67-69 stock dart hood with bumps #1713264
12/20/14 08:52 PM
12/20/14 08:52 PM
Ky.
dart67 Offline OP
dart67  Offline OP
Ky.
I have a chance to pick up a hood with the long narrow bumps, one on each side of the hood, for my 67 dart. The inserts are gone. Anyone know if I can buy the inserts separate and where? Not lookin for original if there is a cheaper aftermarket alternative. This is far from a high dollar car.
Thanks, Kevin
Re: 67-69 stock dart hood with bumps [Re: dart67] #1713265
12/20/14 09:13 PM
12/20/14 09:13 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
Thanks, Kevin
I see them for 68-69 dart at Classic industries but they are over $300 ! maybe a decent used set on Ebay or check the parts swap on here.
Re: 67-69 stock dart hood with bumps [Re: mikemee1331] #1713266
12/20/14 10:58 PM
12/20/14 10:58 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
I have gotten a few sets at shows for $30-50 not perfect mind oyu but good driver quality.
Careful, your character's showing!
Re: 67-69 stock dart hood with bumps [Re: mopar346] #1713267
12/21/14 12:12 AM
12/21/14 12:12 AM
Ky.
dart67 Offline OP
dart67  Offline OP
Ky.
Thanks! Driver quality is all I want. Granny car. The hood has a huge hole cut in it and will need to weld it up.
Re: 67-69 stock dart hood with bumps [Re: dart67] #1713268
12/21/14 01:42 AM
12/21/14 01:42 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Which inserts are you going to get?, 67 didn't come with the bulge hood. 68 and 69 are different.
Re: 67-69 stock dart hood with bumps [Re: JohnRR] #1713269
12/21/14 01:44 AM
12/21/14 01:44 AM
Ky.
dart67 Offline OP
dart67  Offline OP
Ky.
It doesn't matter which. Just trying to fill the area so it looks normal.
Not sure if what i can get is a 8 or 9.
Re: 67-69 stock dart hood with bumps [Re: dart67] #1713270
12/21/14 01:55 AM
12/21/14 01:55 AM
mopar346 Offline
mopar346  Offline
The sets I was referring to are 69s, 68s are generally more expensive from what I have run accross, argueably cooler looking.
Re: 67-69 stock dart hood with bumps [Re: mopar346] #1713271
12/21/14 02:17 AM
12/21/14 02:17 AM
Ky.
dart67 Offline OP
dart67  Offline OP
Ky.
Are the hood openings the same and the inserts different from 8-9?
Re: 67-69 stock dart hood with bumps [Re: dart67] #1713272
12/21/14 02:31 AM
12/21/14 02:31 AM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
'68 and '69 hoods are the same. Inserts look different but will interchange.
Re: 67-69 stock dart hood with bumps [Re: Ramrod39] #1713273
12/21/14 10:37 PM
12/21/14 10:37 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
68 and 69 hoods are not the same. The underhood bracing is different as the 69 had crumple zones and three holes punched in the drivers side for the DODGE emblem for the 340 Swinger. Of course the holes are also different between the 68 GTS letters (3 sets of holes), the 69 GTS letters, only two holes, and the 69 Swinger holes. Besides they are the same...
JB Rhinehart, Realist
A-Body's RULE!
Re: 67-69 stock dart hood with bumps [Re: Rhinodart] #1713274
12/23/14 01:23 AM
12/23/14 01:23 AM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
I stand corrected.
I just knew that you could swap a '69 hood onto a '68 and vice versa.
Re: 67-69 stock dart hood with bumps [Re: Ramrod39] #1713275
12/23/14 01:36 AM
12/23/14 01:36 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I get a bit anal with 67-69 Dart parts...
A-Body's RULE!
Re: 67-69 stock dart hood with bumps [Re: mopar346] #1713276
12/23/14 09:16 AM
12/23/14 09:16 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
I like the '69 inserts myself, to each their own!
"I think its got a hemi"
Re: 67-69 stock dart hood with bumps [Re: gdonovan] #1713277
12/23/14 11:45 AM
12/23/14 11:45 AM
mopar346 Offline
mopar346  Offline
I think I like 69s better too but that is why I said argueably cause I know some have a different view, you gotta admit the 68s are cool.
