Page 3 of 3 1 2 3
Re: 470 to 512 [Re: fattire] #1712439
12/26/14 12:50 PM
12/26/14 12:50 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Now I'm really confused
FILTER..............I`ve seen dyno shootouts w/cams installed at 99-101 and made sick power. Kinda like carbs, no two motors signal the same so the tune up needs are different. My custom Isky solid roller w/.680-.660 lift and 276-281 @ .050 purrs like a kitten in my 470 and pulls to 7500 if needed. As it was described to me; if u run an exhaust system then the tighter lsa helps BUT I was still pullin on a chassis dyno past 7000 and not tapering off. Pick YOUR flavor...........
Re: 470 to 512 [Re: ProSport] #1712440
12/26/14 01:50 PM
12/26/14 01:50 PM
Mentor,Oh.
fattire Offline OP
fattire  Offline OP
Mentor,Oh.
Found the card:@1.5 rocker ratio
lobe lift-int. 0.435 exh. 0.430
valve lift- int. 653 exh. 645
adv. dur. - int. 289 exh. 300
dur@.050 - int. 259 exh. 267
lobe centerline - int. 108 exh. 116
valve timing int. open 21.5 btdc close 57.5 abdc exh. 69.5 bbdc 17.5 atdc
lobe separation 112
degree intake lobe to 108
Re: 470 to 512 [Re: fattire] #1712441
12/26/14 02:02 PM
12/26/14 02:02 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`ve never run anything wider that a 110 so no help here but other than the wide lsa it looks pretty good to me.............
Re: 470 to 512 [Re: fattire] #1712442
12/26/14 09:34 PM
12/26/14 09:34 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
The 112 LS of that cam helps it to be more streetable with more idle vacuum. Youd be faster with a 108 LS with the same specs listed. Nice cam except for the 112. But like I said it does help with street manors. Its a comprimise cam IMO
Re: 470 to 512 [Re: Sport440] #1712443
12/27/14 12:07 AM
12/27/14 12:07 AM
Mentor,Oh.
fattire Offline OP
fattire  Offline OP
Mentor,Oh.
Well it is a street car that goes to the track D.O.T. tires full exhaust air cleaner even a kick butt sound system just think there is some more in it, thinking heads and carb should get me 10.30 - 10.40
Re: 470 to 512 [Re: fattire] #1712444
12/27/14 12:18 AM
12/27/14 12:18 AM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
What's the weight? Where does converter flash to? What rear ratio? What tire diameter?...kinda surprised you're not at those ETs!
Re: 470 to 512 [Re: fattire] #1712445
12/27/14 01:42 AM
12/27/14 01:42 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Well, you posted 1.46/1.48 60ft. times. That's kind of soft for the engine combo. More carb and ported heads might even make those 60,fts slower.
But even with that said, those EZ heads OOTB arent that great, so yes have them ported.
It seems you have the budget for the 512, so YES Id go ahead and do that too. But , I say NO on the 12.5 comp.512 motor, if you do that you've just "lost" your Street car combo. Keep it around 10.5/11.0 max and enjoy pump gas.
Further, that cam you have now will be better suited for the 512 vs the 470.
That 470 is a good motor, if your going to stick with it. Change the cam and port the EZheads and swap carbs. @ 3700# your ride isn't running to bad, but she does have more in her.
With a 1.46/1.48 your running what, about a 10.75 to 10.9 ET If your ET,s are faster then that, your actually running pretty good with that motor at 3700# Maybe you need more Vert.
Id say just go with the 512, more streetable at a 10.5 comp, and plus you know you Want one.
Re: 470 to 512 [Re: Sport440] #1712446
12/27/14 02:42 AM
12/27/14 02:42 AM
Mentor,Oh.
fattire Offline OP
fattire  Offline OP
Mentor,Oh.
Yes you hit the nail on the head with your ET estimate but have been the fastest of 10.58 with good air. Ran a 63 with a 3 on a 63 dial so moved it down to 59 for the next round and ran 58 with a 8 but that's better than red
Re: 470 to 512 [Re: GTS340] #1712447
12/27/14 02:45 AM
12/27/14 02:45 AM
Mentor,Oh.
fattire Offline OP
fattire  Offline OP
Mentor,Oh.
Around 3700 with me,4200 on the vert,31" tire,430 gears
Re: 470 to 512 [Re: fattire] #1712448
12/27/14 01:13 PM
12/27/14 01:13 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
What's your trap RPM?
Re: 470 to 512 [Re: ProSport] #1712449
12/27/14 04:03 PM
12/27/14 04:03 PM
Mentor,Oh.
fattire Offline OP
fattire  Offline OP
Mentor,Oh.
Around 6700 give or take
Re: 470 to 512 [Re: ProSport] #1712450
12/27/14 04:27 PM
12/27/14 04:27 PM
gregsdart Offline
gregsdart  Offline
David Vizzard's latest book HOW TO BUILD HORSEPOWER has some great info on why and where the LSA should be for different motors. In a nut shell, it is about intake valve to cubic inches,valve to valve relationship, combined with a bit wider LSA for high compression. Our big blocks suffer from small valves to start with. They are also parallel, which doesn't help. Then we stroke them to the limit and reduce the overlap flow needed per cubic inch even more.
When you get into large engines there is a need for more exhaust flow, and in my case with 528 cubes and 7100 rpm shifts it works out to 110 to 112 LSA IF it has more exhaust duration. Because I have over 15/1 compression and poor exhaust flow for the cubes and fuel, it works. The cam timing is brought back to more like a 110 or 108 LSA by advancing it combined with the extra exhaust duration. If you look at the card numbers, my cam current cam which is 284/296/112 installed at 108 looks like a 108 LSA cam with 284 intake and 284 exhaust duration on all three opening and closing points but the exhaust opening point.
With very high compression, the pressure in the cylinder decreases at a high rate compared to low compression, and for that reason opening the exhaust early is less detrimental than the gains from more exhaust flow.
Re: 470 to 512 [Re: gregsdart] #1712451
12/27/14 08:52 PM
12/27/14 08:52 PM
Mentor,Oh.
fattire Offline OP
fattire  Offline OP
Mentor,Oh.
I'm no where near that at 10.75, and thanks I'll look for that book.
Page 3 of 3 1 2 3
