Re: Monte Smith ? [Re: MR_P_BODY] #1713353
12/21/14 06:31 PM
12/21/14 06:31 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
I understand what your saying.. If you find out what
the car runs the fastest THEN you take the reading
so its easy to get back to that A/F reading.. we have
found that a engine runs the best(for power) somewhere
around 12.5-13.0(but not always) so the O2 doesnt know
where the peak is at
Exactly....some intakes are worse about distributing fuel unequally to each cylinder so they have to be richer to compensate and get enough fuel to the leanest cylinders....I remember someone telling me that on one of Dudek's older FAST builds he had to be in the high 10's A/F for max power....
If you can't handle the truth, you're living a lie.......
Re: Monte Smith ? [Re: Big Squeeze] #1713354
12/21/14 06:48 PM
12/21/14 06:48 PM
MR_P_BODY Offline OP
A buddy of mine owns Dudeks car and Dave was with him
on DW.. they had a HARD time trying to find power
in the heat... I heard yesterday that HRM was doing
a big pic display and interview on the car of it on
DW.. I was surprised as how poorly it ran.. but its
one of the FAST cars
Re: Monte Smith ? [Re: MR_P_BODY] #1713355
12/21/14 07:18 PM
12/21/14 07:18 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
My Dart liked the Fast EZ Efi at 11.8 AFR WOT. The difference between that and 12.2 were noticeable.
Mopar to the bone!!!
Re: Monte Smith ? [Re: 72Swinger] #1713356
12/21/14 07:23 PM
12/21/14 07:23 PM
I hear ya.. there is no magic number like a few
on here think there is
Re: Monte Smith ? [Re: 72Swinger] #1713357
12/21/14 07:33 PM
12/21/14 07:33 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
On the engine dyno, mine was in the 12.1 to 12.4 range for best power and that was testing with 3 different intakes and two different carbs.
Re: Monte Smith ? [Re: MR_P_BODY] #1713358
12/21/14 07:59 PM
12/21/14 07:59 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
A narrowband sensor will tell you if the ratio your running is making the engine happy. I had the benefit of running both a narrow and wide band sensor at the same time. I found the ratios my engine liked were dynamic... Generally richer below tq peak rpm, and leaning as rpm would rise.
A narrow band sensor will not have any "true" value as a ratio indicator, only as a "happy" monitor.
As an example, lets say I'm running the engine at a wide band confirmed 12:1 ratio. I look at the data logs, and look at the narrow band output voltage. If you see amplitude spikes(high/low) the engine wants something different. Add some fuel, log it, than look at the amplitude again. If the voltage line is smoother, keep moving in that direction. If its worse, go the other way. A smooth output voltage line is the goal. Just ignore any other part of the info you get from this. voltage value is of no value with a narrow band outside of 14.64:1 ratios.
Bottom line.. A wideband will tell you where you are. A narrow band will tell you if you should be there!
Re: Monte Smith ? [Re: TRENDZ] #1713359
12/21/14 08:11 PM
12/21/14 08:11 PM
I never tried to run a narrow band on a race engine
but it might be something to look at
Re: Monte Smith ? [Re: MR_P_BODY] #1713360
12/21/14 08:39 PM
12/21/14 08:39 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Our 4 stage, dry nitrous 738 runs to a target A/F ratio of 12:8.1. That's where it runs the best and the plugs come out REALLY clean. Richer slows it down. We have been 178 in the 1/8 on 4 small kits
Monte
Re: Monte Smith ? [Re: Monte_Smith] #1713361
12/21/14 08:48 PM
12/21/14 08:48 PM
Monte
Monte.. read up a few post and see what I said about
the Global down load.. thanks
