Race gas aluminum head corrosion? #1712269
12/18/14 03:28 PM
12/18/14 03:28 PM
Penna
70satelliteguy Offline OP
Penna
My setup is currently at the machine shop. They informed me that my aluminum heads have some corrosion in the exhaust ports from using RACE gas.Intake ports are clean. They said it is pretty common. Should I be worried?
I run Sunoco 112 with 13.5 compression and 35 degrees of timing.
Mike
Re: Race gas aluminum head corrosion? [Re: 70satelliteguy] #1712270
12/18/14 03:30 PM
12/18/14 03:30 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Mike
I wouldn`t worry about it myself and would have em cleaned and polish the heck out of em...............
Re: Race gas aluminum head corrosion? [Re: 70satelliteguy] #1712271
12/18/14 03:49 PM
12/18/14 03:49 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
It use to freak me out every time I had my 451 apart, heads looked terribly corroded on the intake and the exhaust sides, and they were cnc ported/polished. It looked like chunks of aluminum were sand blasted off. Motor ran 9's for many years though and plugs always looked good.
Re: Race gas aluminum head corrosion? [Re: ProSport] #1712272
12/18/14 04:04 PM
12/18/14 04:04 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Interesting, I saw this on a friend's 440 we had the heads off of over the summer, the 2 center exhaust ports had a build up. He runs 110 Sunoco all the time and its a street car.
Re: Race gas aluminum head corrosion? [Re: ProSport] #1712273
12/18/14 05:23 PM
12/18/14 05:23 PM
Penna
Penna
"It use to freak me out every time I had my 451 apart, heads looked terribly corroded on the intake and the exhaust sides, and they were cnc ported/polished. It looked like chunks of aluminum were sand blasted off. Motor ran 9's for many years though and plugs always looked good. "
Prosport, mine are only corroded on the exhaust but also some in the combustion chamber also. Pretty much everywhere the gas is being burnt.
This is a race car only and I do use Nitrous a few time a year but only up to 250 HP shot and it is a conservative tune up with plenty of timing retard.
It does have a sand blasted look to it!
My plugs always look good.
Mike
Re: Race gas aluminum head corrosion? [Re: 70satelliteguy] #1712274
12/18/14 05:36 PM
12/18/14 05:36 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Mike
I don't think it's from the gas, it's from condensation. IMO
Re: Race gas aluminum head corrosion? [Re: Challenger 1] #1712275
12/18/14 06:05 PM
12/18/14 06:05 PM
Penna
Penna
"I don't think it's from the gas, it's from condensation. IMO "
Challenger could you elaborate
Thanks Mike
Re: Race gas aluminum head corrosion? [Re: 70satelliteguy] #1712276
12/18/14 06:13 PM
12/18/14 06:13 PM
Cincinnati, Ohio
Cincinnati, Ohio
Thanks Mike
Aluminum heads condensate much more than iron heads. Being a race engine it has a lot heating and cooling cycles which leave moisture. Then it sits and corrodes.
Re: Race gas aluminum head corrosion? [Re: Challenger 1] #1712277
12/18/14 06:28 PM
12/18/14 06:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Mike
... corrosion on alum is from water
Re: Race gas aluminum head corrosion? [Re: MR_P_BODY] #1712278
12/18/14 07:15 PM
12/18/14 07:15 PM
Just don't lick the head and you will be fine
I see it when folks bring engines and or heads that have been sitting a long time or sitting in damp trailer etc
Water/ weather not fuel IMO
Clean 'em up keep moving no worry
