Re: 9-1/4" rear question
[Re: Stanton]
#1712617
12/19/14 04:18 PM
12/19/14 04:18 PM
Posts: 25,849 Rio Linda, CA
John_Kunkel
Rio Linda, CA
When in doubt the casting number might help.
7-1/4
2070051 3507881 3723675
8-1/4
2852905 3723598 3723599
8-3/4
1820657 (small stem, up to 1964) 2070741 (small stem, 1965 and later) 1634985 (large stem, up to 1964) 2070742 (large stem, 1957-1968) 2881489 (tapered pinion, 1969-1971)
9-1/4
3507890 3507891 3723199
[Re: Stanton]
#1712620
12/20/14 11:42 AM
12/20/14 11:42 AM
Posts: 15,487 Florida
scratchnfotraction
Yes, that's the thread I was looking for.
So this still has me baffled. It doesn't appear to be a 9-1/4 as it only has 10 bolts. But it doesn't look like an 8-1/4 either - no plug and the cover is round, not oval. Its definitely a Mopar piece as it has the pentastar cast into it. What is it?
that's a 8 3/8 AKA 8 1/4 10 bolt
[Re: skicker]
#1712621
12/20/14 01:42 PM
12/20/14 01:42 PM
Posts: 16,844 Phoenix - surface of the sun
nomore65BelvJim
8 1/4 according to the part #...
Yup.
1976 or earlier due to the fill/level check plug being on the side of the housing. 77 moved the plug to the cover. Looking at the larger locating hole in the spring perches tells me iso-clamp mounting so its 73 or newer. 73-76 F, M, J, or B. Drum and perch widths will tell which. Looks identical to the one in my 76 Aspen wagon. The wagons all got an 8.25 with the HD brake drums.
