 01:04 PM
Posts: 412 Portersville, Pa
1badx
Portersville, Pa
Post a pic of the MAP sensor and your wiring harness connector
OST Dyno - Home of the worlds Quickest and Fastest Supercharged Hellcat! Building and tuning record setting Gen III Hemi’s since 2006!
[Re: biff426]
#1713594
12/23/14 01:14 AM
12/23/14 01:14 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
That is the 06-08 Map. 06-11 6.1 Map.
Mopar to the bone!!!
[Re: biff426]
#1713596
12/23/14 01:52 AM
12/23/14 01:52 AM
72Swinger
Nebraska
The MAP and plug in your picture work together? What MAP are you trying to use in the Mudman?
[Re: biff426]
#1713599
12/23/14 02:48 PM
12/23/14 02:48 PM
1badx
Portersville, Pa
If I'm not mistaken it looks like you can shave the "ears" off of the MAP sensor and it will slide into you plug. I'll grab a few MAP sensors later today when I get to the shop and see what they look like. It's not uncommon for me to have to shave the "ears" off of a 2 or 3bar SRT4 MAP to fit a stock 6.1 harness.
[Re: 1badx]
#1713601
12/23/14 04:58 PM
12/23/14 04:58 PM
Posts: 52,972 Romeo MI
MR_P_BODY
No it wont.. if you look down into the map it has a squareish hole and the plug has a radius
[Re: 72Swinger]
#1713602
12/23/14 05:19 PM
12/23/14 05:19 PM
MR_P_BODY
Sorry I see the difference now, they must of changed the plug-ins in 09, im guessing here, on the 6.1's even though the engine and intakes were not. This is mine and it is what you want, 06 300 SRT8 map sensor. My engine uses sensors from that car on my build.
I think the map you show here is right... or damn close
[Re: biff426]
#1713604
12/23/14 11:01 PM
12/23/14 11:01 PM
MR_P_BODY
Why not use a remote map.. run a hose to it.. just get one that plugs in EDIT I dont know if you tried.. but take the map into the parts store and see if anything will match.. at least the plug part
