2002 Ram 1500 4.7 ENGINE SWAP #1713414
12/20/14 11:58 PM
12/20/14 11:58 PM
Big Wonderful Wyoming!
toomanymopars Offline OP
Has anyone ever attempted or successfully installed a 4.7 engine from a 07 into a 02 Ram 1500? What all DOES fit or needs traded to make it work? What other years will work without a lot of grief....
This was sure an engineering marvel...you would think that Chrysler would have learned after the 2.7 Intrepid fiasco.
Re: 2002 Ram 1500 4.7 ENGINE SWAP [Re: toomanymopars] #1713415
12/21/14 04:20 AM
12/21/14 04:20 AM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
What is in there now?
Leave the gun.......take the Cannoli's....Mike
Re: 2002 Ram 1500 4.7 ENGINE SWAP [Re: mike s] #1713416
12/21/14 10:29 AM
12/21/14 10:29 AM
Has a 4.7 now
Re: 2002 Ram 1500 4.7 ENGINE SWAP [Re: toomanymopars] #1713417
12/21/14 02:18 PM
12/21/14 02:18 PM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
I don't know the exact years, but the main difference between 4.7l engines is the crank sensor tooth count. The earlier engines use a 16 tooth wheel (first couple years) and the rest use a 32 tooth wheel.I'm sure everything else can be swapped over.
Re: 2002 Ram 1500 4.7 ENGINE SWAP [Re: moretoys] #1713418
12/21/14 02:24 PM
12/21/14 02:24 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
2002 was the change year.You will not be able to fire both spark plugs running the old computer.Fly by wire if the 07 had it will be another issue.
Re: 2002 Ram 1500 4.7 ENGINE SWAP [Re: mike s] #1713419
12/21/14 03:03 PM
12/21/14 03:03 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
My 03 must be early production. It has single plugs.
Kevin
