2005 Ram Running Boards #1712551
12/18/14 10:33 PM
12/18/14 10:33 PM
Lowes
steve660 Offline OP
steve660  Offline OP
Lowes
Wanting to put running boards on 2005 1/2 ton reg cab Ram. Does anyone know What years will interchange? Found a few for sale locally but they're off a later model with Quad Cab.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure.
..... Now its a door stop....
Re: 2005 Ram Running Boards [Re: steve660] #1712552
12/18/14 10:50 PM
12/18/14 10:50 PM
Fallon, Nv
SeventyGTX Offline
SeventyGTX  Offline
Fallon, Nv
02-08 1500's and 03-08 2500/3500's should all be the same from my experience. Basically anything off a Gen 3 should fit right up, doubtful Gen 4's will work.
Re: 2005 Ram Running Boards [Re: SeventyGTX] #1712553
12/18/14 10:56 PM
12/18/14 10:56 PM
Lowes
steve660 Offline OP
steve660  Offline OP
Lowes
Thanks...Are they all bolt on??
Re: 2005 Ram Running Boards [Re: steve660] #1712554
12/19/14 12:41 AM
12/19/14 12:41 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The ones I've seen use a bracket that the tube bolts to and the bracket mounts to the body mounting bolts. They always seem to break off the bolt that mounts the tube to the brackets. Make sure you get the brackets, then hopefully your cab mounting bolts will come out without breaking. I know some of the older cab mounting bolts used to mount the tube brackets don't come out very well sometimes.
Also, look the bottom and the ends of the tubes over real good, that is where they rot out. Replacing that piece the bolt screws into, on the end of the tube that mounts the tube to the bracket, is a pita. Gene
Re: 2005 Ram Running Boards [Re: poorboy] #1712555
12/19/14 01:24 AM
12/19/14 01:24 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I just bought and installed these from Ebay. Went on in 30 minutes and are solid as a rock with my 190lbs bouncing on them. My 5'2" wife loves them.
http://www.ebay.com/itm/301232311079?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Re: 2005 Ram Running Boards [Re: stumpy] #1712556
12/19/14 01:34 AM
12/19/14 01:34 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Mine came with longer bolts to replace the factory bolts. Took about an hour to do both. I assume you have a regular cab?
JB Rhinehart, Realist
A-Body's RULE!
Re: 2005 Ram Running Boards [Re: Rhinodart] #1712557
12/19/14 01:55 AM
12/19/14 01:55 AM
Fallon, Nv
SeventyGTX Offline
SeventyGTX  Offline
Fallon, Nv
In my first response, I didn't see you had a regular cab. I was under the impression you were looking to put 09+ QC boards on an 05 QC. I don't believe QC running boards will fit on a regular cab. I could be wrong, but I don't think so.
Re: 2005 Ram Running Boards [Re: SeventyGTX] #1712558
12/19/14 02:09 AM
12/19/14 02:09 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Quad cab and regular cab running boards are entirely different.
Re: 2005 Ram Running Boards [Re: stumpy] #1712559
12/19/14 12:45 PM
12/19/14 12:45 PM
Lowes
steve660 Offline OP
steve660  Offline OP
Lowes
Thanks for all the replies. I may look into some off Ebay if I cant find any decent ones locally. Just don't want any that are rusty or have broken off/ stripped bolts.
Re: 2005 Ram Running Boards [Re: steve660] #1712560
12/19/14 02:43 PM
12/19/14 02:43 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
$105 for brand new shipped to your door is a pretty good price.
Re: 2005 Ram Running Boards [Re: stumpy] #1712561
12/20/14 08:25 PM
12/20/14 08:25 PM
Lowes
steve660 Offline OP
steve660  Offline OP
Lowes
Im thinking about the same ones you bought. How do they attach....to the cab bolts or to the rocker panel?
Re: 2005 Ram Running Boards [Re: steve660] #1712562
12/20/14 08:52 PM
12/20/14 08:52 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Cab bolts. Look below the description box on the ad I provided for complete instruction video. Super easy install and solid as a rock. I did do the extra support a little differently. You could drill a hole for the inside of the front brace but I just butted it up against the frame and it works fine.
