Gen 3 Hemi map sensor with MSD hemi 6 #1713589
12/21/14 05:28 PM
12/21/14 05:28 PM
Deland, Florida
biff426 Offline OP
biff426  Offline OP
Deland, Florida
I am having issues coming up with a map sensor that will fit the Modman manifold opening and plug into the hemi 6 wire harness I have the late model harness I bought a map for a 2006-09 6.1 but the harness does not work but it fits the intake opening
Re: Gen 3 Hemi map sensor with MSD hemi 6 [Re: biff426] #1713590
12/22/14 08:48 AM
12/22/14 08:48 AM
Melbourne.....Oz-land
Moparmal Offline
Moparmal  Offline
Thats weird because my later MSD6013 harness plugged straight onto my 6.1 crate motor MAP SENSOR.
I hate to say this....but are you sure they sent you the correct harness?
What I did find is that I had to change the 6.1 crank and cam sensors to the 5.7 type....but not the MAP........
Re: Gen 3 Hemi map sensor with MSD hemi 6 [Re: Moparmal] #1713591
12/22/14 11:12 AM
12/22/14 11:12 AM
Deland, Florida
biff426 Offline OP
biff426  Offline OP
Deland, Florida
I changed the crank and cam sensors to the 5.7 type the harness plugs into the coils fine and the plugs into the 5.7 cam and crank sensor fine but the plug for the map does not work.
Re: Gen 3 Hemi map sensor with MSD hemi 6 [Re: biff426] #1713592
12/22/14 02:04 PM
12/22/14 02:04 PM
Portersville, Pa
1badx Offline
1badx  Offline
Portersville, Pa
Post a pic of the MAP sensor and your wiring harness connector
Re: Gen 3 Hemi map sensor with MSD hemi 6 [Re: 1badx] #1713593
12/23/14 01:38 AM
12/23/14 01:38 AM
Deland, Florida
biff426 Offline OP
biff426  Offline OP
Deland, Florida
Here is what I have
Re: Gen 3 Hemi map sensor with MSD hemi 6 [Re: biff426] #1713594
12/23/14 02:14 AM
12/23/14 02:14 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
That is the 06-08 Map. 06-11 6.1 Map.
Mopar to the bone!!!
Re: Gen 3 Hemi map sensor with MSD hemi 6 [Re: 72Swinger] #1713595
12/23/14 02:25 AM
12/23/14 02:25 AM
Deland, Florida
biff426 Offline OP
biff426  Offline OP
Deland, Florida
Ok what I am looking for is a map that uses that plug but mounts like the map in the picture anybody have a part number or application it fits?
Re: Gen 3 Hemi map sensor with MSD hemi 6 [Re: biff426] #1713596
12/23/14 02:52 AM
12/23/14 02:52 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
The MAP and plug in your picture work together? What MAP are you trying to use in the Mudman?
Re: Gen 3 Hemi map sensor with MSD hemi 6 [Re: biff426] #1713597
12/23/14 08:40 AM
12/23/14 08:40 AM
Moparmal Offline
Moparmal  Offline
72Swinger...so for clarity............you are saying that the plug and sensor pictured SHOULD connect no problem?
Re: Gen 3 Hemi map sensor with MSD hemi 6 [Re: Moparmal] #1713598
12/23/14 11:41 AM
12/23/14 11:41 AM
Deland, Florida
biff426 Offline OP
biff426  Offline OP
Deland, Florida
These do not plug together the map in the picture is for a 09 6.1 an d will fit the intake the harness is the late model harness for the 6.1 coils I am ready to just plug the holes in the intake and say screw it I probably won't even use the map as an input but would like the option
Re: Gen 3 Hemi map sensor with MSD hemi 6 [Re: biff426] #1713599
12/23/14 03:48 PM
12/23/14 03:48 PM
Portersville, Pa
1badx Offline
1badx  Offline
Portersville, Pa
If I'm not mistaken it looks like you can shave the "ears" off of the MAP sensor and it will slide into you plug. I'll grab a few MAP sensors later today when I get to the shop and see what they look like. It's not uncommon for me to have to shave the "ears" off of a 2 or 3bar SRT4 MAP to fit a stock 6.1 harness.
Re: Gen 3 Hemi map sensor with MSD hemi 6 [Re: 1badx] #1713600
12/23/14 04:38 PM
12/23/14 04:38 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Sorry I see the difference now, they must of changed the plug-ins in 09, im guessing here, on the 6.1's even though the engine and intakes were not. This is mine and it is what you want, 06 300 SRT8 map sensor. My engine uses sensors from that car on my build.
Re: Gen 3 Hemi map sensor with MSD hemi 6 [Re: 1badx] #1713601
12/23/14 05:58 PM
12/23/14 05:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
No it wont.. if you look down into the map it has a
squareish hole and the plug has a radius
Re: Gen 3 Hemi map sensor with MSD hemi 6 [Re: 72Swinger] #1713602
12/23/14 06:19 PM
12/23/14 06:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I think the map you show here is right... or damn close
Re: Gen 3 Hemi map sensor with MSD hemi 6 [Re: MR_P_BODY] #1713603
12/23/14 11:52 PM
12/23/14 11:52 PM
Deland, Florida
biff426 Offline OP
biff426  Offline OP
Deland, Florida
I took the map I have back to order the 06 300 srt8 one and guess what the one I have is suppose to fit that application screw it I am plugging the holes and not using a MAP
Re: Gen 3 Hemi map sensor with MSD hemi 6 [Re: biff426] #1713604
12/24/14 12:01 AM
12/24/14 12:01 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Why not use a remote map.. run a hose to it.. just
get one that plugs in
EDIT
I dont know if you tried.. but take the map into the
parts store and see if anything will match.. at least
the plug part
Re: Gen 3 Hemi map sensor with MSD hemi 6 [Re: MR_P_BODY] #1713605
12/24/14 03:00 PM
12/24/14 03:00 PM
MN
hemidup Offline
hemidup  Offline
MN
EDIT
the plug part
Thats what I did. I drilled and tapped my G3 XV intake, then installed a brass fitting, push a rubber line on to it and inserted the map sensor into that. Using either a 2 bar or 3 bar Mopar map sensor I did have to trim off the plastic tab so it would couple properly to the harness.
Jerry Williams.
Re: Gen 3 Hemi map sensor with MSD hemi 6 [Re: hemidup] #1713606
12/24/14 04:04 PM
12/24/14 04:04 PM
Portersville, Pa
1badx Offline
1badx  Offline
Portersville, Pa
Not sure if this will help - here are some pics of the MAP sensor harness connector with a 2bar SRT4 MAP and then a picture comparing the SRT4 MAP with a 5.7 truck MAP
Re: Gen 3 Hemi map sensor with MSD hemi 6 [Re: biff426] #1713607
12/25/14 08:57 PM
12/25/14 08:57 PM
Moparmal Offline
Moparmal  Offline
Mine was 2010 crate motor and the sensor plugged in perfect.....maybe ask for that model year?
