Re: Problem at the machine shop
[Re: Twostick]
#1713034
12/20/14 05:00 AM
12/20/14 05:00 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
buy 72-73 340 pistons, there compression height is .100 less then the 68-71 340 piston.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#1713035
12/20/14 09:29 AM
12/20/14 09:29 AM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Sounds like you have a 360 stroke crank with a 340 compression height piston.
A 340 with standard ch pistons should not stick out .100 on a 9.53 block. That is only .050" shorter than stock.
What is the CH on the new pistons? 3.31 stroke divide by 2, 1.655". Add that to your rod length, should be 6.123", 7.778". Subtract this number from you deck height. That will be the tallest ch you can use.
[Re: JohnRR]
#1713037
12/20/14 02:28 PM
12/20/14 02:28 PM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
Weren't the stock 68-71 pistons positive deck? +.020 or so IIRC
Leave the gun.......take the Cannoli's....Mike
[Re: 70AARcuda]
#1713038
12/20/14 02:34 PM
12/20/14 02:34 PM
Posts: 316 Utah
dragnduster
Utah
It has been along time since I built a 340, but if I remember correctly the 68-71 340 piston had a stock positive deck height of .045. If you block has been decked down to 9.538 then it is approx .062 shorter than stock which would make the 68-71 piston stick approx .107 out of the hole. My figures may be off slightly but if you put the 72-73 piston in which is .100 shorter you should be near a zero deck.
[Re: rickb67]
#1713041
12/21/14 01:56 AM
12/21/14 01:56 AM
Posts: 714 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
What was the compression height of the old pistons?
Without Data, you’re just another guy with an opinion.
[Re: rickb67]
#1713042
12/21/14 02:09 PM
12/21/14 02:09 PM
Posts: 13,189 aZLiViN
J_BODY
aZLiViN
Had a 73 340 sitting in corner of garage and picked up a 80 step side 2wd. Tore down the engine 2 cylinders bad . Took everything to machine shop.Needs bored crank turned rods balanced.So I order .060 over pistons and get a call the pistons are out of the block .100. well that won't work.I ordered Kieth Black pistons. Deck height is 9.538. need ideas. this was to be a cheep build ha ha.
what machine shop? I've had B&M do 3 engines and they all worked very well.
[Re: cudaman1969]
#1713044
12/21/14 02:23 PM
12/21/14 02:23 PM
Quicktree
just use a thicker head gasket(multiple layer gaskets can go up to 1/4 inch) deck height will be back where the intake fits.
you could probably buy a new block for what it would cost
[Re: Quicktree]
#1713045
12/21/14 02:35 PM
12/21/14 02:35 PM
Posts: 8,265 fredericksburg,va
cudaman1969
fredericksburg,va
about the price of those new pistons
[Re: rickb67]
#1713047
12/21/14 08:50 PM
12/21/14 08:50 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Pistons + lathe + 1 hour = fixed
