67 Dart grill redo #1713549
12/21/14 02:26 PM
12/21/14 02:26 PM
Ky.
dart67 Offline OP
dart67  Offline OP
Ky.
Can someone tell me the steps and how to re-do my grill on a 67 Dart. I want to brighten up the metal and re-paint the black areas.
Thanks, Kevin
Re: 67 Dart grill redo [Re: dart67] #1713550
12/21/14 03:27 PM
12/21/14 03:27 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Time consuming but did this with my 67 grill. Clean with diluted Muric acid. This wil get the metal cleaned of dirt, paint etc. Dd this in a well ventilated area. Wear good rubber gloves. Water will dilute the acid so make sure the grill is well rinsed.
Go ahead and paint the entire grill with flat black. Once it's dried the hard part begins. Use a lot of clean rags. Take cue tips dipped in a paint remover and clean off the areas of the grill that are suppose to show bare metal. Very tedious but you'll like the results. You may have to touch up using a paint pen. You can get that at a hobby shop.
Some others may want to chime in with different techniques.
Re: 67 Dart grill redo [Re: dart4forte] #1713551
12/21/14 10:33 PM
12/21/14 10:33 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I know that the upper and lower grill needs to have the rivets drilled out first to do it right. I did that and then used oven cleaner to remove the anodizing then send it out for re-andodizing, then mask for paint and finally rivet it back together.
JB Rhinehart, Realist
A-Body's RULE!
