positive batte cables #1713569
12/21/14 03:20 PM
12/21/14 03:20 PM
SE Pa.
LimeliteAero Offline OP
SE Pa.
I was looking through some boxes of parts and found I may not be thrilled with my positive battery cable.
Does anyone have a good source for quality battery cables?
I thought I picked up a "good" piece but after further review, I may not have.
Shouldnt the cable have different colored red cables at the terminal? Im working on a 70 B body with a wedge.
TIA!
Re: positive batte cables [Re: LimeliteAero] #1713570
12/21/14 06:21 PM
12/21/14 06:21 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
If it has to be OEM Gold correct, NOS will be your best choice for the closest replacement, exect to spend some $$$...even the rebops are priced all over the place...try Dixie parts for the best price on a quality replacement
Mike
Re: positive batte cables [Re: LimeliteAero] #1713571
12/21/14 09:47 PM
12/21/14 09:47 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Chrysler parts book lists part# 2926085 for '70 B body with BB (same part# also shown for '68 & '69). Bill Rolik has one described as "concours-correct " for $137. Maybe compare price and photo to ones sold by Moparts sponsors?
http://www.billrolikenterprises.com/proddetail.asp?prod=2926085-S
If by "different colored red cables" you mean two shades of red, I have not heard of that.
Re: positive batte cables [Re: moparfan53] #1713572
12/22/14 05:43 AM
12/22/14 05:43 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
For documentation of two different shades of red, go to:
http://www.iccahome.org/
Click on "Engine Compartment", and scroll 3/4 down page to blue '70 GTX battery cable and click on this image.
"Original positive battery cable: The small wire is brighter red in color than the large wire."
Restorer Jeff Lilly has said to watch out for cables that are normal O.D. but copper undersized - the plastic sheath is extra thick to fool the buyer...
Re: positive batte cables [Re: kentj340] #1713573
12/22/14 03:31 PM
12/22/14 03:31 PM
SE Pa.
SE Pa.
Thanks everyone!
Hey Mike do you have any leads on an NOS part?
Re: positive batte cables [Re: LimeliteAero] #1713574
12/22/14 03:58 PM
12/22/14 03:58 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Thanks everyone!
You really have to troll ebay if you want NOS, knowing the P/N will help plenty too.
Ron
http://www.ebay.com/sch/i.html?_odkw=NOS...le&_sacat=0
Re: positive batte cables [Re: kentj340] #1713575
12/22/14 05:05 PM
12/22/14 05:05 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Kent; thanks for the info. Another bit of Mopar trivia learned!
- Alan
Re: positive batte cables [Re: moparfan53] #1713576
12/22/14 06:59 PM
12/22/14 06:59 PM
People's Republic of Kali
70runner Offline
70runner  Offline
IIRC, 2926085 is the over the counter replacement for the pos battery cable. 2926754 (which does not show up in partsbooks, at least it doesn't in my 70) is the cable that was installed on 69 & 70 b bodies 383/440.
Badalson wrote an article about this not too long ago.
Re: positive batte cables [Re: 70runner] #1713577
12/22/14 09:09 PM
12/22/14 09:09 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
1969 and 1970 B body are like cables ,,but 1968 was different
Finding a true NOS B body cable is going to be like finding hens teeth
Megaparts and RPM Restoration parts carries the same cable I used to stock.
Dixie carries the same cable as Frank Badalson if I remember right,,pretty sure it's the one made by M+H
Avoid the one made by Antique Battery and the one made by Goodmark.( IF,,, they even still make it ) Both were severly undersized gauge wire and will cause issues down the road
Re: positive batte cables [Re: gtx6970] #1713578
12/22/14 10:01 PM
12/22/14 10:01 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Whats different about the 68 cable? I have an NOS one like the split starter connection cable that is in the Rolik link I bought a long time ago.
Re: positive batte cables [Re: JohnRR] #1713579
12/22/14 10:11 PM
12/22/14 10:11 PM
Mass
charge70 Offline
charge70  Offline
Mass
That is the difference.68 used the split design at the starter motor.69 & 70 used a connector that was molded as one piece.In the parts book they all share the same part# 68-70.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: positive batte cables [Re: charge70] #1713580
12/23/14 01:18 PM
12/23/14 01:18 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Thanks , I didn't know that I figured it was a cable made in the 80's .
